Ergebnis 1 bis 10 von 10
Thema: AVR Mega8 + SHT75
    Coburg
    AVR Mega8 + SHT75
    habe folgendes Problem:
    Ich habe einen AVR ATMega8, der einen Sensor SHT75 (Feuchte und Themperatur) auslesen soll. Später soll das ganze dann auf einem Display dargestellt werden und 3 Ausgänge abhängig von der Themperatur bzw. Luftfeuchte geschaltet werden.
    Nun, hier mal das Programm:
     ' Basic application for sensor SHT75. Humidity measuring is 8 bit and tempera-'
     ' ture is 12 bit resolution. Result is display on 16 char LCD module .        '
     ' Sensor DATA pin is connect on PD1 and SCK on PD0. One LED is connect on PD2 '
     ' MCU pin to indicate measuring sequence.                                     '
     ' Program size is 1800 bytes                                                  '
    $regfile = "m8def.dat"
    $crystal = 16000000                                          ' used crystal frequency
    $baud = 9600                                                ' use baud rate
    $hwstack = 32                                               ' default use 32 for the hardware stack
    $swstack = 32                                               ' default use 10 for the SW stack
    $framesize = 32                                             ' default use 40 for the frame space
    'Config Lcd = 16 * 1
    'Config Lcdpin = Pin , Db4 = Portb.4 , Db5 = Portb.5 , Db6 = Portb.6 , Db7 = Portb.7 , E = Portb.3 , Rs = Portb.2
    Dim Command As Byte , Msb As Byte , Lsb As Byte , Humi As Word
    Dim I As Byte , Temp As Word , Celi As Word , Deseti As Word , Big_celi As Word
    Deflcdchar 0 , 6 , 9 , 9 , 6 , 32 , 32 , 32 , 32            'Creating "°" character
    Sck Alias Portd.6                                           'Serial CLOCK
    Sdata Alias Pind.7                                          'Serial DATA for INPUT
    Sdata_out Alias Portd.7                                     'Serial DATA for OUTPUT
          Ddrd.6 = 1                                            'Data direction for SCK
    Config Watchdog = 2048                                      'Watchdog time setting
          Start Watchdog                                        'watchdog enable
          'Cursor Off
          'Cls                                                   'LCD must move back to DATA mode  after creating chr
          'Waitms 20                                             'Must wait to stabilize LCD
    Start1:                                                     'Main program
          'Ddrd.2 = 1
          Ddrd.6 = 1
          'Set Portd.2                                           'Switch ON LED (measuring start)
          Command = &B00011110                                  'SOFTWARE RESET command
          Gosub Trans_start
          Gosub Send_cmd
          Gosub Write_status
          Gosub Conn_reset
          Gosub Read_humidity
          Gosub Conn_reset
          Gosub Read_temp
          'Cursor Off
          'Reset Portd.2                                         'Switch OFF LED (measuring finish)
          'Cls                                                   ' Clear display
          'Waitms 10
          'Locate 1 , 5
          'Lcd "%RH"
          'Locate 1 , 2
          'Lcd Humi
          Print "Luftfeuchte: " ; Humi ; " %"
          'If Celi < 10 Then
          '      Locate 1 , 10
          '      Lcd Celi
          'Else
          'Locate 1 , 9
          'End If
          'Lcd Celi
          'Locate 1 , 11
          'Lcd "."
