Thema: Probleme mit Makefile!
    GRAZ
    Hallo Leute
    Bitte um Hilfe!!
    Bin gerade am Umsteigen von Bascom auf C
    Habe leider derzeit Probleme mit den Makefile!
    Habe das zuerst mal das originale Makfile mit "Mfile" probiert
    Funktionierte leider nicht .
    Dann habe ich eine Makefile von den Demo Programmen probiert.
    Inzwischen läuft zumindest die Compilierung und ich konnte mein kleines Versuchsprogramm im AVR Studio simulieren.
    Dieses Makfile schaute so aus:
    PRG            = Meines
    OBJ            = Meines.o
    #MCU_TARGET     = at90s2313
    #MCU_TARGET     = at90s2333
    #MCU_TARGET     = at90s4414
    #MCU_TARGET     = at90s4433
    #MCU_TARGET     = at90s4434
    #MCU_TARGET     = at90s8515
    #MCU_TARGET     = at90s8535
    #MCU_TARGET     = atmega128
    #MCU_TARGET     = atmega1280
    #MCU_TARGET     = atmega1281
    MCU_TARGET     = atmega16
    #MCU_TARGET     = atmega163
    #MCU_TARGET     = atmega164p
    #MCU_TARGET     = atmega165
    #MCU_TARGET     = atmega165p
    #MCU_TARGET     = atmega168
    #MCU_TARGET     = atmega169
    #MCU_TARGET     = atmega169p
    #MCU_TARGET     = atmega32
    #MCU_TARGET     = atmega324p
    #MCU_TARGET     = atmega325
    #MCU_TARGET     = atmega3250
    #MCU_TARGET     = atmega329
    #MCU_TARGET     = atmega3290
    #MCU_TARGET     = atmega48
    #MCU_TARGET     = atmega64
    #MCU_TARGET     = atmega640
    #MCU_TARGET     = atmega644
    #MCU_TARGET     = atmega644p
    #MCU_TARGET     = atmega645
    #MCU_TARGET     = atmega6450
    #MCU_TARGET     = atmega649
    #MCU_TARGET     = atmega6490
    #MCU_TARGET     = atmega8
    #MCU_TARGET     = atmega8515
    #MCU_TARGET     = atmega8535
    #MCU_TARGET     = atmega88
    #MCU_TARGET     = attiny2313
    #MCU_TARGET     = attiny24
    #MCU_TARGET     = attiny25
    #MCU_TARGET     = attiny26
    #MCU_TARGET     = attiny261
    #MCU_TARGET     = attiny44
    #MCU_TARGET     = attiny45
    #MCU_TARGET     = attiny461
    #MCU_TARGET     = attiny84
    #MCU_TARGET     = attiny85
    #MCU_TARGET     = attiny861
    OPTIMIZE       = -O2
    DEFS           =
    LIBS           =
    # You should not have to change anything below here.
    CC             = avr-gcc
    # Override is only needed by avr-lib build system.
    override CFLAGS        = -g -Wall $(OPTIMIZE) -mmcu=$(MCU_TARGET) $(DEFS)
    override LDFLAGS       = -Wl,-Map,$(PRG).map
    OBJCOPY        = avr-objcopy
    OBJDUMP        = avr-objdump
    all: $(PRG).elf lst text eeprom
    $(PRG).elf: $(OBJ)
    	$(CC) $(CFLAGS) $(LDFLAGS) -o $@ $^ $(LIBS)
    # dependency:
    clean:
    	rm -rf *.o $(PRG).elf *.eps *.png *.pdf *.bak
    	rm -rf *.lst *.map $(EXTRA_CLEAN_FILES)
