Thema: Variablen index (0) ???
    Hallo, ist es in Bascom nicht möglich, eine Variable z.b. von 0 bis 7 zu dimensionieren ??????
    Also z.b.
    Dim Pwm(7) as Byte
    Pwm(0) = 255
    Pwm(1) = 255
    Aarau
    Auszug aus der Bascom Hilfe:
    Arrays
    An array is a set of sequentially indexed elements having the same type. Each element of an array has a unique index number that identifies it. Changes made to an element of an array do not affect the other elements.
    The index must be a numeric constant, a byte, an integer, word or long.
    The maximum number of elements is 65535.
    The first element of an array is always one. This means that elements are 1-based.
    Arrays can be used on each place where a 'normal' variable is expected.
    Das heisst dein PWM Array geht von 1-7
    gruss bluesmash
    Schade, von 0-7 wäre einfacher......naja. Danke !!!
