Hallo Leute,
hier meine einfache Lib für den RP6, um max. 8 Servos betreiben zu können.
Have fun!![]()
Demoprogramm:
Header-Datei (RP6BaseServoLib.h):Code:// Uncommented Version of RP6BaseServo.c // written by Dirk // ------------------------------------------------------------------------------------------ #include "RP6BaseServoLib.h" uint16_t pos = 0; int main(void) { initRobotBase(); writeString_P("\n\n _______________________\n"); writeString_P(" \\| RP6 ROBOT SYSTEM |/\n"); writeString_P(" \\_-_-_-_-_-_-_-_-_-_/\n\n"); writeString_P("################\n"); writeString_P("<<RP6 Base>>\n"); writeString_P(" Servo - Test 1 \n"); writeString_P(" Version 1.20 \n"); writeString_P("################\n\n"); mSleep(2500); setLEDs(0b111111); mSleep(500); initSERVO(SERVO1 | SERVO2); startStopwatch2(); while(true) { if (getStopwatch2() > 48) { servo1_position = pos; servo2_position = pos; pos++; if (pos > RIGHT_TOUCH) {pos = 0;} setStopwatch2(0); } task_SERVO(); task_RP6System(); } return 0; }
Bibliothek (RP6BaseServoLib.c):Code:/* **************************************************************************** * _______________________ * \| RP6 ROBOT SYSTEM |/ * \_-_-_-_-_-_-_-_-_-_/ >>> BASE CONTROLLER * ---------------------------------------------------------------------------- * ------------------------ [c]2008 - Dirk ------------------------------------ * **************************************************************************** * File: RP6BaseServoLib.h * Version: 1.2 * Target: RP6 Base - ATMEGA32 @8.00MHz * Author(s): Dirk * **************************************************************************** * Description: * This is the RP6BaseServoLib header file. * You have to include this file, if you want to use the library * RP6BaseServoLib.c in your own projects. * * **************************************************************************** * THE CHANGELOG CAN BE FOUND AT THE END OF THIS FILE! * **************************************************************************** */ /*****************************************************************************/ // Includes: #include "RP6RobotBaseLib.h" // The RP6 Robot Base Library. // Always needs to be included! /*****************************************************************************/ // Defines: // Servo constants: #define SERVO1 0b00000001 #define SERVO2 0b00000010 #define SERVO3 0b00000100 #define SERVO4 0b00001000 #define SERVO5 0b00010000 #define SERVO6 0b00100000 #define SERVO7 0b01000000 #define SERVO8 0b10000000 // Servo movement limits (depending on servo type): // Standard Servos need an impulse every 20ms (50Hz). This impulse must have // a length of 1ms (0.7 .. 1ms) to move the servo lever to the left touch // and a length of 2ms (2 .. 2.3ms) for moving it to the right touch. In the // middle position the servo needs an impulse length of 1.5ms (1.3 .. 1.6ms). // If you want to modify the following constants for a certain servo type, // you must adapt the LEFT_TOUCH constant first (values ~690 .. 990 = ~0.7 .. // 1ms) by using a servo position value (servoX_position) of zero. // After that you have two "screws" to adjust the servo movement limits: // First you may change the RIGHT_TOUCH constant. If you choose a higher // value than 255, you will use 16-bit values. Higher values mean a longer // impulse length, but longer impulses than 2.3ms do not make sense. // Second you may alter the number of nop() instructions in the pulseSERVO() // function. Less nop()s lead to smaller steps of the servo movement. This of // course reduces the impulse length and may be compensated again by a higher // RIGHT_TOUCH constant. #define LEFT_TOUCH 692 // Left servo touch (~0.7ms) #define RIGHT_TOUCH 254 // Right servo touch (~2.3ms) #define MIDDLE_POSITION (RIGHT_TOUCH / 2) // Middle position (~1.5ms) #define PULSE_REPETITION 17 // Pulse repetition freq. (~50Hz) // Servo ports: #define SERVO1_PULSE_ON (PORTC |= SL1) // PC4 #define SERVO1_PULSE_OFF (PORTC &= ~SL1) #define SERVO2_PULSE_ON (PORTC |= SL2) // PC5 #define SERVO2_PULSE_OFF (PORTC &= ~SL2) #define SERVO3_PULSE_ON (PORTC |= SL3) // PC6 #define SERVO3_PULSE_OFF (PORTC &= ~SL3) #define SERVO4_PULSE_ON (PORTB |= SL4) // PB7 #define SERVO4_PULSE_OFF (PORTB &= ~SL4) #define SERVO5_PULSE_ON (PORTB |= SL5) // PB1 #define SERVO5_PULSE_OFF (PORTB &= ~SL5) #define SERVO6_PULSE_ON (PORTB |= SL6) // PB0 #define