was haltet Ihr den hiervon ?
kostet 60 Euro mit Versand!
The new design for the T8435: the 4 axis T8435 Stepper motor driver . In adaption of the prono position 8435 chip , we install the larger thermal sink in the bottom ,and adapt the FR307 heavy current diode. The new design of the wire-connection and the pin-insert , this two-way input design makes the connection more convenient.The semi-flow uses the 555 chip. Description:
* chip 555 adapts the SOP( SURFACE MOUNT)
* In application of the SMT solder-reflow technic.
* add the 24V and 5V indication LED light
* use the DCDC as the isolation of the front and the end power supplys, in order to protect the parallel ports
* the mannuel control connector and the limit connector use the DB15 and DB9 connection port
* support the relay extension
* can extend the 5th axis
* the 5V controlling power supply is separated with the 12-36V driving power supply
Download Manual
http://www.cnc-in.cn/pdf/4%20Axis%20...er%20board.pdf
Packing list:
* the board T8435 1 piece
* the parallel wire 1 piece
* the 5V power supply 1 piece
the currrent of this board is 1.8A.
oder
40V/3.0A
3 Axis CNC Router or Mill Stepper Motor Driver
Artikelnummer: 110345998453
130 Euro mit Versand
oder
60V/5.0A
CNC 3 Axis Stepper motor Driver ROUTER,MILL , Artikelnummer: 120372438390
160 Euro mit Versand
gefunden bei 3.2.1.
Zitieren
