Zum bugreport bei gcc.gnu.org:
Häng da noch die Precompilierte Quelle (also wo alle #includes etc aufgelöst sind) dran, und wie du die Datei erhalten hast!
Sonst kann man das niemals nachvollziehen!
long foo (long a, long b, long c, unsigned char d){
  if(d){
    return a+b;
  }else{
    return a-c;
d:\avr\test>avr-gcc blah.c -Os -S -v -fverbose-asm
Reading specs from E:/WinAVR_20060421/lib/gcc/avr/3.4.6/specs
Configured with: ../gcc-3.4.6/configure --prefix=/c/WinAVR --target=avr --enable
=c,c++ --with-dwarf2 --enable-win32-registry=WinAVR --disable-nls
Thread model: single
GCC version 3.4.6
 E:/WinAVR_20060421/libexec/gcc/avr/3.4.6/cc1.exe -quiet -v -iprefix e:\WinAVR_2
n/../lib/gcc/avr/3.4.6/ blah.c -quiet -dumpbase blah.c -auxbase blah -Os -versio
e-asm -o blah.s
ignoring nonexistent directory "E:/WinAVR_20060421/avr/sys-include"
#include "..." search starts here:
#include <...> search starts here:
 e:\WinAVR_20060421\bin/../lib/gcc/avr/3.4.6/include
 E:/WinAVR_20060421/lib/gcc/avr/3.4.6/include
 E:/WinAVR_20060421/avr/include
End of search list.
GNU C version 3.4.6 (avr)
        compiled by GNU C version 3.4.2 (mingw-special).
GGC heuristics: --param ggc-min-expand=47 --param ggc-min-heapsize=32702
blah.s:
	.file	"blah.c"
	.arch AVR2
__SREG__ = 0x3f
__SP_H__ = 0x3e
__SP_L__ = 0x3d
__tmp_reg__ = 0
__zero_reg__ = 1
	.global __do_copy_data
	.global __do_clear_bss
 ;  GNU C version 3.4.6 (avr)
 ; 	compiled by GNU C version 3.4.2 (mingw-special).
 ;  GGC heuristics: --param ggc-min-expand=47 --param ggc-min-heapsize=32702
 ;  options passed:  -v -iprefix -auxbase -Os -fverbose-asm
 ;  options enabled:  -feliminate-unused-debug-types -fdefer-pop
 ;  -fomit-frame-pointer -foptimize-sibling-calls -funit-at-a-time
 ;  -fcse-follow-jumps -fcse-skip-blocks -fexpensive-optimizations
 ;  -fthread-jumps -fstrength-reduce -fpeephole -fforce-mem -ffunction-cse
 ;  -fkeep-static-consts -fcaller-saves -freg-struct-return -fgcse
 ;  -fgcse-lm -fgcse-sm -fgcse-las -floop-optimize -fcrossjumping
 ;  -fif-conversion -fif-conversion2 -frerun-cse-after-loop
 ;  -frerun-loop-opt -fdelete-null-pointer-checks -fsched-interblock
 ;  -fsched-spec -fsched-stalled-insns -fsched-stalled-insns-dep
 ;  -fbranch-count-reg -freorder-functions -fcprop-registers -fcommon
 ;  -fverbose-asm -fregmove -foptimize-register-move -fargument-alias
 ;  -fstrict-aliasing -fmerge-constants -fzero-initialized-in-bss -fident
 ;  -fpeephole2 -fguess-branch-probability -fmath-errno -ftrapping-math
 ;  -minit-stack=__stack -mmcu=avr2
	.text
.global	foo
	.type	foo, @function
foo:
/* prologue: frame size=0 */
	push r12
	push r14
	push r15
	push r16
	push r17
	push r28
	push r29
/* prologue end (size=7) */
	mov r29,r25	 ;  a, a
	mov r28,r24	 ;  a, a
	mov r27,r23	 ;  a, a
	mov r26,r22	 ;  a, a
	tst r12	 ;  d
	breq .L2	 ; ,
	mov r22,r26	 ;  <result>, a
	mov r23,r27	 ;  <result>, a
	mov r24,r28	 ;  <result>, a
	mov r25,r29	 ;  <result>, a
	add r22,r18	 ;  <result>, b
	adc r23,r19	 ;  <result>, b
	adc r24,r20	 ;  <result>, b
	adc r25,r21	 ;  <result>, b
	rjmp .L1	 ;
.L2:
	sub r22,r14	 ;  <result>, c
	sbc r23,r15	 ;  <result>, c
	sbc r24,r16	 ;  <result>, c
	sbc r25,r17	 ;  <result>, c
.L1:
/* epilogue: frame size=0 */
	pop r29
	pop r28
	pop r17
	pop r16
	pop r15
	pop r14
	pop r12
	ret
/* epilogue end (size=8) */
/* function foo size 38 (23) */
	.size	foo, .-foo
/* File "blah.c": code   38 = 0x0026 (  23), prologues   7, epilogues   8 */