SERVO6_PULSE_OFF (PORTB &= ~SL6) #define SERVO7_PULSE_ON (PORTC |= SCL) // PC0 #define SERVO7_PULSE_OFF (PORTC &= ~SCL) #define SERVO8_PULSE_ON (PORTC |= SDA) // PC1 #define SERVO8_PULSE_OFF (PORTC &= ~SDA) // ----------------------------------------------------------- // Other possible ports for connecting Servos to RP6Base: //#define SERVOx_PULSE_ON (PORTA |= ADC0) // PA0 //#define SERVOx_PULSE_OFF (PORTA &= ~ADC0) //#define SERVOx_PULSE_ON (PORTA |= ADC1) // PA1 //#define SERVOx_PULSE_OFF (PORTA &= ~ADC1) //#define SERVOx_PULSE_ON (PORTA |= E_INT1) // PA4 //#define SERVOx_PULSE_OFF (PORTA &= ~E_INT1) // ----------------------------------------------------------- /*****************************************************************************/ // Variables: uint16_t servo1_position; // Servo 1 position [0..RIGHT_TOUCH] uint16_t servo2_position; // Servo 2 position [0..RIGHT_TOUCH] uint16_t servo3_position; // Servo 3 position [0..RIGHT_TOUCH] uint16_t servo4_position; // Servo 4 position [0..RIGHT_TOUCH] uint16_t servo5_position; // Servo 5 position [0..RIGHT_TOUCH] uint16_t servo6_position; // Servo 6 position [0..RIGHT_TOUCH] uint16_t servo7_position; // Servo 7 position [0..RIGHT_TOUCH] uint16_t servo8_position; // Servo 8 position [0..RIGHT_TOUCH] /*****************************************************************************/ // Functions: void initSERVO(uint8_t servos); void startSERVO(void); void stopSERVO(void); void pulseSERVO(void); void task_SERVO(void); /****************************************************************************** * Additional info * **************************************************************************** * Changelog: * - v. 1.0 (initial release) 03.05.2008 by Dirk * - v. 1.1 (bugs fixed) 21.12.2008 by Dirk * - v. 1.2 (pulse generation improved) 26.12.2008 by Dirk * * **************************************************************************** */ /*****************************************************************************/ // EOF
DirkCode:/* **************************************************************************** * _______________________ * \| RP6 ROBOT SYSTEM |/ * \_-_-_-_-_-_-_-_-_-_/ >>> BASE CONTROLLER * ---------------------------------------------------------------------------- * ------------------------ [c]2008 - Dirk ------------------------------------ * **************************************************************************** * File: RP6BaseServoLib.c * Version: 1.2 * Target: RP6 Base - ATMEGA32 @8.00MHz * Author(s): Dirk * **************************************************************************** * Description: * This is my simple RP6 Base Servo Library for up to 8 Servos. * * COMMENT: It is a good idea to use a separate power supply for the servos! * * Servo connections: * SERVO1 -> Status LED 1 (SL1) SERVO5 -> Status LED 5 (SL5) * SERVO2 -> Status LED 2 (SL2) SERVO6 -> Status LED 6 (SL6) * SERVO3 -> Status LED 3 (SL3) SERVO7 -> PC0 (I2C bus: SCL) * SERVO4 -> Status LED 4 (SL4) SERVO8 -> PC1 (I2C bus: SDA) * If you want to use the RP6 bumpers in your program, you should not * connect Servos to SL3 and SL6. * It is not possible to use the I2C bus, if Servos are connected to SCL * and/or SDA. Instead of SCL/SDA you could use ADC0/ADC1 for servo 7/8, * if you want to use the I2C bus. * * **************************************************************************** * ATTENTION: Stopwatch 1 is used for the servo task! Please do * not use this stopwatch elsewhere in your program! * * **************************************************************************** * THE CHANGELOG CAN BE FOUND AT THE END OF THIS FILE! * **************************************************************************** */ /*****************************************************************************/ // Includes: #include "RP6BaseServoLib.h" /*****************************************************************************/ // Variables: uint8_t usedservos; uint8_t servo_on = FALSE; /*****************************************************************************/ // Functions: /** * INIT SERVO * * Call this once before using the servo library. * * Input: Servos -> Used Servos * Examples: * - initSERVO(SERVO1 | SERVO2) -> Use only Servos 1 and 2 * - initSERVO(SERVO1 | SERVO6) -> Use only Servos 1 and 6 * - initSERVO(SERVO1 | SERVO2 | SERVO8) -> Use Servos 1, 2 and 8 * */ void initSERVO(uint8_t