In dem Programm stimmt noch was nicht, make all gibt mir folgendes aus:
RP6Base_hinundher.c: In function 'Batt':
RP6Base_hinundher.c:33: error: expected '(' before '{' token
RP6Base_hinundher.c:80: warning: 'main' is normally a non-static function
RP6Base_hinundher.c:92:3: warning: no newline at end of file
RP6Base_hinundher.c:92: error: expected declaration or statement at end of input
make: *** [RP6Base_hinundher.o] Fehler 1
ich bin dankbar für jede hilfe MfG carlitocoCode:// Cruise Behaviour: #include "RP6RobotBaseLib.h" #define IDLE 0 #define TURN_SPEED 50 #define MOVE_SPEED 100 #define MOVE_FORWARDS 1 void behaviour_cruise(void) { uint8_t turn_direction = LEFT; { setLEDs(0b100100); move(MOVE_SPEED, FWD, DIST_MM(2000), BLOCKING); rotate(TURN_SPEED, turn_direction, 102, BLOCKING); move(MOVE_SPEED, FWD, DIST_MM(100), BLOCKING); rotate(TURN_SPEED, turn_direction, 102, BLOCKING); move(MOVE_SPEED, FWD, DIST_MM(2000), BLOCKING); rotate(TURN_SPEED, RIGHT, 102, BLOCKING); move(MOVE_SPEED, FWD, DIST_MM(100), BLOCKING); rotate(TURN_SPEED, RIGHT, 102, BLOCKING); } // akku_load: void Batt(void) { uint16_t ubat setStopwatch1(400); { while { startStopwatch1(); if(getStopwatch1() > 300) { writeString_P("\nADC Akku: Voll"); writeInteger(adcBat, DEC); writeChar('\n'); if(adcBat > 900) { setLEDs(0b001001); writeString_P("\nADC Akku: >9V"); } else if(adcBat < 901 && adcBat > 800) { writeString_P("\nADC Akku: >8V"); statusLEDs.LED4 = !statusLEDs.LED4; statusLEDs.LED1 = !statusLEDs.LED1; updateStatusLEDs(); } else if(adcBat < 801 && adcBat > 700) { setLEDs(0b000001); writeString_P("\nADC Akku: >7V"); } else if(adcBat < 701 && adcBat > 590) { statusLEDs.LED1 = !statusLEDs.LED1; updateStatusLEDs(); writeString_P("\nADC Akku: Leer"); } else if(adcBat < 591 && adcBat > 500) { writeString_P("\nADC Akku: Laden!"); powerOFF(); } setStopwatch1(0); } } int main (void) { initRobotBase(); startStopwatch1(); powerON(); while(true) { task_ADC(); task_RP6System(); Batt(); behaviour_cruise(); } return 0; }
Zitieren
