der ganze code passte nicht, deswegen hier der rest
MfGCode:'######## Anzeige ################################ Sub Anzeige Select Case Auswahl(1) 'Ebene 1 Case 0 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 1 Ebene3 = 1 Case 1 X1 = 1 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 0 Ebene2 = 1 Ebene3 = 1 Case 2 X1 = 0 X2 = 1 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 0 Ebene2 = 1 Ebene3 = 1 Case 3 X1 = 0 X2 = 0 X3 = 1 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 0 Ebene2 = 1 Ebene3 = 1 Case 4 X1 = 0 X2 = 0 X3 = 0 X4 = 1 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 0 Ebene2 = 1 Ebene3 = 1 Case 5 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 1 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 0 Ebene2 = 1 Ebene3 = 1 Case 6 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 1 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 0 Ebene2 = 1 Ebene3 = 1 Case 7 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 1 X8 = 0 X9 = 0 Ebene1 = 0 Ebene2 = 1 Ebene3 = 1 Case 8 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 1 X9 = 0 Ebene1 = 0 Ebene2 = 1 Ebene3 = 1 Case 9 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 1 Ebene1 = 0 Ebene2 = 1 Ebene3 = 1 'Ebene 2------------------------------------------ Case 10 Leds = &B0000110000000001 X1 = 1 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 0 Ebene3 = 1 Case 11 Leds = &B0000110000000010 X1 = 0 X2 = 1 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 0 Ebene3 = 1 Case 12 Leds = &B0000110000000100 X1 = 0 X2 = 0 X3 = 1 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 0 Ebene3 = 1 Case 13 Leds = &B0000110000001000 X1 = 0 X2 = 0 X3 = 0 X4 = 1 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 0 Ebene3 = 1 Case 14 Leds = &B0000110000010000 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 1 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 0 Ebene3 = 1 Case 15 Leds = &B0000110000100000 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 1 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 0 Ebene3 = 1 Case 16 Leds = &B0000110001000000 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 1 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 0 Ebene3 = 1 Case 17 Leds = &B0000110010000000 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 1 X9 = 0 Ebene1 = 1 Ebene2 = 0 Ebene3 = 1 Case 18 Leds = &B0000110100000000 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 1 Ebene1 = 1 Ebene2 = 0 Ebene3 = 1 'Ebene 3------------------------------------------ Case 19 Leds = &B0000110000000001 X1 = 1 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 1 Ebene3 = 0 Case 20 Leds = &B0000110000000010 X1 = 0 X2 = 1 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 1 Ebene3 = 0 Case 21 Leds = &B0000110000000100 X1 = 0 X2 = 0 X3 = 1 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 1 Ebene3 = 0 Case 22 Leds = &B0000110000001000 X1 = 0 X2 = 0 X3 = 0 X4 = 1 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 1 Ebene3 = 0 Case 23 Leds = &B0000110000010000 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 1 X6 = 0 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 1 Ebene3 = 0 Case 24 Leds = &B0000110000100000 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 1 X7 = 0 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 1 Ebene3 = 0 Case 25 Leds = &B0000110001000000 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 1 X8 = 0 X9 = 0 Ebene1 = 1 Ebene2 = 1 Ebene3 = 0 Case 26 Leds = &B0000110010000000 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 1 X9 = 0 Ebene1 = 1 Ebene2 = 1 Ebene3 = 0 Case 27 Leds = &B0000110100000000 X1 = 0 X2 = 0 X3 = 0 X4 = 0 X5 = 0 X6 = 0 X7 = 0 X8 = 0 X9 = 1 Ebene1 = 1 Ebene2 = 1 Ebene3 = 0 End Select End Sub '----------------------------------- Sub Schalten X1 = Leds.0 X2 = Leds.1 X3 = Leds.2 X4 = Leds.3 X5 = Leds.4 X6 = Leds.5 X7 = Leds.6 X8 = Leds.7 X9 = Leds.8 Ebene1 = Leds.9 Ebene2 = Leds.10 Ebene3 = Leds.11 End Sub '------------------------------------- Sub Zufall() A: Ladewert = Rnd(6000) If Ladewert <= 1000 Then Goto A Toggle Ledgelb End Sub '-------------------------------------- '-------------------------------------- Systemtakt: Status.0 = 1 'timer bit setzen Load Timer1 , Ladewert Toggle Ledrot Return
mycroc
Zitieren
