Ergebnis 1 bis 8 von 8
Thema: Interrupt löst nicht zuverlässig aus
    Kagerer
    ich hab ein Problem mit dem Interrupt an einem ATMega16. Und zwar hab ich einen Taster an Int0 angeschlossen. Der Controller löst aber nicht zuverlässig die Interrupt-Routine aus, wenn ich den Taster betätige.
    Hier mal der Code:
    #include <avr/io.h>
    #include <util/delay.h>
    #include <avr/interrupt.h>
    // Ports initialisieren
    void port_init()
    	// Alle Pins  bis auf PD2 & PD3 als Ausgang schalten
    	DDRA = 0xff;
    	DDRB = 0xff;
    	DDRC = 0xff;
    	DDRD = 0b11110011;
    	//Pullup-Widerstand von PD2 aktivieren
    	PORTD |= (1<<PD2);
    	// Interrupt vorbereiten
    	MCUCR |= (1 << ISC01); // INT0 läst bei fallender Flanke aus
    	GICR |= (1 << INT0); // INT0 aktivieren
    // Funktion zum Einschalten der LEDs
    void led_on(uint8_t led)
    	if(led == 1) PORTA |= (1 << PA3);
    	if(led == 2) PORTB |= (1 << PB4);
    	if(led == 3) PORTA |= (1 << PA2);
    	if(led == 4) PORTD |= (1 << PD0);
    	if(led == 5) PORTC |= (1 << PC5);
    	if(led == 6) PORTB |= (1 << PB7);
    	if(led == 7) PORTC |= (1 << PC6);
    	if(led == 8) PORTB |= (1 << PB6);
    	if(led == 9) PORTC |= (1 << PC7);
    	if(led == 10) PORTB |= (1 << PB5);
    	if(led == 11) PORTA |= (1 << PA5);
    	if(led == 12) PORTA |= (1 << PA4);
    	if(led == 13) PORTB |= (1 << PB3);
    	if(led == 14) PORTA |= (1 << PA1);
    	if(led == 15) PORTB |= (1 << PB2);
    	if(led == 16) PORTA |= (1 << PA7);
    	if(led == 17) PORTB |= (1 << PB1);
    	if(led == 18) PORTA |= (1 << PA6);
    	if(led == 19) PORTB |= (1 << PB0);
    	if(led == 20) PORTA |= (1 << PA0);
    	if(led == 21) PORTD |= (1 << PD6);
    	if(led == 22) PORTC |= (1 << PC0);
    	if(led == 23) PORTD |= (1 << PD7);
    	if(led == 24) PORTC |= (1 << PC4);
    	if(led == 25) PORTD |= (1 << PD1);
    	if(led == 26) PORTC |= (1 << PC3);
    	if(led == 27) PORTD |= (1 << PD4);
    	if(led == 28) PORTC |= (1 << PC2);
    	if(led == 29) PORTD |= (1 << PD5);
    	if(led == 30) PORTC |= (1 << PC1);
    // Funktion zum Ausschalten der LEDs
    void led_off(uint8_t led)
    	if(led == 1) PORTA &= ~(1 << PA3);
    	if(led == 2) PORTB &= ~(1 << PB4);
    	if(led == 3) PORTA &= ~(1 << PA2);
    	if(led == 4) PORTD &= ~(1 << PD0);
    	if(led == 5) PORTC &= ~(1 << PC5);
    	if(led == 6) PORTB &= ~(1 << PB7);
    	if(led == 7) PORTC &= ~(1 << PC6);
    	if(led == 8) PORTB &= ~(1 << PB6);
    	if(led == 9) PORTC &= ~(1 << PC7);
    	if(led == 10) PORTB &= ~(1 << PB5);
    	if(led == 11) PORTA &= ~(1 << PA5);
    	if(led == 12) PORTA &= ~(1 << PA4);
    	if(led == 13) PORTB &= ~(1 << PB3);
    	if(led == 14) PORTA &= ~(1 << PA1);
    	if(led == 15) PORTB &= ~(1 << PB2);
    	if(led == 16) PORTA &= ~(1 << PA7);
    	if(led == 17) PORTB &= ~(1 << PB1);
    	if(led == 18) PORTA &= ~(1 << PA6);
    	if(led == 19) PORTB &= ~(1 << PB0);
    	if(led == 20) PORTA &= ~(1 << PA0);
