Ergebnis 1 bis 7 von 7
Thema: Abfragecodes für Tastatur (Bascom)
    Boppard
    Hi
    Ich hab mal ein kleines Problem:
    '     PS/2 - Tastatur abfrage
    $regfile = "m8def.dat"
    $crystal = 8000000
    '$baud = 9600
    Config Portd = Output
    Config Keyboard = Pinb.0 , Data = Pinb.1 , Keydata = Keydata
    Dim Cursorposx As Byte
    Dim Cursorposy As Byte
    Dim Key As Byte
    Dim S As String * 16 At $400                                'Beide Variablen, String und Byte() liegen
    Dim B(16) As Byte At $400 Overlay                           'an der gleichen Stelle im Speicher
    '===== Command ===========================================
    Dim Text as String * 16
    '====== Timer =============================================
    Dim Seconds As Integer
    Dim Hours As Integer
    Dim Minutes As Integer
    $serialinput = Kbdinput
    Declare Sub TimerT
    Declare Sub Write_nible(byval D As Byte)                    'ein Nible (D4-D7) schreiben
    Declare Sub Lcd_write_data(byval D As Byte)                 'ins Datenregister schreiben
    Declare Sub Lcd_write_string                                'String S ausgeben
    Initlcd
    Cls
      Cursor On Blink
      Lowerline
      S = "Tastatur + Timer"
      Call Lcd_write_string
      Home
      Cursorposx = 1
      Cursorposy = 1
      Text = ""
      Key = Getatkbd()
      If Key <> 0 Then
        If Key = 8 Then
          Shiftcursor Left
          S = " "
          Cursorposx = Cursorposx - 1
        End If
        If Key = 52 Then
        End If
        If Key = 54 Then
          Cursorposx = Cursorposx + 1
        End If
        If Key = 44 Then
          S = " "
          Shiftcursor Left
        End If
        If Key = 56 Then
          Cursorposy = 1
        End If
        If Key = 50 Then
          Cursorposy = 2
        End If
        If Key <> 54 And Key <> 8 And Key <> 0 And Key <> 52 And Key <> 56 And Key <> 50 Then
          S = Chr(key)
          Text = Text + Chr(key)
        End If
        If Key = 13 Then
          s = LCase(Text)
          If Left(s , 5) = "timer" then TimerT
          Text = ""
          Cls
          Home
          Cursorposx = 1
          Cursorposy = 1
        End If
        If Cursorposx < 1 And Cursorposy = 2 Then
          Cursorposx = 16
          Cursorposy = 1
        End If
        If Cursorposx < 1 And Cursorposy = 1 Then Cursorposx = 1
        If Cursorposx > 16 And Cursorposy = 1 Then
          Cursorposx = 1
          Cursorposy = 2
        End If
        If Cursorposx > 16 And Cursorposy = 2 Then Cursorposx = 16
        Locate Cursorposy , Cursorposx
      End If
    End
    Sub TimerT
    Deflcdchar 1 , 32 , 10 , 32 , 4 , 32 , 17 , 14 , 32         'little Smily
    Deflcdchar 2 , 32 , 12 , 12 , 32 , 32 , 1 , 1 , 32          'big Smily ol
    Deflcdchar 3 , 32 , 6 , 6 , 32 , 32 , 16 , 16 , 32          'big Smily or
    Deflcdchar 4 , 32 , 24 , 28 , 15 , 3 , 32 , 32 , 32         'big Smily ul
    Deflcdchar 5 , 32 , 3 , 7 , 30 , 24 , 32 , 32 , 32          'big Smily ur
    Cls
    Seconds = 0
    Minutes = 0
    Hours = 0
      'Config Portb.1 = Output
      'Config Portb.0 = Input
      Cls
      Lowerline
      S = "By Bjoern  " + Chr(1) + "  " + Chr(4) + Chr(5)
      Cursor Off
      Waitms 110
      Incr Seconds
      If Seconds = 60 Then
        Incr Minutes
        Seconds = 0
      End If
      If Minutes = 60 Then
        Incr Hours
        Minutes = 0
      End If
      Home
