Thema: WinAVR compiler error
    Minneapolis
    I upgraded to Asuor Lib ver 2.7.1 and the WinAVR ver 20071221.
    Now I´m getting the following error message when I try to compile a project (see code section).
    -------- begin --------
    avr-gcc --version
    avr-gcc (GCC) 4.2.2 (WinAVR 20071221)
    Copyright (C) 2007 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    make.exe: *** No rule to make target `test.hex', needed by `all'.  Stop.
    > Process Exit Code: 2
    > Time Taken: 00:00
    The make clean functions just fine.
    Any idea what I´m missing here?
    Thanks
    Geislingen a. d. Steige
    hi irobot_22587,
    No rule to make target means that their is no makefile.
    MfG Martin
    Minneapolis
    ich habe jedoch das makefile in dem selben directory wie die C-Datei. Erwartet PN das Makefile anderswo?
    Minneapolis
    Jetzt habe ich ein weiteres Problem mit AVR Studio compiler.
    Hier ist die Fehlermeldung:
    Build started 13.1.2008 at 14:43:21
    avr-gcc.exe -I"C:\Dokumente und Einstellungen\Petersen.PN15\Eigene Dateien\Volker\ProgramCode\ASURO_SRC\MotorTest\..\..\..\..\..\..\..\Programme\WinAVR\AsuroLIB\lib\inc"  -mmcu=atmega128 -Wall -gdwarf-2  -O0 -fsigned-char -MD -MP -MT MotorTest.o -MF dep/Mo
    torTest.o.d  -c  ../MotorTest.c
    ../MotorTest.c: In function 'testfahrt':
    ../MotorTest.c:28: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness
    ../MotorTest.c: In function 'main':
    ../MotorTest.c:68: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness
    ../MotorTest.c:74: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness
    ../MotorTest.c:80: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness
    avr-gcc.exe -I"C:\Dokumente und Einstellungen\Petersen.PN15\Eigene Dateien\Volker\ProgramCode\ASURO_SRC\MotorTest\..\..\..\..\..\..\..\Programme\WinAVR\AsuroLIB\lib\inc"  -mmcu=atmega128 -Wall -gdwarf-2  -O0 -fsigned-char -MD -MP -MT asuro.o -MF dep/asuro.
    o.d  -c  ../../../../../../../../Programme/WinAVR/AsuroLIB/lib/asuro.c
    ../../../../../../../../Programme/WinAVR/AsuroLIB/lib/asuro.c: In function 'Init':
    ../../../../../../../../Programme/WinAVR/AsuroLIB/lib/asuro.c:133: error: 'UCSRA' undeclared (first use in this function)
    ../../../../../../../../Programme/WinAVR/AsuroLIB/lib/asuro.c:133: error: (Each undeclared identifier is reported only once
    ../../../../../../../../Programme/WinAVR/AsuroLIB/lib/asuro.c:133: error: for each function it appears in.)
    ../../../../../../../../Programme/WinAVR/AsuroLIB/lib/asuro.c:134: error: 'UCSRB' undeclared (first use in this function)
    ../../../../../../../../Programme/WinAVR/AsuroLIB/lib/asuro.c:135: error: 'UCSRC' undeclared (first use in this function)
    ../../../../../../../../Programme/WinAVR/AsuroLIB/lib/asuro.c:136: error: 'UBRRL' undeclared (first use in this function)
    ../../../../../../../../Programme/WinAVR/AsuroLIB/lib/asuro.c: In function '__vector_2':
    ../../../../../../../../Programme/WinAVR/AsuroLIB/lib/asuro.c:252: error: 'GICR' undeclared (first use in this function)
    make: *** [asuro.o] Error 1
    Build failed with 7 errors and 4 warnings...
    Wo werden die Variablen UCSRA, UCSRB, etc. declariert? Welche .h Datei vermisse ich?
    Gruss,
    vp
    Hi irobot,
    versuch dein projekt nicht in den Eigenen Dateien zu compilieren sonder z.B. in C:\Asuro\projektname denn WinAVR macht probleme bei ordner namen mit Leer zeichen (C:\Dokumente und Einstellungen\Petersen.PN15\Eigene Dateien\)
    MfG Martin