    lst:  $(PRG).lst
    %.lst: %.elf
    	$(OBJDUMP) -h -S $< > $@
    # Rules for building the .text rom images
    text: hex bin srec
    hex:  $(PRG).hex
    bin:  $(PRG).bin
    srec: $(PRG).srec
    %.hex: %.elf
    	$(OBJCOPY) -j .text -j .data -O ihex $< $@
    %.srec: %.elf
    	$(OBJCOPY) -j .text -j .data -O srec $< $@
    %.bin: %.elf
    	$(OBJCOPY) -j .text -j .data -O binary $< $@
    # Rules for building the .eeprom rom images
    eeprom: ehex ebin esrec
    ehex:  $(PRG)_eeprom.hex
    ebin:  $(PRG)_eeprom.bin
    esrec: $(PRG)_eeprom.srec
    %_eeprom.hex: %.elf
    	$(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O ihex $< $@
    %_eeprom.srec: %.elf
    	$(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O srec $< $@
    %_eeprom.bin: %.elf
    	$(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O binary $< $@
    # Every thing below here is used by avr-libc's build system and can be ignored
    # by the casual user.
    FIG2DEV                 = fig2dev
    EXTRA_CLEAN_FILES       = *.hex *.bin *.srec
    dox: eps png pdf
    eps: $(PRG).eps
    png: $(PRG).png
    pdf: $(PRG).pdf
    %.eps: %.fig
    	$(FIG2DEV) -L eps $< $@
    %.pdf: %.fig
    	$(FIG2DEV) -L pdf $< $@
    %.png: %.fig
    	$(FIG2DEV) -L png $< $@
    Jetzt möchte ich aber gerne das schreiben in den AVR auch gleich mit dem "AVRDUDE" erledigen lassen.
    Habe dafür die beiden Zeilen für AVRDUDE von den Hilfen hier im Netz dazugefügt.
    AVRDUDE_PROGRAMMER= stk200
    AVRDUDE_PORT =lpt1
    Leider rührt sich da aber nix
    Jetzt habe ich mal wieder das Originale File Von "MFILE" probiert und
    meine Werte dazu geändert
    c-File = Meines.c
    STK200 /LPT1
    Ist in der zweiten Teil (Nachrichtentext zu lang Bild   )
    Es kommt dann immer die Meldung:
    No rule to make target 'obj/main.o' needed by 'Meines.elf'. STop
    Bitte um Hilfe!
    Habe das Forum durchgeschaut , aber dazu leider nicht viel gefunden Bild
    (nur Standardeinstellungen für das Makfile von File-Name und Prozessor..)
    Gibt es vielleicht irgendwo ein gute beschreibung für Makile's in deutsch?