      Upperline
      If Hours < 10 Then
        S = "0" + Str(hours)
      Else
        S = " " + Str(hours)
      End If
      If Minutes < 10 Then
        S = S + ":0" + Str(minutes)
      Else
        S = S + ":" + Str(minutes)
      End If
      If Seconds < 10 Then
        S = S + ":0" + Str(seconds) + " Uhr  " + Chr(2) + Chr(3)
      Else
        S = S + ":" + Str(seconds) + " Uhr  " + Chr(2) + Chr(3)
      End If
      Home
      Portb.0 = 1
      If Pinb.1 = 0 Then
        Hours = -1
      end IF
    Loop until Hours = -1
    End SUB
    If D.4 = 1 Then Portd.0 = 1 Else Portd.0 = 0
    If D.5 = 1 Then Portd.1 = 1 Else Portd.1 = 0
    If D.6 = 1 Then Portd.2 = 1 Else Portd.2 = 0
    If D.7 = 1 Then Portd.3 = 1 Else Portd.3 = 0
    Portd.5 = 1
    Waitus 5
    Portd.5 = 0
    End Sub
    Portd.4 = 1
    Call Write_nible(d)
    Waitus 50
    D = D * 16
    Call Write_nible(d)
    Waitus 50
    End Sub
    Dim Istring As Byte
    For Istring = 1 To Len(s)
    Call Lcd_write_data(b(istring))
    Next Istring
    End Sub
    Kbdinput:
    'we come here when input is required from the COM port
    'So we pass the key into R24 with the GetATkbd function
    ' We need some ASM code to save the registers used by the function
    $asm
    push r16           ; save used register
    push r25
    push r26
    push r27
    Kbdinput1:
    rCall _getatkbd    ; call the function
    tst r24            ; check for zero
    breq Kbdinput1     ; yes so try again
    pop r27            ; we got a valid key so restore registers
    pop r26
    pop r25
    pop r16
    $end Asm
    'just return
    Return
    'The tricky part is that you MUST include a normal call to the routine
    'otherwise you get an error
    'This is no clean solution and will be changed
    Key = Getatkbd()
    Keydata:
    'normal keys lower case
    Data 0 , 0 , 0 , 0 , 0 , 200 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , &H5E , 0
    Data 0 , 0 , 0 , 0 , 0 , 113 , 49 , 0 , 0 , 0 , 122 , 115 , 97 , 119 , 50 , 0
    Data 0 , 99 , 120 , 100 , 101 , 52 , 51 , 0 , 0 , 32 , 118 , 102 , 116 , 114 , 53 , 0
    Data 0 , 110 , 98 , 104 , 103 , 121 , 54 , 7 , 8 , 44 , 109 , 106 , 117 , 55 , 56 , 0
    Data 0 , 44 , 107 , 105 , 111 , 48 , 57 , 0 , 0 , 46 , 45 , 108 , 48 , 112 , 43 , 0
    Data 0 , 0 , 0 , 0 , 0 , 92 , 0 , 0 , 0 , 0 , 13 , 0 , 0 , 92 , 0 , 0
    Data 0 , 60 , 0 , 0 , 0 , 0 , 8 , 0 , 0 , 49 , 0 , 52 , 55 , 0 , 0 , 0
    Data 48 , 44 , 50 , 53 , 54 , 56 , 0 , 0 , 0 , 43 , 51 , 45 , 42 , 57 , 0 , 0
    'shifted keys UPPER case
    Data 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0
    Data 0 , 0 , 0 , 0 , 0 , 81 , 33 , 0 , 0 , 0 , 90 , 83 , 65 , 87 , 34 , 0
    Data 0 , 67 , 88 , 68 , 69 , 0 , 35 , 0 , 0 , 32 , 86 , 70 , 84 , 82 , 37 , 0
    Data 0 , 78 , 66 , 72 , 71 , 89 , 38 , 0 , 0 , 76 , 77 , 74 , 85 , 47 , 40 , 0
    Data 0 , 59 , 75 , 73 , 79 , 61 , 41 , 0 , 0 , 58 , 95 , 76 , 48 , 80 , 63 , 0
    Data 0 , 0 , 0 , 0 , 0 , 96 , 0 , 0 , 0 , 0 , 13 , 94 , 0 , 42 , 0 , 0
    Data 0 , 62 , 0 , 0 , 0 , 8 , 0 , 0 , 49 , 0 , 52 , 55 , 0 , 0 , 0 , 0
    Mit diesem einfachen Programm kann ich jetzt schon Tasten Abfragen. Mein Problem ist nun, dass eine menge Sondertasten in der von Bascom bereitgestellten Tabelle fehlen :
    Keydata:
    Kann mir jemand da mal helfen ß
    Moderator Roboter Genie
    Ich weiß ja nicht, ob du dir das RN schon mal näher angeschaut hast...aber es gibt hier ein
    Extra Forum für Bascom
    Verschoben!
