Ergebnis 11 bis 20 von 25
Thema: Erstes eigenes Programm
    Erfahrener Benutzer Begeisterter Techniker Avatar von Ferdinand
    Zendure
    ok
    Ich habe den path zu AsuroLib geendert und jetst kommt das
    >Ready.
    >Session Environment Variables:
    AF_AVRDIR=C:\WinAVR-20080610
    AF_PROJECT=Project1
    AF_SOURCE_FILES=test1.c
    AF_ASM_SRC_FILES=
    AF_PRGDIR=C:\Programme\AsuroFlash
    AF_PRJDIR=C:\Dokumente und Einstellungen\All Users\Anwendungsdaten\AsuroFlash
    AF_LIB_PATH=C:\AsuroFlash\AsuroLib-v280rc1\lib
    File test1.c saved.
    >Default make_all.cmd file created.
    >Default makefile created.
    Make
    C:\Dokumente und Einstellungen\All Users\Anwendungsdaten\AsuroFlash>C:\WinAVR-20080610\utils\bin\make all
    set -e; avr-gcc -MM -mmcu=atmega8 -DF_CPU=8000000UL -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test1.lst -IC:\Programme\AsuroFlash\include -IC:\AsuroFlash\AsuroLib-v280rc1\lib\inc test1.c \
    	| sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > test1.d; \
    	[ -s test1.d ] || rm -f test1.d
    -------- begin --------
    avr-gcc --version
    avr-gcc (WinAVR 20080610) 4.3.0
    Copyright (C) 2008 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    avr-gcc -c -mmcu=atmega8 -DF_CPU=8000000UL -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test1.lst -IC:\Programme\AsuroFlash\include -IC:\AsuroFlash\AsuroLib-v280rc1\lib\inc test1.c -o test1.o
    avr-gcc -mmcu=atmega8 -DF_CPU=8000000UL -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test1.o -IC:\Programme\AsuroFlash\include -IC:\AsuroFlash\AsuroLib-v280rc1\lib\inc test1.o  --output Project1.elf -Wl,-Map=Project1.map,--cref -IC:\Programme\AsuroFlash\lib -LC:\AsuroFlash\AsuroLib-v280rc1\lib -lm -lasuro
    test1.o: In function `main':
    C:\Dokumente und Einstellungen\All Users\Anwendungsdaten\AsuroFlash/test1.c:5: undefined reference to `Init'
    make: *** [Project1.elf] Error 1
    ExitCode 2
    was muss ich jetst machen ?
    thx
    habe schreiben erst heute gelernt.
    bin legasteniger.
    by Ferdinand.
    ich bekomme kein *.hex
    #include "asuro.h"
    init();
    int main(void){
        unsigned int data[2];
    //init();
      FrontLED(ON);
      MotorDir(FWD,FWD);
       while (1)
     LineData(data);
       if (data[0] > data[1])
       MotorSpeed(200,150);
      else
      MotorSpeed(150,200) ;
       return 0;
    > "C:\ASURO_src\FirstTry\Test-all.bat"
    C:\ASURO_src\FirstTry>make all
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > asuro.d; \
    [ -s asuro.d ] || rm -f asuro.d
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > test.d; \
    [ -s test.d ] || rm -f test.d
    avr-gcc --version
    avr-gcc (GCC) 3.3.1
    Copyright (C) 2003 Free Software Foundation, Inc.
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c -o test.o
    test.c:5: warning: type defaults to `int' in declaration of `init'
    test.c:5: warning: function declaration isn't a prototype
    test.c:5: warning: data definition has no type or storage class
    test.c:45:2: warning: no newline at end of file
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c -o asuro.o
    avr-gcc -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.o test.o asuro.o   --output test.elf -Wl,-Map=test.map,--cref -lm
    avr-objcopy -O ihex -R .eeprom test.elf test.hex
    avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \
    --change-section-lma .eeprom=0 -O ihex test.elf test.eep
    avr-objdump -h -S test.elf > test.lss
    Size after:
    test.elf  :
    section    size      addr
    .text      1552         0
    .data         0   8388704
    .bss          1   8388704
    .noinit       0   8388705
    .eeprom       0   8454144
    .stab      3204         0
    .stabstr   1763         0
    Total      6520
    Errors: none
    -------- end --------
    > Process Exit Code: 0
    > Time Taken: 00:00
    thx
    bin legasteniger.
    by Ferdinand.
