Thema: LCD 44780 zeigt nur schwarze Balken
    Hallo Leute!!
    seit 3 Tagen versuche ich mein LC-Display zum Laufen zu bringen.
    LC-Display hab ich an den AtMEga8 angeschloßen.
    Hier ist der Auszug aus dem Assemblercode!
    include "m8def.inc"
    ; Reset and Interrupt vector ; VNr. Beschreibung
    rjmp main ; 1 POWER ON RESET
    ; Start, Power ON, Reset
    main: ldi r16,low(RAMEND)
    out SPL,r16 ; Init Stackpointer LO
    ldi r16,high(RAMEND)
    out SPH,r16 ; Init Stackpointer HI
    rcall LCD_init
    mainloop: rcall wait
    ldi r16, 'T'
    rcall LCD_data
    ldi r16, 'e'
    rcall LCD_data
    ldi r16, 's'
    rcall LCD_data
    ldi r16, 't'
    rcall LCD_data
    rjmp mainloop
    ;hier Unterprogramme und Interruptroutinen zuf�gen
    wait: push r24
    ldi r24,0x13 ; hier delay einstellen 13 = ca. 20yS
    w1: subi r24,0x01
    rcall wait20ms
    brcc w1
    pop r24
    ret
    wait5ms: ldi r16, 255
    ldi r17, 26
    w5ms: dec r16
    brne w5ms
    dec r17
    brne w5ms
    ret
    wait20ms: ldi r16, 255
    ldi r17,104
    w20ms: dec r16
    brne w20ms
    dec r17
    brne w20ms
    ret
    LCD_init: sbi DDRD,4 ;LCD RS = OUT
    sbi DDRD,5 ;LCD E = OUT
    sbi DDRC,0 ;LCD D4 = OUT
    sbi DDRC,1 ;LCD D5 = OUT
    sbi DDRC,2 ;LCD D6 = OUT
    sbi DDRC,3 ;LCD D7 = OUT
    cbi PORTD,4 ;LDC RS = Low
    ;warte bis PowerUp
    ldi r18,20
    powerup: rcall wait5ms
    dec r18
    brne powerup ; Power-Up Wartezyklus min 30 ms
    ; sende init 1
    ldi r16, 0b00100000 ; 4 Bit Modus aktivieren
    out PORTD, r16
    rcall LCD_enable ; Enable-Impuls
    rcall wait5ms
    ldi r16, 0b00101000
    rcall LCD_cmd ; Function Set 4 Bit, 2 Zeilen, 5x7
    rcall LCD_off
    rcall LCD_clear
    ldi r16, 0x06
    rcall LCD_cmd ; Entry Mode Set, increase+shifted
    rcall LCD_on
    ret
    LCD_data: ldi r18,0b0000100 ;RS = hi
    rjmp LCD_out
    LCD_cmd: ldi r18,0b0000000 ;RS = lo
    LCD_out: mov r17, r16
    swap r17
    andi r16, 0b11110000
    or r16,r18
    andi r17, 0b11110000
    or r17,r18
    out PORTD, r16
    rcall LCD_enable
    out PORTD, r17
    rcall LCD_enable
    rcall wait5ms
    ret
    LCD_enable: sbi PORTD, 5 ; Enable high
    nop ; kurz warten
    nop
    nop
    cbi PORTD, 5 ; Enable wieder low
    ret
    LCD_clear: ldi r16, 0b00000001 ; Display l�schen
    rcall LCD_cmd
    rcall wait5ms
    ret
    LCD_off: ldi r16, 0b00001000
    rcall LCD_cmd
    rcall wait5ms
    ret
    LCD_on: ldi r16, 0x0E
    rcall LCD_cmd
    rcall wait5ms
    ret
    Erlangen
    Wäre auch hilfreich zu wissen, wie du dein LCD angeschlossen hast Bild
    €: Ahja, leuchtet das LCD, gibt es schwarze Balken? Oder passiert garnichts?
    Zwei Dinge sind unendlich: Das Universum und die menschliche Dummheit. Aber beim Universum bin ich mir nicht ganz sicher.
    (Albert Einstein, 1879-1955)
    Hallo!!
    also Ich habe Datenbits DB4-DB7 an den PORTC angeschloßen
    DB4- 0
    DB5-1
    DB6-2
    DB7-3
    dann ENABLE habe ich an den Port D angeschlosen nähmlich an den Pin5
    und RS auch an den PORT D an den Pin4
    Erfahrener Benutzer Roboter Genie Avatar von oratus sum
    Wenn es nur schwarze Balken zeigt, dann kann es sein, dass eine zu große Spannung beim Kontrast hast.
    Oder du bleibst bei der Initialisierung stecken.