    l.G. Roberto
    GRAZ
    # Hey Emacs, this is a -*- makefile -*-
    # WinAVR Makefile Template written by Eric B. Weddington, Jörg Wunsch, et al.
    # Released to the Public Domain
    # Additional material for this makefile was written by:
    # Peter Fleury
    # Tim Henigan
    # Colin O'Flynn
    # Reiner Patommel
    # Markus Pfaff
    # Sander Pool
    # Frederik Rouleau
    # Carlos Lamas
    # On command line:
    # make all = Make software.
    # make clean = Clean out built project files.
    # make coff = Convert ELF to AVR COFF.
    # make extcoff = Convert ELF to AVR Extended COFF.
    # make program = Download the hex file to the device, using avrdude.
    #                Please customize the avrdude settings below first!
    # make debug = Start either simulavr or avarice as specified for debugging,
    #              with avr-gdb or avr-insight as the front end for debugging.
    # make filename.s = Just compile filename.c into the assembler code only.
    # make filename.i = Create a preprocessed source file for use in submitting
    #                   bug reports to the GCC project.
    # To rebuild project do "make clean" then "make all".
    # MCU name
    MCU = atmega16
    # Processor frequency.
    #     This will define a symbol, F_CPU, in all source code files equal to the
    #     processor frequency. You can then use this symbol in your source code to
    #     calculate timings. Do NOT tack on a 'UL' at the end, this will be done
    #     automatically to create a 32-bit value in your source code.
    #     Typical values are:
    #         F_CPU =  1000000
    #         F_CPU =  1843200
    #         F_CPU =  2000000
    #         F_CPU =  3686400
    #         F_CPU =  4000000
    #         F_CPU =  7372800
    #         F_CPU =  8000000
    #         F_CPU = 11059200
    #         F_CPU = 14745600
    #         F_CPU = 16000000
    #         F_CPU = 18432000
    #         F_CPU = 20000000
    F_CPU = 8000000
    # Output format. (can be srec, ihex, binary)
    FORMAT = ihex
    # Target file name (without extension).
    TARGET = Meines
    # Object files directory
    OBJDIR = obj
    # List C source files here. (C dependencies are automatically generated.)
    SRC =
    # List C++ source files here. (C dependencies are automatically generated.)
    CPPSRC = main.cpp
    # List Assembler source files here.
    #     Make them always end in a capital .S.  Files ending in a lowercase .s
    #     will not be considered source files but generated files (assembler
    #     output from the compiler), and will be deleted upon "make clean"!
    #     Even though the DOS/Win* filesystem matches both .s and .S the same,
    #     it will preserve the spelling of the filenames, and GCC itself does
    #     care about how the name is spelled on its command-line.
    ASRC =
    # Optimization level, can be [0, 1, 2, 3, s].
    #     0 = turn off optimization. s = optimize for size.
    #     (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
    OPT = s
    # Debugging format.
    #     Native formats for AVR-GCC's -g are dwarf-2 [default] or stabs.
    #     AVR Studio 4.10 requires dwarf-2.
    #     AVR [Extended] COFF format requires stabs, plus an avr-objcopy run.
    DEBUG = dwarf-2
    # List any extra directories to look for include files here.
    #     Each directory must be seperated by a space.
    #     Use forward slashes for directory separators.
    #     For a directory that has spaces, enclose it in quotes.
    EXTRAINCDIRS =
    # Compiler flag to set the C Standard level.
    #     c89   = "ANSI" C
    #     gnu89 = c89 plus GCC extensions
    #     c99   = ISO C99 standard (not yet fully implemented)
    #     gnu99 = c99 plus GCC extensions
    CSTANDARD = -std=gnu99
    # Place -D or -U options here for C sources
    CDEFS = -DF_CPU=$(F_CPU)UL
    # Place -D or -U options here for C++ sources
    CPPDEFS = -DF_CPU=$(F_CPU)UL
    #CPPDEFS += -D__STDC_LIMIT_MACROS
    #CPPDEFS += -D__STDC_CONSTANT_MACROS
    #---------------- Compiler Options C ----------------
    #  -g*:          generate debugging information
    #  -O*:          optimization level
    #  -f...:        tuning, see GCC manual and avr-libc documentation
    #  -Wall...:     warning level
    #  -Wa,...:      tell GCC to pass this to the assembler.
    #    -adhlns...: create assembler listing
    CFLAGS = -g$(DEBUG)
    CFLAGS += $(CDEFS)
    CFLAGS += -O$(OPT)
    #CFLAGS += -mint8
    #CFLAGS += -mshort-calls
    CFLAGS += -funsigned-char
    CFLAGS += -funsigned-bitfields
    CFLAGS += -fpack-struct
    CFLAGS += -fshort-enums
    #CFLAGS += -fno-unit-at-a-time
    CFLAGS += -Wall
    CFLAGS += -Wstrict-prototypes
    CFLAGS += -Wundef
    #CFLAGS += -Wunreachable-code
    #CFLAGS += -Wsign-compare
    CFLAGS += -Wa,-adhlns=$(<:%.c=$(OBJDIR)/%.lst)
    CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
    CFLAGS += $(CSTANDARD)
    #---------------- Compiler Options C++ ----------------
    CPPFLAGS = -g$(DEBUG)
    CPPFLAGS += $(CPPDEFS)
    CPPFLAGS += -O$(OPT)
    #CPPFLAGS += -mint8
    #CPPFLAGS += -mshort-calls
    CPPFLAGS += -funsigned-char
    CPPFLAGS += -funsigned-bitfields
    CPPFLAGS += -fpack-struct
    CPPFLAGS += -fshort-enums
    CPPFLAGS += -fno-exceptions
    #CPPFLAGS += -fno-unit-at-a-time
    CPPFLAGS += -Wall
    #CPPFLAGS += -Wstrict-prototypes
    CFLAGS += -Wundef
    #CPPFLAGS += -Wunreachable-code
    #CPPFLAGS += -Wsign-compare
    CPPFLAGS += -Wa,-adhlns=$(<:%.cpp=$(OBJDIR)/%.lst)
    CPPFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
    #CPPFLAGS += $(CSTANDARD)
    #---------------- Assembler Options ----------------
    #  -ahlms:    create listing
    #  -gstabs:   have the assembler create line number information; note that
    #             for use in COFF files, additional information about filenames
    #             and function names needs to be present in the assembler source
    #             files -- see avr-libc docs [FIXME: not yet described there]
    ASFLAGS = -Wa,-adhlns=$(<:%.S=$(OBJDIR)/%.lst),-gstabs
    #---------------- Library Options ----------------
    # Minimalistic printf version
    PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
    # Floating point printf version (requires MATH_LIB = -lm below)
    PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
    # If this is left blank, then it will use the Standard printf version.
    PRINTF_LIB =
    #PRINTF_LIB = $(PRINTF_LIB_MIN)
    #PRINTF_LIB = $(PRINTF_LIB_FLOAT)
