also ich habe mal versucht, die makefiles zu vergleichen und die einstellungen zu verändern. nun sieht der file folgendermaßen aus:
Code:############################################################################### # Makefile for the project TestProjekt ############################################################################### ## General Flags PROJECT = TestProjekt MCU = atmega8 TARGET = program.elf CC = avr-gcc.exe ## Options common to compile, link and assembly rules COMMON = -mmcu=$(MCU) ## Compile options common for all C compilation units. CFLAGS = $(COMMON) CFLAGS += -Wall -gdwarf-2 -DF_CPU=8000000UL -Os -fsigned-char CFLAGS += -MD -MP -MT $(*F).o -MF dep/$(@F).d ## Assembly specific flags ASMFLAGS = $(COMMON) ASMFLAGS += $(CFLAGS) ASMFLAGS += -x assembler-with-cpp -Wa,-gdwarf2 ## Linker flags LDFLAGS = $(COMMON) LDFLAGS += -Wl,-Map=program.map ## Intel Hex file production flags HEX_FLASH_FLAGS = -R .eeprom HEX_EEPROM_FLAGS = -j .eeprom HEX_EEPROM_FLAGS += --set-section-flags=.eeprom="alloc,load" HEX_EEPROM_FLAGS += --change-section-lma .eeprom=0 --no-change-warnings ## Include Directories INCLUDES = -I"C:\Users\michael\Asuro\Workspace\eigener test\TestProjekt\..\..\..\Asuro lib\AsuroLib-v270rc3\lib\inc" ## Library Directories LIBDIRS = -L"C:\WinAVR\avr\lib" -L"C:\Users\michael\Asuro\Asuro lib\AsuroLib-v270rc3\lib" ## Libraries LIBS = -lasuro ## Objects that must be built in order to link OBJECTS = TestProjekt.o 001.o asuro.o ## Objects explicitly added by the user LINKONLYOBJECTS = ## Build all: $(TARGET) program.hex program.eep program.lss size ## Compile TestProjekt.o: ../TestProjekt.c $(CC) $(INCLUDES) $(CFLAGS) -c $< 001.o: ../001.c $(CC) $(INCLUDES) $(CFLAGS) -c $< asuro.o: ../../../../Asuro lib/AsuroLib-v270rc3/lib/asuro.c $(CC) $(INCLUDES) $(CFLAGS) -c $< ##Link $(TARGET): $(OBJECTS) $(CC) $(LDFLAGS) $(OBJECTS) $(LINKONLYOBJECTS) $(LIBDIRS) $(LIBS) -o $(TARGET) %.hex: $(TARGET) avr-objcopy -O ihex $(HEX_FLASH_FLAGS) $< $@ %.eep: $(TARGET) -avr-objcopy $(HEX_EEPROM_FLAGS) -O ihex $< $@ || exit 0 %.lss: $(TARGET) avr-objdump -h -S $< > $@ size: ${TARGET} @echo @avr-size -C --mcu=${MCU} ${TARGET} ## Clean target .PHONY: clean clean: -rm -rf $(OBJECTS) program.elf dep/* program.hex program.eep program.lss program.map ## Other dependencies -include $(shell mkdir dep 2>/dev/null) $(wildcard dep/*)
aber eine hex wird immer noch nicht erstellt. mein programm sieht nun so aus:
also so, dass es keine fehler bringt:Code:#include "asuro.h" //void Sleep3ms(short b); int main(void) { Init(); while(1){ if(PollSwitch()!=0) { //SerPrint("Achtung\n"); if(PollSwitch()>7){//links SetMotorPower (0,0); // Sleep3MS(50); SetMotorPower (0,-100); // Sleep3MS(200); SetMotorPower (100,100); } else{//rechts SetMotorPower (0,0); // Sleep3MS(50); SetMotorPower (-100,0); // Sleep3MS(200); SetMotorPower (100,100); } } else{ SetMotorPower (100,100); // Sleep3MS(30); } } } //void Sleep3MS(short b){ //short t; // for(t=0;t<=b;t++){ // Sleep(216); // } //}
Build succeeded with 0 Warnings...
muss man den makefile noch mal extern starten oder ist noch etwas falsch eingestellt???
Zitieren
