Habs grad selbst herausgefunden, trotzdem danke !
Code:$regfile = "m32def.dat" $crystal = 16000000 'Quarzfrequenz $baud = 9600 Config Serialin = Buffered , Size = 30 Dim Ar(6) As String * 7 Dim Bcount As Byte Dim Telegramm As String * 30 Dim E_adr As String * 7 Dim E_aktion As String * 7 Dim E_typ As String * 7 Dim E_property As String * 7 Dim E_wert As String * 7 Dim E_check As String * 7 Dim I_wert As Integer Dim B_wert As Byte Dim I As Byte Enable Interrupts Print "Start" Do 'get a char from the UART If Ischarwaiting() = 1 Then 'was there a char? Input Telegramm Print Telegramm 'print it Bcount = Split(telegramm , Ar(1) , "!") 'Aufteilen des Telegramms auf Arryes E_adr = Ar(1) E_aktion = Ar(2) E_typ = Ar(3) E_property = Ar(4) E_wert = Ar(5) E_check = Ar(6) End If Loop
Zitieren
