Hallo Tiller,
Code:Config Keyboard = Pind.2 , Data = Pind.6 , Keydata = Keydata On Int0 Isr0 Enable Int0 Config Int0 = Falling Enable Interrupts Do 'tu was geniales... Loop '--------------------------------------------------------------------------- ' Isr0 ' Interruptroutine für die Tastatur ' der externe Interrupt 0 überwacht die Dataleitung der Tastatur '--------------------------------------------------------------------------- Isr0: 'interrupt routine Taste = Getatkbd() Select Case Taste Case 13: 'Entertaste Case Else: If Taste <> 0 Then 'tu was geniales... End If End Select Set Gifr.intf0 Taste = 0 Return
Zitieren