          'Locate 1 , 12
          'Lcd Deseti
          'Locate 1 , 14
          'Lcd Chr(0)
          'Locate 1 , 15
          'Lcd "C"
          Print "Themperatur: " ; Celi ; "," ; Deseti ; " " ; Chr(167) ; "C"
          Print
          Reset Watchdog
    Powerdown
    ' HUMIDITY READ '
    Read_humidity:
          Command = &B00000101                                  'Command "READ HUMIDITY"
          Gosub Send_cmd
          Waitms 20                                             'Wait to finish measuring
          Gosub Sensor_readout
          Humi = 0                                              'Start of humidity calculation (see App. note)
          Humi = Humi + Msb
          Shift Humi , Left , 8
          Humi = Humi + Lsb
             If Humi <= 107 Then
                Humi = 143 * Humi
                    If Humi < 512 Then Humi = 512
                    Humi = Humi - 512
             Else
                Humi = 111 * Humi
                Humi = Humi + 2893
                If Humi > 25600 Then Humi = 25600
             End If
           Shift Humi , Right , 8
    Return
    ' TEMPERATURE READ '
    Read_temp:
          Command = &B00000011                                  'Command "READ TEMPERATURE"
          Gosub Send_cmd
          Waitms 60
          Temp = 0                                              'Calculation (see App. note)
          Temp = Temp + Msb
          Shift Temp , Left , 8
          Temp = Temp + Lsb
          Temp = Temp * 10
          Temp = Temp / 25
          Temp = Temp - 400
          Celi = Temp / 10
          Big_celi = Celi * 10
          Deseti = Temp - Big_celi
    Return
    ' TRANSMISION START'
    Trans_start:
          Config Sdata = Output
          Set Sdata_out
          Set Sck
          Reset Sdata_out
          Reset Sck
          Waitus 5
          Set Sck
          Set Sdata_out
          Reset Sck
    Return
    ' CONNECTION RESET '
    Conn_reset:
          Reset Sck
          Set Sdata_out
          For I = 1 To 12
             Set Sck
             Reset Sck
          Next I
          Goto Trans_start
    Return
    ' COMMAND SEND '
    Send_cmd:
             Shiftout Sdata_out , Sck , Command , 1             ', 8 , 1     'data change when sck goes low, 8bit out, 1uS delay
             Ddrd.7 = 0
             Reset Sck
             Set Sck
          Bitwait Sdata , Reset                                 'Wait ACK
          Reset Sck
    Return
    Sensor_readout:
          Config Sdata = Input
          Shiftin Sdata , Sck , Msb , 1 , 8 , 1
             Reset Sdata_out
             Set Sck
             Reset Sck
          Shiftin Sdata , Sck , Lsb , 1 , 8 , 1
          Set Sdata_out                                         'pull-up ACK (CRC not use)
          Set Sck
          Reset Sck
    Return
    Write_status:
          Gosub Trans_start
          Command = &B00000110
          Gosub Send_cmd
          Command = &B00000001                                  'Switch to 8/12 bit resolution
          Gosub Send_cmd
    Return
    End
    Das Problem ist nun, das auf der RS232 Schnittstelle immer das gleiche ankommt:
    Luftfeuchte: 0 %
    Themperatur: 11,2 °C
    Anscheinend wird der SHT nicht richtig angesprochen oder so.
    Kann mir evtl. jemand helfen?
    Danke
    Danke
    Christian
    [Meine Projekte]
    Coburg
    habe jetzt mal den Sensor auf andere Ports gelegt (PD4 und PD5) allerdings mit dem gleichen Ergebnis! Bild
    Auch ein anderes Beispiel Programm:
    'Routine to read the  SHT75 Humidity sensor chip
    'By Stuart Leslie
    'Contact stu@4sightinc.com with any questions
    'Uses BascomAVR
    'a .01 uf capacitor across VCC and Ground on the SHT75 really cleans up the data
    'a pullup is required on "data" pin as shown in the data sheet
    Dim Ctr As Byte
    Dim Dataword As Word
    Dim Command As Byte
    Dim Dis As String * 20
    Dim Calc As Single
    Dim Calc2 As Single
    Dim Rhlinear As Single
    Dim Rhlintemp As Single
    Dim Tempc As Single
    'Dim Tempf As Single
    Const C1 = -4
    Const C2 = 0.0405
    Const C3 = -0.0000028
    Const T1c = .01
    Const T2 = .00008
    'Const T1f = .018
    Sck Alias Portd.4
    Dataout Alias Portd.5
    Datain Alias Pind.5
    'Redled Alias PortD.2
    Declare Sub Getit()
    Ddrd = &B11111111                                           'all port b are output
    Config Pind.4 = Output                                      'sck
    Config Pind.5 = Output                                      'datain
    'reset the serial communications first, it is easily confused!
