also habe die neue version genommen.
kabel und so stecken auch alle.
batterien (neu) /bei vollen akkus war das gleiche
rp6 eingeschaltet, led machen das wie im manual beschrieben, gehn nach ca 25sek ganz aus.
loader gestartet port angewählt, connect -> log:
RP6Loader log file
SystemLogger started at: Mon Dec 17 19:24:27 GMT 2007 (1197919467454)
JVM System Information:
java.runtime.name	=	Java(TM) SE Runtime Environment
sun.boot.library.path	=	/usr/lib/jvm/java-6-sun-1.6.0.03/jre/lib/i386
java.vm.version	=	1.6.0_03-b05
java.vm.vendor	=	Sun Microsystems Inc.
java.vendor.url	=	http://java.sun.com/
path.separator	=	:
java.vm.name	=	Java HotSpot(TM) Server VM
file.encoding.pkg	=	sun.io
sun.java.launcher	=	SUN_STANDARD
user.country	=	DE
sun.os.patch.level	=	unknown
java.vm.specification.name	=	Java Virtual Machine Specification
user.dir	=	/home/axel/Desktop/loader
java.runtime.version	=	1.6.0_03-b05
java.awt.graphicsenv	=	sun.awt.X11GraphicsEnvironment
java.endorsed.dirs	=	/usr/lib/jvm/java-6-sun-1.6.0.03/jre/lib/endorsed
os.arch	=	i386
java.io.tmpdir	=	/tmp
line.separator	=
java.vm.specification.vendor	=	Sun Microsystems Inc.
os.name	=	Linux
sun.jnu.encoding	=	UTF-8
java.library.path	=	./lib
java.specification.name	=	Java Platform API Specification
java.class.version	=	50.0
sun.management.compiler	=	HotSpot Server Compiler
os.version	=	2.6.22-14-generic
user.home	=	/home/axel
user.timezone	=	GMT
java.awt.printerjob	=	sun.print.PSPrinterJob
file.encoding	=	UTF-8
java.specification.version	=	1.6
java.class.path	=	RP6Loader_lib.jar
user.name	=	axel
java.vm.specification.version	=	1.0
java.home	=	/usr/lib/jvm/java-6-sun-1.6.0.03/jre
sun.arch.data.model	=	32
user.language	=	de
java.specification.vendor	=	Sun Microsystems Inc.
java.vm.info	=	mixed mode
java.version	=	1.6.0_03
java.ext.dirs	=	/usr/lib/jvm/java-6-sun-1.6.0.03/jre/lib/ext:/usr/java/packages/lib/ext
sun.boot.class.path	=	/usr/lib/jvm/java-6-sun-1.6.0.03/jre/lib/resources.jar:/usr/lib/jvm/java-6-sun-1.6.0.03/jre/lib/rt.jar:/usr/lib/jvm/java-6-sun-1.6.0.03/jre/lib/sunrsasign.jar:/usr/lib/jvm/java-6-sun-1.6.0.03/jre/lib/jsse.jar:/usr/lib/jvm/java-6-sun-1.6.0.03/jre/lib/jce.jar:/usr/lib/jvm/java-6-sun-1.6.0.03/jre/lib/charsets.jar:/usr/lib/jvm/java-6-sun-1.6.0.03/jre/classes
java.vendor	=	Sun Microsystems Inc.
file.separator	=	/
java.vendor.url.bug	=	http://java.sun.com/cgi-bin/bugreport.cgi
sun.io.unicode.encoding	=	UnicodeLittle
sun.cpu.endian	=	little
sun.desktop	=	gnome
sun.cpu.isalist	=
JVM Memory Information:
Free: 30913968 (30189 Kb)
Max: 512950272 (500928 Kb)
Total: 33226752 (32448 Kb)
Initializing...
RP6Loader Version: 1.4 - BETA
Last build: 17.12.2007
Loading Configuration...
Done!
Global->loadLocalizedText
Loading Board Library...
Done!
OS:LINUX
Initializing native communication library: RXTX
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version   = RXTX-2.1-7
TERMINAL: RP6Loader Terminal
TERMINAL:  - type ".help" for command list!
Loading File List...
Done!
Global->Enabling log panel...
RP6 Loader is ready to go.
ACTIVE: WINDOW_ACTIVATED,opposite=null,oldState=0,newState=0 -- java.awt.event.WindowEvent[WINDOW_ACTIVATED,opposite=null,oldState=0,newState=0] on frame0 -- 0
Message (Mon Dec 17 19:24:31 GMT 2007) : RP6Main.actionPerformed: CONNECT
Trying to open port: /dev/ttyUSB0
Portlist: /dev/ttyUSB0, owned by: null, type: 1
/dev/ttyUSB0 open @38400-8n1
Baudrate is set to: 38400
Try to get ID...
ERROR (1)  ||| Timeout: The target has not responded!
Are you sure the cable is properly connected and target has power?
ACTIVE: WINDOW_ACTIVATED,opposite=javax.swing.JDialog[dialog0,395,313,489x153,hidden,layout=java.awt.BorderLayout,APPLICATION_MODAL,title=ERROR (1),defaultCloseOperation=HIDE_ON_CLOSE,rootPane=javax.swing.JRootPane[,0,0,489x153,layout=cls.aK,alignmentX=0.0,alignmentY=0.0,border=cls.ax@c550,flags=16777673,maximumSize=,minimumSize=,preferredSize=],rootPaneCheckingEnabled=true],oldState=0,newState=0 -- java.awt.event.WindowEvent[WINDOW_ACTIVATED,opposite=javax.swing.JDialog[dialog0,395,313,489x153,hidden,layout=java.awt.BorderLayout,APPLICATION_MODAL,title=ERROR (1),defaultCloseOperation=HIDE_ON_CLOSE,rootPane=javax.swing.JRootPane[,0,0,489x153,layout=cls.aK,alignmentX=0.0,alignmentY=0.0,border=cls.ax@c550,flags=16777673,maximumSize=,minimumSize=,preferredSize=],rootPaneCheckingEnabled=true],oldState=0,newState=0] on frame0 -- 0
DEICON: WINDOW_DEICONIFIED,opposite=null,oldState=0,newState=0 -- java.awt.event.WindowEvent[WINDOW_DEICONIFIED,opposite=null,oldState=0,newState=0] on frame0 -- 0
Message (Mon Dec 17 19:29:14 GMT 2007) : RP6LoaderGUI.windowClosing: WINDOW_CLOSING,opposite=null,oldState=0,newState=0
Saving File List...
Done!
Saving configuration...
Done!
Free: 28794768 (28119 Kb)
Total: 42663936 (41664 Kb)
Comport: Try to close...
Attempting to close port: /dev/ttyUSB0
Comport: Closed!
Program terminated! (1197919754672)
wenn ich jetzt die Start/Stop Taste drücke passiert das gleiche wie nach dem einschalten (Gelbe LED kurz , 2 rote kurz , 1 rote blinkt grüne leuchtet)
MfG und Danke für die schnelle Hilfe Axel
EDIT: Terminal schweigt sich aus...
