				Neuer Benutzer
				Öfters hier
							$regfile = "m32def.dat"
 $crystal = 6144000
 $baud = 19200
 $timeout = 100000
 Ddra = &B11111000
 Ddrb = &B11111111
 Ddrc = &B11111111
 Ddrd = &B11111111
 Porta = &B00000000
 Portb = &B00001100
 Portc = &B00000000
 Portd = &B00000000
 Porta.0 = 1                                                 '-pull up Widerstand für erste Taste aktivieren
 Porta.1 = 1                                                 '-pull up Widerstand für zweite Taste aktivieren
 Porta.2 = 1                                                 '-pull up Widerstand für zweite Taste aktivieren
 Config Lcdpin = Pin , Db4 = Porta.4 , Db5 = Porta.5 , Db6 = Porta.6 , Db7 = Porta.7 , E = Portb.5 , Rs = Portb.0
 Config Lcd = 16 * 2
 Config Porta = Output
 Reset Portb.1
 Initlcd
 Cursor Off
 Cls
 Porta.3 = 1                                                 'Licht an
 'Declare Function Read_gsm(byval Mask As String) As Byte
 Dim A As String * 10
 Dim B As Word
 Dim C As Word
 Dim D As String * 32
 Dim E As String * 32
 Dim F As String * 32
 Dim Status As Byte
 Config Serialin = Buffered , Size = 20
 Enable Interrupts
 C = 0
 Print "at"
 Locate 1 , 1
 for b = 1 to 50
 A = Inkey()
 If Err = 0 Then
 Lcd A
 End If
 Waitms 100
 If C = 16 Then
 Locate 2 , 1
 End If
 Incr C
 Next B
 Locate 2 , 1
 Lcd A
 End
		- Neue Themen erstellen: Nein
- Themen beantworten: Nein
- Anhänge hochladen: Nein
- Beiträge bearbeiten: Nein
Foren-Regeln
