Hab es mal mit Byte versucht, aber weder speichert er mir die Daten im Eram, noch zeigt er mir den Statusbalken vernünftig an, verstehe einfach nicht woran das liegen kann.
Code:$regfile = "m16def.dat" ' specify the used micro $crystal = 1000000 ' used crystal frequency $baud = 19200 ' use baud rate $hwstack = 32 ' default use 32 for the hardware stack $swstack = 10 ' default use 10 for the SW stack $framesize = 40 ' default use 40 for the frame space Config Portd = Input $lib "glcdKS108.lbx" $include "font8x8.font" Config Graphlcd = 128 * 64sed , Dataport = Porta , Controlport = Portc , Ce = 1 , Ce2 = 2 , Cd = 5 , Rd = 4 , Reset = 0 , Enable = 3 Dim Eedummy As Eram Byte Dim Intens As Eram Byte Dim Inten As Byte Dim I As Integer Dim Speed As Eram Byte Dim Spee As Byte Dim S As Integer Cls Setfont Font8x8 Lcdat 2 , 30 , "DLP 3000" Lcdat 8 , 1 , "Start" Lcdat 8 , 83 , "Config" Do Debounce Pind.0 , 0 , Intense Loop Intense: Inten = Intens I = Inten Cls Lcdat 2 , 35 , "Intense" Do Debounce Pind.0 , 0 , Inthoch , Sub Debounce Pind.1 , 0 , Saveint Debounce Pind.2 , 0 , Intrunter , Sub Lcdat 8 , 10 , I Loop End Inthoch: I = I + 10 If I > 100 Then I = 100 Lcdat 5 , I , " " , 1 Return Intrunter: I = I - 10 If I < 10 Then I = 10 Lcdat 5 , I , " " Return Saveint: Inten = I Intens = Inten Cls
Zitieren
