In Bascome Hilfe habe ich diesen Code gefunden, aber zur Zeile "Config Atemu =..." gib es die Fehlermeldung "Library file not found"
Code:$lib "mcsbyteint.lbx" ' use optional lib since we use only bytes 'configure PS2 AT pins Enable Interrupts ' you need to turn on interrupts yourself since an INT is used Config Atemu = Int1 , Data = Pind.3 , Clock = Pinb.0 ' ^------------------------ used interrupt ' ^----------- pin connected to DATA ' ^-- pin connected to clock 'Note that the DATA must be connected to the used interrupt pin Waitms 500 ' optional delay 'rcall _AT_KBD_INIT Print "Press t for test, and set focus to the editor window" Dim Key2 As Byte , Key As Byte Do Key2 = Waitkey() ' get key from terminal Select Case Key2 Case "t" : Waitms 1500 Sendscankbd Mark ' send a scan code Case Else End Select Loop Print Hex(key) Mark: ' send mark Data 12 , &H3A , &HF0 , &H3A , &H1C , &HF0 , &H1C , &H2D , &HF0 , &H2D , &H42 , &HF0 , &H42 ' ^ send 12 bytes ' m a r k
Zitieren