    8
    Warum schreibst du das Init() außerhalb von main()? Das wird natürlich angemotzt:
    ...und nach dem letzten } fehlt angeblich noch ein [Enter]
    Warum kein .hex erzeugt wird weiß ich auch nicht. Vielleicht mal ein "clean all" ausführen...
    hi
    das kommt dabei raus
    #include "asuro.h"
    int main(void){
    init();
      FrontLED(ON);
      MotorDir(FWD,FWD);
       while (1)
     LineData(data);
      else
       return 0;
    avr-gcc --version
    avr-gcc (GCC) 3.3.1
    test.c: In function `main':
    test.c:10: warning: implicit declaration of function `init'
    test.o(.text+0x8): In function `main':
    C:\ASURO_src\FirstTry/test.c:10: undefined reference to `init'
    make: *** [test.elf] Error 1
    > Process Exit Code: 2
    > Time Taken: 00:01
    THX
    bin legasteniger.
    by Ferdinand.
    8
    Die Funktion heißt Init() mit großem I am Anfang. Wir sind nahe dran :)
    OK
    Ich hab jetzt alles neu gemacht mit den sahen von der Arexx HP und jetzt geht es.
    Du hast recht mit großem I
    Danke!!!
    wo find ich den ein besseres Beispiel für die "PollSwitch" tastern.
    Mit freundlichen Grüßen Ferdinand.
    bin legasteniger.
    by Ferdinand.
    Hildesheim
    Ich habe auch mal wieder den Asuro rausgekramt und habe mal versucht ein programm zu schreiben und zwar dieses hier:
    #include "asuro.h"
    int main(void)
    	unsigned char Speed;
    	unsigned int i;
    	Init();
    	StatusLED (GREEN);
    	MotorDir(FWD,FWD);
    	MotorSpeed(255,255);
    	while (PollSwitch()==0) {
    			StatusLED (GREEN);
    	MotorSpeed(0,0);
    	for (i=0; i<200; i++) {
    	Sleep(255);}
    	MotorDir(RWD,RWD);
    	MotorSpeed(150,150);
    	Sleep(255);}
    	MotorDir(RWD,FWD);
    	for (i=0; i<200; i++);{
    	Sleep(255); }
    	while(1);
    	return 0;
    Aber irgendwie zeigt er die fehlermeldung an
    avr-gcc --version
    avr-gcc (GCC) 3.3.1
    test.c:5: warning: unused variable `Speed'
    C:\Users\FELIXK~1\AppData\Local\Temp\make27964.sh: /c/WinAVR/bin/avr-objcopy: Invalid argument
    make: [test.eep] Error 126 (ignored)
    C:\Users\FELIXK~1\AppData\Local\Temp\make27965.sh: /c/WinAVR/bin/avr-objdump: Invalid argument
    make: *** [test.lss] Error 126
    Vielleicht kan mir jemand weiterhelfen! Es muss ja irgendwas mit dem unsigned char Speed zu tun haben.
    Wäre nett wenn mit jemand helfen könnte.
    Vielen Dank im Vorraus
    Felix
    Deine Speed Variable wirt nicht gebraucht
    komentire das mal aus " unsigned char Speed; " so.: //unsigned char Speed;
    by Ferdinand
    bin legasteniger.
    by Ferdinand.
    hallo
    das mit der nicht benutzten variable dürfte kein problem sein, da es nur eine warnung ist (ein hinweis an den programmierer, da er vl. etwas übersehen haben könnte)
    im weiteren verlauf der fehlermeldung treten aber auch noch 2 Error126. ich glaube man sollte herausfinden was es mit diesen auf sich hat. ich kann aber auch nichts genaueres dazu sagen
    mfg hai1991
    P.S.: wer großbuchstaben oder rechtschreibfehler findet darf sie behalten
    Hildesheim
    Also ich habe das Unsigned char Speed jetzt weggelassen und trotzdem kommt immer noch folgende Fehlermeldungen:
    avr-gcc --version
    avr-gcc (GCC) 3.3.1
    C:\Users\FELIXK~1\AppData\Local\Temp\make33804.sh: /c/WinAVR/bin/avr-objcopy: Invalid argument
    C:\Users\FELIXK~1\AppData\Local\Temp\make33805.sh: /c/WinAVR/bin/avr-objdump: Invalid argument
    Veilleicht hat doch noch jemand eine idee? wäre schön
    Vielen dank im Vorraus und an die Leute welche mir schon geholfenhaben!
    Felix
