Stell dich nicht so an...
Code:Led_port Alias Portb ' Port An Den Die Segmente "hängen" Dim Wer As String * 1 ' String einzelnes Zeichen der Zahl ' Port-Pin zu 7-segement - g f e d c b a Select Case Wert Case "0" : Led_port = &B00111111 ' hier die Port-Pins ansteuern, Case "1" : Led_port = &B00000110 ' welche das Segment ansteuern soll Case "2" : Led_port = &B01011011 Case "3" : Led_port = &B01001111 Case "4" : Led_port = &B01100110 Case "5" : Led_port = &B01101100 Case "6" : Led_port = &B01111101 Case "7" : Led_port = &B00000000 Case "8" : Led_port = &B00000111 Case "9" : Led_port = &B01101111 Case Else Led_port = &B00000000 End Select
Zitieren