    Set Dataout
    For Ctr = 1 To 12
       Set Sck
       Waitus 2
       Reset Sck
       Waitus 2
    Next Ctr
    Do                                                          'continually read the tempfature and humidity
       Call Getit                                               'Get the temperature, puts result in "dataword" for us
       'Tempf = T1f * Dataword
       'Tempf = Tempf - 40
       Tempc = T1c * Dataword                                   'get celcius for later calculations and for "the rest of the world"
       Tempc = Tempc - 40
       Dis = Fusing(tempc , "###.##")
       Print "Temperatur = " ; Dis ; Chr(167) ; "C"
       Call Getit                                               'get the humidity
       Calc = C2 * Dataword
       Calc2 = Dataword * Dataword                              'that "2" in the datasheet sure looked like a footnote for a couple days, nope it means "squared"!
       Calc2 = C3 * Calc2
       Calc = Calc + C1
       Rhlinear = Calc + Calc2
       'Dis = Fusing(rhlinear , "##.##")
       'Print "Humidity adjusted for linear = " ; Dis
       Calc = T2 * Dataword
       Calc = Calc + T1c
       Calc2 = Tempc - 25
       Calc = Calc2 * Calc
       Rhlintemp = Calc + Rhlinear
       Dis = Fusing(rhlintemp , "##.##")
       Print "Luftfeuchte  = " ; Dis ; " %"
       Wait 1
    Sub Getit()
       Local Datavalue As Word
       Local Databyte As Byte
       'start with "transmission start"
       Set Sck
       Reset Dataout
       Reset Sck
       Set Sck
       Set Dataout
       Reset Sck
       'now send the  command
       Shiftout Dataout , Sck , Command , 1
       Ddrd = &B11111101                                        'datain is now input
       Config Pind.5 = Input                                    'datain
       Set Sck                                                  'click one more off
       Reset Sck
       Waitus 10                                                'no idea why, but it doesn't work without it!
       Bitwait Pind.7 , Reset                                   'wait for the chip to have data ready
       Shiftin Datain , Sck , Databyte , 1                      'get the MSB
       Datavalue = Databyte
       Ddrd = &B11111111
       Reset Dataout                                            'this is the tricky part- Lot's of hair pulling- have to tick the ack!
       Set Sck
       Reset Sck
       Shiftin Datain , Sck , Databyte , 1                      'get the LSB
       Shift Datavalue , Left , 8
       Datavalue = Datavalue Or Databyte
       'don't tick the clock or ack since we don't need the CRC value, leave it hanging!
       Dataword = Datavalue
       Ddrd = &B11111111
       Reset Dataout
       Set Sck
       Reset Sck
       Shiftin Datain , Sck , Databyte , 1                      'not using the CRC value for now- can't figure it out! Anybody know how to impliment?
       'Print "CRC value was - " ; Databyte
       Ddrd = &B11111111
       Set Dataout
       Set Sck
       Reset Sck
    End Sub
    End
    Funktionierte nicht!
    Ausgabe war immer:
    Temperatur = 612.80°C
    Luftfeuchte  = -6216.70 %
    Was kann das sein?
    Der Sensor ist in Ordung, an einer C-Control funktioniert er!!!
    Danke
    Christian
    [Meine Projekte]
    Coburg
    Es funktioniert!!!
    Wenn ich den Orginal-Code von:
    http://www.mcselec.com/index.php?opt...d=80&Itemid=57
    nehme und die Ports benutze, die dort angegeben sind (PB0 und PB1) dann geht es!!!
    Ich habe doch nur die Ports in dem Beispiel geändert!
    Evtl. habe ich wohl etwas vergessen???
    Nur was?
    Was muß angepasst werden, wenn ich andere Ports nehmen will?
    Danke für Eure Hilfe!!!
    Danke
    Christian
    [Meine Projekte]
    Berlin
    so wie ich es sehe, musst du die Register auch noch anpassen. (ddrb)
    Coburg
    ALso "Command = &B00000011" ändern in "Command = &D00000011" ???
    Oder "Ddrd = &B11111111" in "Ddrd = &D11111111" ???