    	if(led == 21) PORTD &= ~(1 << PD6);
    	if(led == 22) PORTC &= ~(1 << PC0);
    	if(led == 23) PORTD &= ~(1 << PD7);
    	if(led == 24) PORTC &= ~(1 << PC4);
    	if(led == 25) PORTD &= ~(1 << PD1);
    	if(led == 26) PORTC &= ~(1 << PC3);
    	if(led == 27) PORTD &= ~(1 << PD4);
    	if(led == 28) PORTC &= ~(1 << PC2);
    	if(led == 29) PORTD &= ~(1 << PD5);
    	if(led == 30) PORTC &= ~(1 << PC1);
    // Programmcounter
    volatile uint8_t progcounter = 0;
    // INT0
    ISR(INT0_vect) {
        if(progcounter < 3) progcounter++;
    	else progcounter = 1;
    // Hauptprogramm
    int main()
    	port_init();
    	// Interrupts global aktivieren
    	sei();
    	// Endlosschleife
    	while(1){
    	if(progcounter == 1) led_on(30);
    	if(progcounter == 2) led_off(30);
    return(0);
    Ich hoffe, dass mir jemand bei meinem Problem weiterhelfen kann.
    Christian
    weit weg von nahe Bonn
    meinst du, das er manchmal reagiert und manchmal nicht ?
    ein taster prellt meist, kann doch sein das du 2, 4, 6, 8 oder ein höheres vielfaches von 2 lowflanken hast während du auf den taster drückst.
    versuche mal statt auf eine flanke zu warten auf ein level zu warten, das könnte ETWAS stabiler sein, ansonsten den taster entprellen
    EDIT: wenn du 2 - 8 Flanken hast musst du nicht unbedingt das superkurze flackern der LED bemerken, dazu ist der sehsinn meist zu langsam
    EDITEDIT inkrementier bei jedem interrupt doch ... kA das PORTA Register
    also
    ISR()
      PORTA++;
    dann kannst du mitzählen wie oft die ISR aufgerufen wird bis zu 255 mal ^^
    An der Saar
    Vermutlich gehen die IRQs, aber wegen fehlender Entprellung des Tasters werden mehr als 1 Flanke pro Druck ausgelöst.
    Zudem fehlt ein Teil der Initialisierung, weil du zB mit
    nur 1 Bit auf 1 setzt (es muss noch ein Bit auf 0 gesetzt werden). Weiß jetzt net, wie das SFR beim Reset initialisiert wird, aber sauber ist sowas net.
    Disclaimer: none. Sue me.
    statt zu ODERN würd ich auch an deiner stelle das gesammte register in einem zug programmieren, sonst löst dein ISR eventuell zu früh aus wenn du mehrere operationen hintereinander ausführst, dann musst du das ISC00 nicht nachträglich auf 0 schreiben, da muss ich sprinter zustimmen
    Kagerer
    Erst mal danke für eure schnellen Antworten.
    Ja genau.
    Ich hab parallel zum Taster einen 47nF Kondensator geschalten der sollte doch eigenltich reichen um das Prellen zu verhindern. Hab ich nur vergessen zum schreiben.
    Werd ich dann gleich mal auf "MCUCR = 0b00000010;" ausbessern.
    Kagerer
    Also ich hab es jetzt mit den Interrupts aufgegeben. Ich frag den Taster nun mittels Polling ab und das funktioniert wie gewünscht.
    interrupts kann man doch auch auf PEGEL einstellen also nicht reagieren auf flanke sonder wenn ein bestimmter PEGEL anliegt, versuchs damit mal!
    Kagerer
    Habe ich schon versucht. Brachte aber keine Verbesserung.
