also ich arbeite in Zusammenhang mit RS232 immer mit dieser Routine
ich frage den Puffer direkt über die Variable rx_counter abCode:#define RXB8 1 #define TXB8 0 #define UPE 2 #define OVR 3 #define FE 4 #define UDRE 5 #define RXC 7 #define FRAMING_ERROR (1<<FE) #define PARITY_ERROR (1<<UPE) #define DATA_OVERRUN (1<<OVR) #define DATA_REGISTER_EMPTY (1<<UDRE) #define RX_COMPLETE (1<<RXC) // USART Receiver buffer #define RX_BUFFER_SIZE 8 char rx_buffer[RX_BUFFER_SIZE]; #if RX_BUFFER_SIZE<256 unsigned char rx_wr_index,rx_rd_index,rx_counter; #else unsigned int rx_wr_index,rx_rd_index,rx_counter; #endif // This flag is set on USART Receiver buffer overflow bit rx_buffer_overflow; // USART Receiver interrupt service routine interrupt [USART_RXC] void usart_rx_isr(void) { char status,data; status=UCSRA; data=UDR; if ((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN))==0) { rx_buffer[rx_wr_index]=data; if (++rx_wr_index == RX_BUFFER_SIZE) rx_wr_index=0; if (++rx_counter == RX_BUFFER_SIZE) { rx_counter=0; rx_buffer_overflow=1; }; }; } #ifndef _DEBUG_TERMINAL_IO_ // Get a character from the USART Receiver buffer #define _ALTERNATE_GETCHAR_ #pragma used+ char getchar(void) { char data; while (rx_counter==0); data=rx_buffer[rx_rd_index]; if (++rx_rd_index == RX_BUFFER_SIZE) rx_rd_index=0; #asm("cli") --rx_counter; #asm("sei") return data; } #pragma used- #endif // USART Transmitter buffer #define TX_BUFFER_SIZE 8 char tx_buffer[TX_BUFFER_SIZE]; #if TX_BUFFER_SIZE<256 unsigned char tx_wr_index,tx_rd_index,tx_counter; #else unsigned int tx_wr_index,tx_rd_index,tx_counter; #endif // USART Transmitter interrupt service routine interrupt [USART_TXC] void usart_tx_isr(void) { if (tx_counter) { --tx_counter; UDR=tx_buffer[tx_rd_index]; if (++tx_rd_index == TX_BUFFER_SIZE) tx_rd_index=0; }; } #ifndef _DEBUG_TERMINAL_IO_ // Write a character to the USART Transmitter buffer #define _ALTERNATE_PUTCHAR_ #pragma used+ void putchar(char c) { while (tx_counter == TX_BUFFER_SIZE); #asm("cli") if (tx_counter || ((UCSRA & DATA_REGISTER_EMPTY)==0)) { tx_buffer[tx_wr_index]=c; if (++tx_wr_index == TX_BUFFER_SIZE) tx_wr_index=0; ++tx_counter; } else UDR=c; #asm("sei") } #pragma used- #endif
das ist der Quellcode der automatisch erzeugt wird wenn man bei CodevisionAVR mit dem CVodeVizzard arbeitet und man die Einstelungen für die Schnittstelle macht (funktioniert nur mit der Vollversion, haben in der Schule damit gearbeitet)...Code:if(rx_counter>0) //rx_counter ist immer dann größer 0 wenn Zeichen im Puffer vorhanden sind { myVariable=getchar();//wenn Zeichen über RS232 empfangen wird Zeichen in cZeichenEmpfangen gespeichert switch (myVariable) //je nachdem welches Zeichen empfangen wird, führe Anweisung aus { case 'A': ... break; case 'B': break; default; }
vielleicht hilft dir das ja...
Gruß Pierce
Zitieren
