Ergebnis 1 bis 6 von 6
Thema: RP6Loader streikt!
Baum-Darstellung
    RP6Loader streikt!
    meine Fehlermeldung die ich erhalte, wenn ich den rp6loader starten will
    was kann ich dagegen tun?
    Jemand ne Idee?
    RP6Loader log file
    SystemLogger started at: Thu Apr 10 12:25:07 CEST 2008 (1207823107881)
    JVM System Information:
    java.runtime.name	=	Java(TM) SE Runtime Environment
    sun.boot.library.path	=	C:\Programme\Java\jre1.6.0_05\bin
    java.vm.version	=	10.0-b19
    java.vm.vendor	=	Sun Microsystems Inc.
    java.vendor.url	=	http://java.sun.com/
    path.separator	=	;
    java.vm.name	=	Java HotSpot(TM) Client VM
    file.encoding.pkg	=	sun.io
    sun.java.launcher	=	SUN_STANDARD
    user.country	=	DE
    sun.os.patch.level	=	Service Pack 2
    java.vm.specification.name	=	Java Virtual Machine Specification
    user.dir	=	C:\RP6Loader
    java.runtime.version	=	1.6.0_05-b13
    java.awt.graphicsenv	=	sun.awt.Win32GraphicsEnvironment
    java.endorsed.dirs	=	C:\Programme\Java\jre1.6.0_05\lib\endorsed
    os.arch	=	x86
    java.io.tmpdir	=	C:\DOKUME~1\ANTIVA~1\LOKALE~1\Temp\
    line.separator	=
    java.vm.specification.vendor	=	Sun Microsystems Inc.
    user.variant	=
    os.name	=	Windows XP
    sun.jnu.encoding	=	Cp1252
    java.library.path	=	C:\WinAVR-20071221\bin;C:\WinAVR-20071221\utils\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;\bin;.\lib
    java.specification.name	=	Java Platform API Specification
    java.class.version	=	50.0
    sun.management.compiler	=	HotSpot Client Compiler
    os.version	=	5.1
    user.home	=	C:\Dokumente und Einstellungen\antivalent
    user.timezone	=	Europe/Berlin
    java.awt.printerjob	=	sun.awt.windows.WPrinterJob
    file.encoding	=	Cp1252
    java.specification.version	=	1.6
    java.class.path	=	C:\RP6Loader\RP6Loader_lib.jar
    user.name	=	antivalent
    java.vm.specification.version	=	1.0
    java.home	=	C:\Programme\Java\jre1.6.0_05
    sun.arch.data.model	=	32
    user.language	=	de
    java.specification.vendor	=	Sun Microsystems Inc.
    awt.toolkit	=	sun.awt.windows.WToolkit
    java.vm.info	=	mixed mode, sharing
    java.version	=	1.6.0_05
    java.ext.dirs	=	C:\Programme\Java\jre1.6.0_05\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
    sun.boot.class.path	=	C:\Programme\Java\jre1.6.0_05\lib\resources.jar;C:\Programme\Java\jre1.6.0_05\lib\rt.jar;C:\Programme\Java\jre1.6.0_05\lib\sunrsasign.jar;C:\Programme\Java\jre1.6.0_05\lib\jsse.jar;C:\Programme\Java\jre1.6.0_05\lib\jce.jar;C:\Programme\Java\jre1.6.0_05\lib\charsets.jar;C:\Programme\Java\jre1.6.0_05\classes
    java.vendor	=	Sun Microsystems Inc.
    file.separator	=	\
    java.vendor.url.bug	=	http://java.sun.com/cgi-bin/bugreport.cgi
    sun.io.unicode.encoding	=	UnicodeLittle
    sun.cpu.endian	=	little
    sun.desktop	=	windows
    sun.cpu.isalist	=	pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
    JVM Memory Information:
    Free: 4149880 (4052 Kb)
    Max: 66650112 (65088 Kb)
    Total: 5177344 (5056 Kb)
    Global->Init
    RP6Loader Version: 1.1c
    Last build: 25.05.2007
    Global->loadConfig
    Global->loadLocalizedText
    Global->loadBoardLibrary
    Linkage error (Thu Apr 10 12:25:08 CEST 2008) : Could not load D2XX libraries!
    Is the driver installed properly and the correct JD2XX.dll file in the RP6Loader ./lib folder?
    java.lang.UnsatisfiedLinkError: C:\RP6Loader\lib\JD2XX.dll: Can't find dependent libraries
    	at java.lang.ClassLoader$NativeLibrary.load(Native Method)
    	at java.lang.ClassLoader.loadLibrary0(Unknown Source)
    	at java.lang.ClassLoader.loadLibrary(Unknown Source)
    	at java.lang.Runtime.loadLibrary0(Unknown Source)
    	at java.lang.System.loadLibrary(Unknown Source)
    	at jd2xx.JD2XX.<clinit>(JD2XX.java:534)
    	at cls.c.<init>(Unknown Source)
    	at cls.Y.e(Unknown Source)
    	at cls.Y.<init>(Unknown Source)
    	at de.dsh.rp6loader.Init.<init>(Unknown Source)
    	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
    	at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
    	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
    	at java.lang.reflect.Constructor.newInstance(Unknown Source)
    	at java.lang.Class.newInstance0(Unknown Source)
    	at java.lang.Class.newInstance(Unknown Source)
    	at de.dsh.rp6loader.Init.main(Unknown Source)
    ERROR (43)  ||| Loading D2XX Drivers failed!
    See RP6Loader_logfile.log for more details!
    RP6Loader will now try to use Comport mode!
    Loading D2XX Drivers failed! --> Trying to use RXTX instead!
    OS:W32
    Initializing native communication library: JD2XX
    Stable Library
    Native lib Version = RXTX-2.1-7
    Java lib Version   = RXTX-2.1-7
    TERMINAL: RP6Loader Terminal
    TERMINAL:  - type ".help" for command list!
    Global->loadFileList
    Global->Enabling log panel...
    RP6 Loader is ready to go.
