Thema: USB-Übertragung mit FTDI 245AM und AT90S2333
    Bremen
    Ich möchte Daten vom AD-Wandler über den USB-Bus übertragen. Leider gibt es ein Problem und zwar werden mehr Bytes übertragen als ich senden will. Das Programm sieht folgendermaßen aus:
    ; uC: Atmel, AT90s2333
    ; Used PINs:
    ;	+5V, GND        - power supply
    ;	ADC0...ADC5     - ADC
    ;	PD0..7			- Data I/O
    ;	PB0				- RXF#	(IN)
    ;	PB1				- TXF#	(IN)
    ;	PB2				- WR	(OUT)
    ;	PB3				- RD#	(OUT)
    ;   Further connection for XTAL and ADC see manual.
    ;   (8 MHz)
    .include "2333def.inc"
    ;***** Register definitions *****
    .equ    tmp,            16
    .equ	data,			17
    .equ	adc_lo, 		18
    .equ	adc_hi,			19
    .equ	bool,			20
    ;***** Bit definitions **********
    .equ	RXF,			0		; bit number
    .equ 	TXF,			1		; bit number
    .equ	WR,				2		; bit value
    .equ	RD,				3		; bit value
    ;***** Interrupt Vectors ********
            RJMP RESET              ; Reset         - Hardware Pin, Power-on Reset, Watchdog Reset
            reti				    ; INT0          - external interrupt request 0
            reti                    ; INT1          - external interrupt request 1
            reti                    ; Timer1 capt1  - timer/counter1 capture event
            reti                    ; Timer1 comp1  - timer/counter1 compare mach
            reti                    ; Timer1 ovf1   - timer/counter1 overflow
            reti                    ; Timer0 ovf0   - timer/counter0 overflow
            reti                    ; SPI           - SPI interrupt
            reti                    ; Uart, Rx      - UART, RX complete
            reti                    ; Uart, UDRE    - UART Data Register Empty
            reti                    ; Uart, Tx      - Uart, TX complete
            RJMP ADC_Interrupt	    ; ADC           - ADC interupt
            reti                    ; EEPROM        - EEPROM Interrupt
            reti                    ; Ana_comp      - Analog Comparator
    ADC_Interrupt:
    	IN      r0,SREG
    	IN		adc_lo,ADCL
    	IN		adc_hi,ADCH
    	LDI		bool,1
    	OUT		SREG,r0
    	reti
    SendData:
    	LDI		tmp,0xFF			; PORTD as ouput
    	OUT		DDRD,tmp
    	LDI		adc_lo,65
    	LDI		adc_hi,65
    	LDI		tmp,0x00			; select channel 0
    	OUT		ADMUX,tmp
    	LDI		tmp,0xCF			; start AD conversion
    	OUT		ADCSR,tmp
    	LDI 	bool,0
    WAIT:
    	CPI		bool,1
    	BRNE	WAIT
    	LDI		tmp,0
    	OUT		PORTD,adc_lo		; send low byte
    	SBI		PORTB,WR			; set WR bit
    	CBI		PORTB,WR			; clear WR bit
    	LDI		tmp,0
    	OUT		PORTD,adc_hi		; send high byte
    	NOP
    	NOP
    	LDI		tmp,0x00			; PORTD as input
    	OUT		DDRD,tmp
    	OUT		PORTD,tmp
    	RET
    RESET:
    	LDI     tmp,0x80			; init 32 byte stack
    	OUT     SPL,tmp
    								; PD0..7 as Data I/O
        OUT     DDRD,tmp
        OUT     PORTD,tmp           ; Pull-ups off
    								; PB0..3 as Control
    	LDI		tmp,0xFC			; PB2,PB3 as Output
    	OUT		DDRB,tmp
    	LDI		tmp,0x08			; WR,RD# inactiv
    	OUT		PORTB,tmp
    	LDI		tmp,0x80			; GIE
    	OUT		SREG,tmp
    MAIN:
    	IN		tmp,PINB			; read Control bits
    	SBRC	tmp,RXF				; Skip if Bit in Register is Clear = Data available
    	RJMP	NoData
    	CBI		PORTB,RD			; clear READ# bit
    	NOP
    	NOP
    	IN		data,PIND			; read Data
    	SBI		PORTB,RD			; set RD# bit
    	CPI		data,0x01			; send data?
    	BRNE	NotDataCommand
    	RCALL	SendData
    NotDataCommand:
    NoData:
    	RJMP 	MAIN
    Wenn ich die Datenblätter richtig verstanden habe, sollte das Programm beim empfangen von "1" zwei Bytes senden. Gesendet wird aber folgendes:
    Wenn ich ein Poti am ADC0 gegen Masse gedreht habe erhalte ich folgendes:
    0, 1, 0 - 2. und 3. Byte sind richtig (= ADC_lo/hi)
    Wenn ich es gegen +5V gedreht habe erhalte ich die Bytes:
    0, 127, 3, 3 - 2. und 3. sind richtig (= ADC_lo/hi)
    Ich habs auch mal ausprobiert nur den PORTD von Input auf Output umschalten selbst dann wird ein Byte gesendet.
    Vermuten tue ich das es beim Umschalten des PORTD irgendwie zu störungen kommen muss die ein Schreiben des Bytes auslösen, was wohl an meinem Steckbrett aufbau liegen könnte.
    Hat jemand sonst eine Idee?
    Bremen
    Ich denke, ich habe das Problem gefunden. Hab folgendes in der Knowledgebase von FTDI gefunden:
    Why do I get repeated data when I read from the FT245BM?
    The WR and RD pins may be driven too hard, which can cause ringing on the lines. This can result in corrupted data because WR and RD are edge sensitive. Fitting series resistors to the WR and RD pins in the range 20-40W close to the microcontroller should remedy the problem.
    Nachdem ich nun 24 Ohm in die WR-Leitung eingbaut habe scheint es zu funktionieren.
