@ Mobius
Deine Routine funktioniert hab sie mal geschrieben um sie fuer meine Anwedung zu testen.
Nochmal DankeCode:list p=16f873 ; list directive to define processor #include <p16f873.inc> ; processor specific variable definitions __CONFIG _CP_OFF & _WDT_ON & _BODEN_ON & _PWRTE_ON & _RC_OSC & _WRT_ENABLE_ON & _LVP_ON & _CPD_OFF ; '__CONFIG' directive is used to embed configuration data within .asm file. ; The lables following the directive are located in the respective .inc file. ; See respective data sheet for additional information on configuration word. ;***** VARIABLE DEFINITIONS w_temp EQU 0x20 ; variable used for context saving status_temp EQU 0x21 ; variable used for context saving AD1 EQU 0x22 AD2 EQU 0x23 DA10 EQU 0x26 DA11 EQU 0x27 PIX_COUNT EQU 0x2F TEST_PORTA EQU 0x30 TEST_PORTB EQU 0x31 ;********************************************************************** ORG 0x000 ; processor reset vector clrf PCLATH ; ensure page bits are cleared goto main ; go to beginning of program ;Initialisierung ini movlw 0x6F movwf DA10 movlw 0x1C movwf DA11 return main call ini ;Die Routine ist nur zum Test geschrieben ist nicht die eigenliche Routine ;ansonsten laesst sich sowas auch einfacher schreiben start incf PIX_COUNT movf PIX_COUNT,w addlw 0x21 movwf FSR movlw 0x26 movwf INDF movf PIX_COUNT,w addlw 0x21 movwf FSR movf INDF,w movwf FSR movf INDF,w movwf TEST_PORTA incf FSR movf INDF,w movwf TEST_PORTB nop nop nop END ; directive 'end of program'
Zitieren
