Thema: Programierhilfe für linienverfolgung
    Marbach am Neckar
    Hey
    ich habe folgendes Problem, nämlich das wenn ich das linienfolgeprogramm:
    // Program used by "myIrAsuro" in qualifying for competition
    // "Parallel Slalom" of RobotChallenge 2007 in Vienna (24th march):
    // http://www.robotchallenge.at
    // Time 10.1s for 354cm, that is speed 35.05cm/s (best was 60.00 cm/s).
    // myIrAsuro has reduction of 1:12.5 (Asuro standard is 1:25), see:
    // https://www.roboternetz.de/phpBB2/ze...ag.php?t=28876
    // The entries 0xFF for both SPEED values below will work on
    // a standard Asuro with speed < 0.5m/s.
    // The value for THRESHOLD must be changed if no IR-FrontLED
    // with white shield is used, see:
    // https://www.roboternetz.de/phpBB2/ze...ag.php?t=29109
    // Robot will have to be placed on the line for starting!
    // After starting the StatusLED of Asuro will blink [ready].
    // After (any) switch is pressed both BackLED's turn on [steady].
    // Releasing the switch will start the Robot [go].
    #include <asuro.h>
    #define OFF_LEFT  -1
    #define ON_LINE   0
    #define OFF_RIGHT +1
    #define SPEED  0xdF // 0xFF
    #define SPEED1 0xbF // 0xFF
    #define SPEED2 0x00
    #define THRESHOLD  1100
    void RaceStart(void); // blink until any switch is pressed,
                          // then wait until switch is released
    int main(void)
      unsigned int sum,data[2];
      int position = ON_LINE;
      Init();
      RaceStart();
      FrontLED(ON);
      MotorDir(FWD,FWD);
      MotorSpeed(SPEED,SPEED);
      while (1)                  // state machine: position on/off the line
        LineData(data);
        sum = data[LEFT] + data[RIGHT];
        if (sum>=THRESHOLD)      // not on the line
          if (position==ON_LINE) // switch state if previously on the line
            position = (data[LEFT]<data[RIGHT]) ? OFF_RIGHT : OFF_LEFT;
            BackLED( (position==OFF_LEFT)?ON:OFF, (position==OFF_RIGHT)?ON:OFF );
        else                     // on the line
          if (position!=ON_LINE) // switch state if previously not on the line
            position = ON_LINE;
            BackLED(OFF,OFF);
             if (position==ON_LINE)   { MotorSpeed(SPEED,SPEED);   } // full FWD
        else if (position==OFF_RIGHT) { MotorSpeed(SPEED2,SPEED1); } // turn left
        else if (position==OFF_LEFT)  { MotorSpeed(SPEED1,SPEED2); } // turn right
      while (1);                 // code unreachable
      return 0;
    void RaceStart(void)    // blink until any switch is pressed,
    {                       // then wait until switch is released
      uint8_t t1, t2;
      unsigned int col=OFF;
      while (1)             // blinking StatusLED until any switch is pressed
        t1 = PollSwitch();
        t2 = PollSwitch();
        if (t1==t2)
          if (t1)
            break;
          else
            col ^= GREEN;
            StatusLED(col);
        Msleep(50);
      StatusLED(OFF);       // turn off StatusLED and ...
      BackLED(ON,ON);       // ... turn on both BackLED's
      while (1)             // wait until switch is released
        t1 = PollSwitch();
        t2 = PollSwitch();
        if (t1==t2)
          if (!t1)
            break;
        Msleep(50);
      BackLED(OFF,OFF);     // turn off BackLED's indication start of race
    compilieren will kommt folgender error:
    > "C:\Asuro_src\Progs\Drei\Test-all.bat"
    C:\Asuro_src\Progs\Drei>make all
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > asuro.d; \
    [ -s asuro.d ] || rm -f asuro.d
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=Linie.lst Linie.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > Linie.d; \
    [ -s Linie.d ] || rm -f Linie.d
    -------- begin --------
    avr-gcc --version
    avr-gcc (GCC) 4.1.1 (WinAVR 20070122)
    Copyright (C) 2006 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions. There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=Linie.lst Linie.c -o Linie.o
    In file included from ./asuro.h:34,
    from Linie.c:25:
    c:/winavr/bin/../avr/include/avr/signal.h:36:2: warning: #warning "This header file is obsolete. Use <avr/interrupt.h>."
    Linie.c: In function 'main':
    Linie.c:58: error: 'LEFT' undeclared (first use in this function)
    Linie.c:58: error: (Each undeclared identifier is reported only once
    Linie.c:58: error: for each function it appears in.)
    Linie.c:58: error: 'RIGHT' undeclared (first use in this function)
    Linie.c: In function 'RaceStart':
    Linie.c:114: warning: implicit declaration of function 'Msleep'
    make: *** [Linie.o] Error 1
    > Process Exit Code: 2
    was mach ich falsch.
    Ach jaich hab mir die lib 2.7 installiert(*.exe) kann es vieleicht daran liegen das ich deswegen noch was einstellen muss?
    Erfahrener Benutzer Roboter Genie Avatar von m.a.r.v.i.n
    Berlin
    hast du die Lib in das vorgeschlage Verzeichnis installiert (c:\ASURO_SRC\AsuroLib) oder woanders?
    Das Lib Verzeichnis und das Examples Verzeichnis müssen in der gleichen Verzeichnisebene stehen wie dein Progs Verzeichnis, sonst klappt es mit den Makefiles nicht.
    Scheinbar steht in dem Verzeichnis Progs\Drei noch eine alte asuro.h evtl. auch noch eine asuro.c. Die müssen beide weg.
    Auch solltest du statt in eckigen Klammern
    #include "asuro.h"
    schreiben.
    Im Makefile für dein Projekt muß dann lediglich noch der Targetname auf linie umbenannt werden. Kopiere dazu z.B. das Makefile aus dem Examples\FirstTry in den Progs\Drei Ordner.
    TARGET = linie
    Dann sollte alles funktionieren.
    Marbach am Neckar
    ok werd ich morgen ma probieren vielen dank.
    Christian