    # Minimalistic scanf version
    SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
    # Floating point + %[ scanf version (requires MATH_LIB = -lm below)
    SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
    # If this is left blank, then it will use the Standard scanf version.
    SCANF_LIB =
    #SCANF_LIB = $(SCANF_LIB_MIN)
    #SCANF_LIB = $(SCANF_LIB_FLOAT)
    MATH_LIB = -lm
    #---------------- External Memory Options ----------------
    # 64 KB of external RAM, starting after internal RAM (ATmega128!),
    # used for variables (.data/.bss) and heap (malloc()).
    #EXTMEMOPTS = -Wl,-Tdata=0x801100,--defsym=__heap_end=0x80ffff
    # only used for heap (malloc()).
    #EXTMEMOPTS = -Wl,--defsym=__heap_start=0x801100,--defsym=__heap_end=0x80ffff
    EXTMEMOPTS =
    #---------------- Linker Options ----------------
    #  -Wl,...:     tell GCC to pass this to linker.
    #    -Map:      create map file
    #    --cref:    add cross reference to  map file
    LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
    LDFLAGS += $(EXTMEMOPTS)
    LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
    #LDFLAGS += -T linker_script.x
    #---------------- Programming Options (avrdude) ----------------
    # Programming hardware: alf AVR910 avrisp Bascom bsd
    # dt006 pavr picoweb pony-stk200 sp12 stk200 stk500
    # Type: avrdude -c ?
    # to get a full listing.
    AVRDUDE_PROGRAMMER = stk200
    # com1 = serial port. Use lpt1 to connect to parallel port.
    AVRDUDE_PORT = lpt1
    AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
    #AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
    # Uncomment the following if you want avrdude's erase cycle counter.
    # Note that this counter needs to be initialized first using -Yn,
    # see avrdude manual.
    #AVRDUDE_ERASE_COUNTER = -y
    # Uncomment the following if you do /not/ wish a verification to be
    # performed after programming the device.
    #AVRDUDE_NO_VERIFY = -V
    # Increase verbosity level.  Please use this when submitting bug
    # reports about avrdude. See <http://savannah.nongnu.org/projects/avrdude>
    # to submit bug reports.
    #AVRDUDE_VERBOSE = -v -v
    AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
    AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
    AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
    AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
    #---------------- Debugging Options ----------------
    # For simulavr only - target MCU frequency.
    DEBUG_MFREQ = $(F_CPU)
    # Set the DEBUG_UI to either gdb or insight.
    # DEBUG_UI = gdb
    DEBUG_UI = insight
    # Set the debugging back-end to either avarice, simulavr.
    DEBUG_BACKEND = avarice
    #DEBUG_BACKEND = simulavr
    # GDB Init Filename.
    GDBINIT_FILE = __avr_gdbinit
    # When using avarice settings for the JTAG
    JTAG_DEV = /dev/com1
    # Debugging port used to communicate between GDB / avarice / simulavr.
    DEBUG_PORT = 4242
    # Debugging host used to communicate between GDB / avarice / simulavr, normally
    #     just set to localhost unless doing some sort of crazy debugging when
    #     avarice is running on a different computer.
    DEBUG_HOST = localhost
    # Define programs and commands.
    SHELL = sh
    CC = avr-gcc
    SIZE = avr-size
    NM = avr-nm
    AVRDUDE = avrdude
    REMOVE = rm -f
    REMOVEDIR = rm -rf
    COPY = cp
    WINSHELL = cmd
    # Define Messages
    # English
    MSG_ERRORS_NONE = Errors: none
    MSG_BEGIN = -------- begin --------
    MSG_END = --------  end  --------
    MSG_SIZE_BEFORE = Size before:
    MSG_SIZE_AFTER = Size after:
    MSG_COFF = Converting to AVR COFF:
    MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
    MSG_FLASH = Creating load file for Flash:
    MSG_EEPROM = Creating load file for EEPROM:
    MSG_EXTENDED_LISTING = Creating Extended Listing:
    MSG_SYMBOL_TABLE = Creating Symbol Table:
    MSG_LINKING = Linking:
    MSG_COMPILING = Compiling C:
    MSG_COMPILING_CPP = Compiling C++:
    MSG_ASSEMBLING = Assembling:
    MSG_CLEANING = Cleaning project:
    MSG_CREATING_LIBRARY = Creating library:
    # Define all object files.
    OBJ = $(SRC:%.c=$(OBJDIR)/%.o) $(CPPSRC:%.cpp=$(OBJDIR)/%.o) $(ASRC:%.S=$(OBJDIR)/%.o)