    Lkr. Rottal/Inn
    Ich hab vor kurzem mal so ne Tastatur "analyisert"; dabei hab ich die ganzen Zahlen bei KeyData von 0, 1, 2, ... 253, 254, 255 durchnumeriert und mir die Codes, die beim Drücken einer Taste erzeugt werden, auf nem LCD darstellen lassen. Also wenn ich F4 drücke, wird mir die 12 angezeigt. Die Daten hab ich dann auch gleich so gelassen und arbeite direkt mit den "sortieren" Zahlen weiter.
    Der Datenblock sieht dann also in etwa so aus
    KeyData:
    DATA 0,1,2,3....
    Evtl hilft die Tabelle hier:
    a	28
    b	50
    c	33
    d	35
    e	36
    f	43
    g	52
    h	51
    i	67
    j	59
    k	66
    l	75
    m	58
    n	49
    o	68
    p	77
    q	21
    r	45
    s	27
    t	44
    u	60
    v	42
    w	29
    x	34
    y	26
    z	53
    A	156
    B	178
    C	161
    D	163
    E	164
    F	171
    G	180
    H	179
    I	195
    J	187
    K	194
    L	203
    M	186
    N	177
    O	196
    P	205
    Q	149
    R	173
    S	155
    T	172
    U	188
    V	170
    W	157
    X	162
    Y	154
    Z	181
    1	22
    2	30
    3	38
    4	37
    5	46
    6	54
    7	61
    8	62
    9	70
    0	69
    !	150
    "	158
    §	166
    $	165
    %	174
    &	182
    /	189
    (	190
    )	198
    =	197
    CAPS LOCK	88
    TAB	13
    ^	14
    °	142
    ß	78
    ?	206
    ENTER	90
    RÜCK	102
    Taste Oben	224, 224, 117
    Taste Unten	224, 224, 114
    Taste Links	224, 224, 107
    Taste Rechts	224, 224, 116
    INS	224, 224, 112
    DEL	224, 224, 113
    HOME	224, 224, 108
    END	224, 224, 105
    PGUP	224, 224, 125
    PGDN	224, 224, 122
    ESC	118
    SHIFT + INS	96, 96, 96, 240
    SHIFT + DEL	96, 96, 96, 241
    SHIFT + HOME	96, 96, 96, 236
    SHIFT + END	96, 96, 96, 233
    SHIFT + PGUP	96, 96, 96, 253
    SHIFT + PGDN	96, 96, 96, 250
    SHIFT + ESC	246
    STRG L	20
    STRG R	224, 224, 20
    Windows L	224, 224, 31
    Windows R	224, 224, 39
    ALT	17
    Space	41
    ALT GR	224, 224, 17
    SHIFT + ALT	145
    SHIFT + CTRL	148
    SHIFT + SPACE 	169
    SHIFT + ALTGR	96, 96, 145
    SHIFT + Windows L	96, 96, 159
    SHIFT + Windows R	96, 96, 167
    Kontext	224, 224, 47
    SHIFT + Kontext	96, 96, 167
    DRUCK	224, 224, 224, 124
    SHIFT + Druck	96, 96, 252
    Rollen	126
    SHIFT + Rollen	254
    Pause	225, 119
    Shift + Pause	97,247
    Wake Up	224, 224, 94
    SHIFT + WakeUp	96, 96, 222
    Sleep	224, 224, 63
    Shift + Sleep	96,96,191
    Power	224, 224, 55
    SHIFT + Power	96,96,183
    F1	5
    F2	6
    F3	4
    F4	12
    F5	3
    F6	11
    F7	131
    F8	10
    F9	1
    F10	9
    F11	120
    F12	7
    SHIFT + F1	133
    SHIFT + F2	134
    SHIFT + F3	132
    SHIFT + F4	140
    SHIFT + F5	131
    SHIFT + F6	139
    SHIFT + F7	3
    SHIFT + F8	138
    SHIFT + F9	129
    SHIFT + F10	137
    SHIFT + F11	148
    SHIFT + F12	135
    Num Lock	119
    SHIFT + NumLock	247
    Numpad /	224,224,74
    SHIFT + Numpad /	96,96,96,202
    Numpad *	124
    SHIFT + Numpad * 	252
    ä	82
    Ä	210
    ö	76
    Ö	204
    ü	84
    Ü	212
    +	92
    *	219
    #	93
    '	221
    ,	65
    ;	193
    .	73
    :	201
    -	74
    _	202
    <	97
    >	225
    Numpad -	123
    SHIFT + Numpad -	251
    Numpad + 	121
    SHIFT + Numpad +	249
    Numpad 0	112
    Numpad 1	105
    Numpad 2	114
    Numpad 3	122
    Numpad 4	107
    Numpad 5	115
    Numpad 6	116
    Numpad 7	108
    Numpad 8	117
    Numpad 9	125
    SHIFT + Numpad 0	240
    SHIFT + Numpad 1	233
    SHIFT + Numpad 2	242
    SHIFT + Numpad 3	250
    SHIFT + Numpad 4	235
    SHIFT + Numpad 5	243
    SHIFT + Numpad 6	244
    SHIFT + Numpad 7	236
    SHIFT + Numpad 8	245
    SHIFT + Numpad 9	253
    TAB	13
    SHIFT + TAB	141
    SHIFT + RÜCK	230
    SHIFT + ENTER	218
    Hmm
    Du hast die Numlock-Taste erkennen können?
