warum kompliziert, wenns auch einfach geht ...
Mein RGY-Laser reagiert auf folgendes Progrämmchen
einwandfrei:
Code:$regfile = "m8def.dat" $crystal = 16000000 $hwstack = 30 ' default use 32 for the hardware stack $swstack = 50 ' default use 10 for the SW stack $framesize = 50 $baud = 250000 Config Com1 = Dummy , Synchrone = 0 , Parity = None , Stopbits = 2 , Databits = 8 Dim A_byte(16) As Byte Led Alias Portd.7 Config Led = Output Uart_tx Alias Portd.1 Config Uart_tx = Output 485_rw Alias Portd.4 Config 485_rw = Output 485_rw = 1 A_byte(1) = 50 A_byte(2) = 130 A_byte(3) = 250 A_byte(4) = 63 A_byte(5) = 63 A_byte(6) = 0 A_byte(7) = 0 A_byte(8) = 255 A_byte(9) = 10 A_byte(10) = 255 A_byte(11) = 128 A_byte(12) = 120 Do Ucsrb = Ucsrb And &B11100111 ' UART deaktivieren Reset Uart_tx ' break setzen Waitus 95 Set Uart_tx Ucsrb = Ucsrb Or &B00011000 ' UART reaktivieren Waitus 22 Printbin A_byte(1) ; 16 ' Daten senden Toggle Led Waitms 100 Loop
Zitieren
