rs232 kann man in .net einfach als "Variable" definieren
z.B.
einfach maln bisschen CodefutterCode:Dim FLASHER5_SerialPort() As SerialPort Dim x As Int16 ReDim Preserve FLASHER5_SerialPort(0 To PRG_FLASHER5.GetUpperBound(0)) For x = 0 To PRG_FLASHER5.GetUpperBound(0) If FLASHER5_SerialPort(x) Is Nothing Then ' Wenn Anschluss schon instanziert FLASHER5_SerialPort(x) = New SerialPort(PRG_FLASHER5(x).PORT, 115200, Parity.Odd, 8, StopBits.One) FLASHER5_SerialPort(x).Handshake = Handshake.None FLASHER5_SerialPort(x).ReadBufferSize = 4096 FLASHER5_SerialPort(x).WriteBufferSize = 2024 FLASHER5_SerialPort(x).ReadTimeout = -1 FLASHER5_SerialPort(x).WriteTimeout = -1 End If ...... Public Function open(ByVal ProgIndex As Int16) As Boolean Dim counter As Int16 = 0 With FLASHER5_SerialPort(ProgIndex) Do Until .IsOpen DoEvents() Try .Open() Catch If counter > 100 Then Return False counter += 1 End Try Loop Return True End With End Function Public Function closeAll() As Boolean Dim x As Int16 For x = 0 To PRG_FLASHER5.GetUpperBound(0) Dim counter As Int16 = 0 With FLASHER5_SerialPort(x) Do Until Not (.IsOpen) DoEvents() Try .Close() Catch If counter > 100 Then FLASHER5_MESSAGES.Enqueue("could not close " & .PortName) Return False End If counter += 1 End Try Loop End With Next x Return True End Function Public Function CmdSend(ByVal stringg As String, ByVal ProgIndex As Int16) As String With FLASHER5_SerialPort(ProgIndex) If .IsOpen Then .WriteLine(stringg & vbCrLf) 'x = Chr(13) Do While .BytesToWrite > 0 DoEvents() Loop Else FLASHER5_MESSAGES.Enqueue(.PortName & " not open") Exit Function End If Dim x As String = "" Dim temp() As String Dim counter As Int16 = 0 Do Try DoEvents() System.Threading.Thread.Sleep(20) x &= .ReadExisting If x.Length < 1 Then counter += 1 If counter > 100 Then Return "timeout" Catch ex As Exception FLASHER5_MESSAGES.Enqueue(ex.Message) Return ex.Message End Try If x.StartsWith("#NACK" & vbCr) Then Return "failure" Loop Until x.StartsWith("#ACK" & vbCr & "#") And x.EndsWith(vbCr) temp = x.Split("#") x = temp(2).TrimEnd(vbCr) Return x End With End Function Next x![]()
wenn ihr Fragen zu .net habt kann ich dienen...
Zitieren