servos) { setLEDs(0b000000); // All LEDs off! usedservos = servos; // Save used Servos if (servos & SERVO1) {DDRC |= SL1; PORTC &= ~SL1;} if (servos & SERVO2) {DDRC |= SL2; PORTC &= ~SL2;} if (servos & SERVO3) {DDRC |= SL3; PORTC &= ~SL3;} if (servos & SERVO4) {DDRB |= SL4; PORTB &= ~SL4;} if (servos & SERVO5) {DDRB |= SL5; PORTB &= ~SL5;} if (servos & SERVO6) {DDRB |= SL6; PORTB &= ~SL6;} if (servos & SERVO7) {DDRC |= SCL; PORTC &= ~SCL;} if (servos & SERVO8) {DDRC |= SDA; PORTC &= ~SDA;} // ----------------------------------------------------------- // Other possible ports for connecting Servos to RP6Base: // if (servos & SERVOx) {DDRA |= ADC0; PORTA &= ~ADC0;} // if (servos & SERVOx) {DDRA |= ADC1; PORTA &= ~ADC1;} // if (servos & SERVOx) {DDRA |= E_INT1; PORTA &= ~E_INT1;} // ----------------------------------------------------------- startSERVO(); startStopwatch1(); // Needed for 20ms pulse repetition } /** * START SERVO * * If the servo function was stopped with the * function stopSERVO() before, it can be * started again with this function. * */ void startSERVO(void) { servo_on = TRUE; } /** * STOP SERVO * * The servo function uses a certain amount of the * processor's calculating time. If the Servos are * not moving for a while, the servo pulse * generation can be stopped with this function. * */ void stopSERVO(void) { servo_on = FALSE; } /** * PULSE SERVO * * This is the servo pulse generation. This function * must be called every 20ms (pulse repetition). * * position = 0 : Left touch * position = RIGHT_TOUCH : Right touch * position = MIDDLE_POSITION : Middle position * * ATTENTION: ! This function is BLOCKING all other activities for up to 2 ! * ! ms!!! ! * ! If you generate a pulse every 20ms <= 10% of the processor's ! * ! calculating time is wasted by this kind of pulse generation. ! * ! If this is a problem for the rest of your program, you ! * ! cannot use this method. ! * ! You will need an interrupt- or PWM-based solution instead. ! * */ void pulseSERVO(void) {uint16_t position = 0; uint8_t pulse_active = usedservos; if (servo_on) { cli(); if (usedservos & SERVO1) {SERVO1_PULSE_ON;} if (usedservos & SERVO2) {SERVO2_PULSE_ON;} if (usedservos & SERVO3) {SERVO3_PULSE_ON;} if (usedservos & SERVO4) {SERVO4_PULSE_ON;} if (usedservos & SERVO5) {SERVO5_PULSE_ON;} if (usedservos & SERVO6) {SERVO6_PULSE_ON;} if (usedservos & SERVO7) {SERVO7_PULSE_ON;} if (usedservos & SERVO8) {SERVO8_PULSE_ON;} delayCycles(LEFT_TOUCH); // Delay ~0.7ms (left touch) while (position <= RIGHT_TOUCH) { if ((usedservos & SERVO1) && (position == servo1_position)) { SERVO1_PULSE_OFF; pulse_active &= ~SERVO1;} if ((usedservos & SERVO2) && (position == servo2_position)) { SERVO2_PULSE_OFF; pulse_active &= ~SERVO2;} if ((usedservos & SERVO3) && (position == servo3_position)) { SERVO3_PULSE_OFF; pulse_active &= ~SERVO3;} if ((usedservos & SERVO4) && (position == servo4_position)) { SERVO4_PULSE_OFF; pulse_active &= ~SERVO4;} if ((usedservos & SERVO5) && (position == servo5_position)) { SERVO5_PULSE_OFF; pulse_active &= ~SERVO5;} if ((usedservos & SERVO6) && (position == servo6_position)) { SERVO6_PULSE_OFF; pulse_active &= ~SERVO6;} if ((usedservos & SERVO7) && (position == servo7_position)) { SERVO7_PULSE_OFF; pulse_active &= ~SERVO7;} if ((usedservos & SERVO8) && (position == servo8_position)) { SERVO8_PULSE_OFF; pulse_active &= ~SERVO8;} if (!pulse_active) break; // Longest pulse done: Break! // Delay 9 cycles for an 8-bit servo movement range [0..255]: nop(); nop(); nop(); nop(); nop(); nop(); nop(); nop(); nop(); position++; } sei(); } } /** * SERVO TASK * * This is the servo task. The task performes the pulse repetition * with the help of a stopwatch. * */ void task_SERVO(void) { if (getStopwatch1() > PULSE_REPETITION) { // Pulse every ~20ms pulseSERVO(); // Servo pulse generation setStopwatch1(0); } } /****************************************************************************** * Additional info * **************************************************************************** * Changelog: * - v. 1.0 (initial release) 03.05.2008 by Dirk * - v. 1.1 (bugs fixed) 21.12.2008 by Dirk * - v. 1.2 (pulse generation improved) 26.12.2008 by Dirk * * **************************************************************************** */ /*****************************************************************************/ // EOF
Zitieren
