so mach ich es mit Bascom mit einem atmega 32:
Code:config int2=rising On Int2 Int2_int Enable Interrupts Enable Int2 Open "comb.2:19200,8,n,1" For Input As #1 Open "comd.6:19200,8,n,1" For Output As #2 do waitms 300 loop End Int2_int: Disable Int2 Enable Interrupts input #1, text waitms 5 call empfang() enable int2 Return sub empfang() If Text = "vor" Then M_wert_a = 100 M_wert_b = 100 Call Robby_vor() End If If Text = "zurueck" Then M_wert_a = 100 M_wert_b = 100 Call Robby_zurueck() End If If Text = "links" Then M_wert_a = 60 M_wert_b = 60 Call Robby_links() End If If Text = "rechts" Then M_wert_a = 60 M_wert_b = 60 Call Robby_rechts() End If If Text = "stop" Then Call Robby_aus() End If end sub
Zitieren