    Danke
    Christian
    [Meine Projekte]
    sehr nice
    hab auch so nen sensor daheim nur noch nicht das richtige display. das muss ich mir noch zulegen.
    bist du schon weiter, würd es auch für temperaturabhängiges schalten benötigen, hätte an einen bestimmten temp bereich gedacht oder gibts hierfür eigenen Bascom befehle.
    piri
    meine aktuellen Projekte
    Sternenhimmel
    http://www.roboternetz.de/phpBB2/viewtopic.php?t=31439
    BuBoter - Roboter mit Antikolision
    http://www.roboternetz.de/phpBB2/viewtopic.php?t=31632
    hallo update
    hab jetzt auch meinen sht in betrieb genommen!
    hab sogar den sht75 damals gekauft, also rm1,27,
    programm funkt bei mir auch.
    das einzige was probleme macht dürfte die ausgabe sein (nichts wird angezeigt):
     Dis = Fusing(tempf , "###.##")
     Print "Temperature = " ; Dis ; " (F)"
    wenn ich das durch
    Lcd "Temperatu = " ; Tempc
     Print
     Waitms 999
     Cls
    ersetze funktioniert es problemlos (also wird was angezeigt)?!
    naja jedenfalls der sht funktioniert! und das auch noch sehr gut! hab daneben mein innen/außen termometer liegen und die toleranz liegt zwischen den beiden so bei 1-2%max!
    also top teil & problemlose montage an einem µc.
    der einzige nachteil ist der preis, naja man gönnt sich ja sonst kaum was.
    piri
    Sternenhimmel
    Sensor SHT11 defekt?
    ich habe den SHT11 SMD und bei mir bleibt das Programm hängen.
    Immer in der Sub bei
       Bitwait Pinb.4 , Reset                                   'wait for the chip to have data ready
    Kann es sein das der Sensor defekt ist?
    Am Programm und an der Config kann es nicht liegen, weil ich solch einen Sensor schon einmal verbaut habe. Diesen funktionierenden möchte ich aber nicht auslöten zum Testen.
    Funktioniert hatte, der wo jetzt nicht geht, schonmal mit dem Programm.
    Nur habe ich gestern eine andere Platine gelötet und nun geht er nicht mehr.
    Coburg
    Also bei mir läufte es prima!
    Habe eine Gewächshaussteuerung daraus gemacht!
    Bei bestimmten Temperaturen geht die Heizung oder ein Lüfter an!
    Und bei bestimmten Luftfeuchten geht das Fenster auf oder die Luftbefeuchtung springt an!
    Danke
    Christian
    [Meine Projekte]
    'By Stuart Leslie
    'Uses BascomAVR
    Dim Ctr As Byte
    Dim Command As Byte
    Dim Calc As Single
    Dim Calc2 As Single
    Dim Tempc As Single
    Const C1 = -4
    Const C2 = 0.0405
    Const T1c = .01
    Const T2 = .00008
    'Const T1f = .018
    Sck Alias Portd.4
    Datain Alias Pind.5
    Declare Sub Getit()
    Set Dataout
    For Ctr = 1 To 12
       Set Sck
       Waitus 2
       Reset Sck
       Waitus 2
    Next Ctr
       'Tempf = Tempf - 40
       Tempc = Tempc - 40
       Calc2 = C3 * Calc2
       Calc = Calc + C1
       Calc = Calc + T1c
       Calc2 = Tempc - 25
       Calc = Calc2 * Calc
       Wait 1
    Sub Getit()
       Set Sck
       Reset Dataout
       Reset Sck
       Set Sck
       Set Dataout
       Reset Sck
       Reset Sck
       Ddrd = &B11111111
       Set Sck
       Reset Sck
       Ddrd = &B11111111
       Reset Dataout
       Set Sck
       Reset Sck
       Ddrd = &B11111111
       Set Dataout
       Set Sck
       Reset Sck
    End Sub
    End
    Ausgabe war immer:
    Was kann das sein?
    Ich hab dasselbe Problem, irgendwie wird hier aber keine Lösung aufgezeigt. Kann sich nochmal einer der Lösung annehmen bitte?