    # Define all listing files.
    LST = $(SRC:%.c=$(OBJDIR)/%.lst) $(CPPSRC:%.cpp=$(OBJDIR)/%.lst) $(ASRC:%.S=$(OBJDIR)/%.lst)
    # Compiler flags to generate dependency files.
    GENDEPFLAGS = -MD -MP -MF .dep/$(@F).d
    # Combine all necessary flags and optional flags.
    # Add target processor to flags.
    ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS)
    ALL_CPPFLAGS = -mmcu=$(MCU) -I. -x c++ $(CPPFLAGS) $(GENDEPFLAGS)
    ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
    # Default target.
    all: begin gccversion sizebefore build sizeafter end
    # Change the build target to build a HEX file or a library.
    build: elf hex eep lss sym
    #build: lib
    elf: $(TARGET).elf
    hex: $(TARGET).hex
    eep: $(TARGET).eep
    lss: $(TARGET).lss
    sym: $(TARGET).sym
    LIBNAME=lib$(TARGET).a
    lib: $(LIBNAME)
    # Eye candy.
    # AVR Studio 3.x does not check make's exit code but relies on
    # the following magic strings to be generated by the compile job.
    begin:
    	@echo
    	@echo $(MSG_BEGIN)
    end:
    	@echo $(MSG_END)
    	@echo
    # Display size of file.
    HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
    ELFSIZE = $(SIZE) -A $(TARGET).elf
    AVRMEM = avr-mem.sh $(TARGET).elf $(MCU)
    sizebefore:
    	@if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); \
    	$(AVRMEM) 2>/dev/null; echo; fi
    sizeafter:
    	@if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); \
    # Display compiler version information.
    gccversion :
    	@$(CC) --version
    # Program the device.
    program: $(TARGET).hex $(TARGET).eep
    	$(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
    # Generate avr-gdb config/init file which does the following:
    #     define the reset signal, load the target file, connect to target, and set
    #     a breakpoint at main().
    gdb-config:
    	@$(REMOVE) $(GDBINIT_FILE)
    	@echo define reset >> $(GDBINIT_FILE)
    	@echo SIGNAL SIGHUP >> $(GDBINIT_FILE)
    	@echo end >> $(GDBINIT_FILE)
    	@echo file $(TARGET).elf >> $(GDBINIT_FILE)
    	@echo target remote $(DEBUG_HOST):$(DEBUG_PORT)  >> $(GDBINIT_FILE)
    ifeq ($(DEBUG_BACKEND),simulavr)
    	@echo load  >> $(GDBINIT_FILE)
    endif
    	@echo break main >> $(GDBINIT_FILE)
    debug: gdb-config $(TARGET).elf
    ifeq ($(DEBUG_BACKEND), avarice)
    	@echo Starting AVaRICE - Press enter when "waiting to connect" message displays.
    	@$(WINSHELL) /c start avarice --jtag $(JTAG_DEV) --erase --program --file \
    	$(TARGET).elf $(DEBUG_HOST):$(DEBUG_PORT)
    	@$(WINSHELL) /c pause
    else
    	@$(WINSHELL) /c start simulavr --gdbserver --device $(MCU) --clock-freq \
    	$(DEBUG_MFREQ) --port $(DEBUG_PORT)
    endif
    	@$(WINSHELL) /c start avr-$(DEBUG_UI) --command=$(GDBINIT_FILE)
    # Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
    COFFCONVERT = $(OBJCOPY) --debugging
    COFFCONVERT += --change-section-address .data-0x800000
    COFFCONVERT += --change-section-address .bss-0x800000
    COFFCONVERT += --change-section-address .noinit-0x800000
    COFFCONVERT += --change-section-address .eeprom-0x810000
    coff: $(TARGET).elf
    	@echo
    	@echo $(MSG_COFF) $(TARGET).cof
    	$(COFFCONVERT) -O coff-avr $< $(TARGET).cof
    extcoff: $(TARGET).elf
    	@echo
    	@echo $(MSG_EXTENDED_COFF) $(TARGET).cof
    	$(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
    # Create final output files (.hex, .eep) from ELF output file.
    %.hex: %.elf
    	@echo
    	@echo $(MSG_FLASH) $@
    	$(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
    %.eep: %.elf
    	@echo
    	@echo $(MSG_EEPROM) $@
    	-$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
    	--change-section-lma .eeprom=0 -O $(FORMAT) $< $@
    # Create extended listing file from ELF output file.
    %.lss: %.elf
    	@echo
    	@echo $(MSG_EXTENDED_LISTING) $@
    # Create a symbol table from ELF output file.
    %.sym: %.elf
    	@echo
    	@echo $(MSG_SYMBOL_TABLE) $@
    	$(NM) -n $< > $@
    # Create library from object files.
    .SECONDARY : $(TARGET).a
    .PRECIOUS : $(OBJ)
    %.a: $(OBJ)
    	@echo
    	@echo $(MSG_CREATING_LIBRARY) $@
    	$(AR) $@ $(OBJ)
    # Link: create ELF output file from object files.
    .SECONDARY : $(TARGET).elf
    .PRECIOUS : $(OBJ)
    %.elf: $(OBJ)
    	@echo
    	@echo $(MSG_LINKING) $@
    	$(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS)
    # Compile: create object files from C source files.
    $(OBJDIR)/%.o : %.c
    	@echo
    	@echo $(MSG_COMPILING) $<
    	$(CC) -c $(ALL_CFLAGS) $< -o $@
    # Compile: create object files from C++ source files.
    $(OBJDIR)/%.o : %.cpp
    	@echo
    	@echo $(MSG_COMPILING_CPP) $<
    	$(CC) -c $(ALL_CPPFLAGS) $< -o $@
    # Compile: create assembler files from C source files.
    %.s : %.c
    	$(CC) -S $(ALL_CFLAGS) $< -o $@
    # Compile: create assembler files from C++ source files.
    %.s : %.cpp
    	$(CC) -S $(ALL_CPPFLAGS) $< -o $@
    # Assemble: create object files from assembler source files.
    $(OBJDIR)/%.o : %.S
    	@echo
    	@echo $(MSG_ASSEMBLING) $<
    	$(CC) -c $(ALL_ASFLAGS) $< -o $@
    # Create preprocessed source for use in sending a bug report.
    %.i : %.c
    	$(CC) -E -mmcu=$(MCU) -I. $(CFLAGS) $< -o $@
    # Target: clean project.
    clean: begin clean_list end
    clean_list :
    	@echo
    	@echo $(MSG_CLEANING)
    	$(REMOVE) $(TARGET).hex
    	$(REMOVE) $(TARGET).eep
    	$(REMOVE) $(TARGET).cof
    	$(REMOVE) $(TARGET).elf
    	$(REMOVE) $(TARGET).map
    	$(REMOVE) $(TARGET).sym
    	$(REMOVE) $(TARGET).lss
    	$(REMOVEDIR) $(OBJDIR)
    	$(REMOVE) $(SRC:.c=.s)
    	$(REMOVE) $(SRC:.c=.d)
    	$(REMOVEDIR) .dep
    # Create object files directory
    $(shell mkdir $(OBJDIR) 2>/dev/null)
    # Include the dependency files.
    -include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
    # Listing of phony targets.
    .PHONY : all begin finish end sizebefore sizeafter gccversion \
    build elf hex eep lss sym coff extcoff \
    clean clean_list program debug gdb-config
    GRAZ
    Hallo..
    Möchte keiner dazu was sagen ? Bild
    Kann mir vielleicht jemand sein Makfile schicken?
    (vielleicht komme ich dann ein bisschen weiter..)
    Vielleicht jemand, der auch AVRDUDE verwendet?!
    Oder , welche ISP Programme verwendet ihr ?
    l.G. Roberto
    was hast du fuer Sourcedateien (*.c, *.cpp)?
    ich denke du hast deinen Code in Meines.c und nicht in main.cpp
    aendere einfach in dem letzten Makefile die Zeile
    CPPSRC = main.cpp
    in
    CPPSRC =
    und die Zeile
    SRC =
    in
    SRC = Meines.c
    oder besser noch in
    SRC =$(TARGET).c
    um mit AVRDUDE zu programmieren gibst du statt 'make' einfach 'make program' ein.
    HTH
    GRAZ
    Hallo fluchtpunkt
    Danke für die Antwort.
    Hat sich jetzt erledigt.
    Mir ist das alles zu kompliziert.
    Habe den Download zum AVR jetzt einfach mit dem Bascom gemacht.
    Bin ich gewohnt und ist auch nicht viel mehr Aufwand.
    (mit Bascom das Bin-File laden und dann brennen...)
    Bin jetzt sowieso am überlegen, ob ich nicht gleich auf Code Vision umsteige.
    Da ist dann alles in einem und ich muss mich nicht mit dem blöden Makfile herrumschlagen...
    Jedesmal wenn man den Filename ändert (z.B.Versionen o.ä.) muss man das auch im Makefile ändern.
    l.G. Roberto