    Klappt bei mir nicht. Allerdings habn ich keine komplette Tastatur, sondern nur einen PS/2-10erBlock dran.
    Alle anderen Tatsen funktionieren, nur der NUMLOCK nicht.
    Hier mal der Code.
    '                PC AT-KEYBOARD Sample
    '              (c) 2000-2003 MCS Electronics
    'For this example :
    'connect PC AT keyboard clock to PIND.2 on the 8535
    'connect PC AT keyboard data to PIND.4 on the 8535
    $regfile = "m644def.dat"
    $crystal = 18432000
    $baud = 19200
    $prog &H00 , &H00 , &H00 , &H00
    'The GetATKBD() function does not use an interrupt.
    'But it waits until a key was pressed!
    'configure the pins to use for the clock and data
    'can be any pin that can serve as an input
    'Keydata is the label of the key translation table
    Config Keyboard = Pinb.2 , Data = Pinb.3 , Keydata = Keydata
    'Dim some used variables
    Dim S As String * 12
    Dim B As Byte
    'Show the program is running
    Print "hello"
      'The following code is remarked but show how to use the GetATKBD() function
      B = Getatkbd()
      'B = Getatkbdraw()                                        'get a byte and store it into byte variable
      'When no real key is pressed the result is 0
      'So test if the result was > 0
       If B > 0 Then
          Print B ; " " ; Chr(b)
       End If
    End
    'This is the key translation table
    Keydata:
    Manchmal "hängt die Kiste sich auch auf". Dann kommen sekundenlang keine Tasten rein. Manchmal gehts dann von selber wieder, manchmal muss ich resetten.
    Jetzt hab ich mal den Befehl getatkbdraw() ausprobiert,
    da sehe ich beim Numlock, wie auch bei allen anderen Keys, immer 2 Zahlen im Logfenster. z.B: Numlock 119,240 oder die 8: 117,240
    Also erkennt er den Numlock doch.
    Dann stimmt wohl was nicht in der Key translation table.
    Um das herauszufinden wäre es nicht schlecht, wenn ich dafür eine Beschreibung hätte. Gibts dazu was?
    Edit: Manchmal sind es dann doch 3 Zahlen die ich reinbekomme??? Jetz steh ich vollkommen daneben.......
    Was soll die "240" immer in der Mitte???
    HILFEEEE Bild
    12°29´ O, 48°38´ N
    mit getatkbdraw() bekommst du ja die Rohdaten der PS/2 Tastatur, evtl. solltest du mal sehen wie das mit PS/2 läuft, und wie die Tastaturcodes aufgebaut sind.
    240 ist in hex F0 und das ist dann der Break-Code, also wenn die Taste wieder losgelassen wurde.
    Gib die Werte von getatkbdraw mit Hex() aus, dann kannst Du hier vergleichen:
    http://www.computer-engineering.org/...cancodes2.html
    Ja, genau das was ich suche und nicht verstanden habe. Danke
    Was noch gesagt werden muss ist, daß die Keydatas aus dem Bascom Sample unvollständig/falsch sind. Die Taste "/" gehört von 45 auf 47 umgeschrieben und der NUMLOCK ist nur mit "0" eingetragen.
    Aber jetz hab ichs gecheckt und kann jede Taste meines Nummernblockes einlesen.
