wenn du avr-gcc verwendest, kannst du deine asm-files im makefile unter asm-quellen auflisten:
einzelne anweisungen gehen mitCode:# List Assembler source files here. # Make them always end in a capital .S. Files ending in a lowercase .s # will not be considered source files but generated files (assembler # output from the compiler), and will be deleted upon "make clean"! # Even though the DOS/Win* filesystem matches both .s and .S the same, # it will preserve the spelling of the filenames, and GCC itself does # care about how the name is spelled on its command-line. ASRC = ... (hier die asm-quelltexte mit leerzeichen getrennt)
gruesseCode:asm("ldi R18,0xEC");
Zitieren
