ich bekomme kein *.hex
Code:#include "asuro.h" init(); int main(void){ unsigned int data[2]; //init(); FrontLED(ON); MotorDir(FWD,FWD); while (1) { LineData(data); if (data[0] > data[1]) { MotorSpeed(200,150); } else { MotorSpeed(150,200) ; } } return 0; }thxCode:> "C:\ASURO_src\FirstTry\Test-all.bat" C:\ASURO_src\FirstTry>make all set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > asuro.d; \ [ -s asuro.d ] || rm -f asuro.d set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > test.d; \ [ -s test.d ] || rm -f test.d -------- begin -------- avr-gcc --version avr-gcc (GCC) 3.3.1 Copyright (C) 2003 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c -o test.o test.c:5: warning: type defaults to `int' in declaration of `init' test.c:5: warning: function declaration isn't a prototype test.c:5: warning: data definition has no type or storage class test.c:45:2: warning: no newline at end of file avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c -o asuro.o avr-gcc -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.o test.o asuro.o --output test.elf -Wl,-Map=test.map,--cref -lm avr-objcopy -O ihex -R .eeprom test.elf test.hex avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \ --change-section-lma .eeprom=0 -O ihex test.elf test.eep avr-objdump -h -S test.elf > test.lss Size after: test.elf : section size addr .text 1552 0 .data 0 8388704 .bss 1 8388704 .noinit 0 8388705 .eeprom 0 8454144 .stab 3204 0 .stabstr 1763 0 Total 6520 Errors: none -------- end -------- > Process Exit Code: 0 > Time Taken: 00:00
Zitieren
