Hi, vielen Danke für die Hilfe.
Nur compilieren tut das leider nicht:
Zeile 44 ist diese hier:Code:avr-gcc.exe -I"E:\mathias\projects\avr.projects\rnbfra_led\." -mmcu=atmega32 -Wall -gdwarf-2 -O0 -fsigned-char -MD -MP -MT rnbfra_led.o -MF dep/rnbfra_led.o.d -c ../rnbfra_led.c ../rnbfra_led.c: In function 'main': ../rnbfra_led.c:44: error: expected expression before '=' token ../rnbfra_led.c:44: error: 'H72' undeclared (first use in this function) ../rnbfra_led.c:44: error: (Each undeclared identifier is reported only once ../rnbfra_led.c:44: error: for each function it appears in.) make: *** [rnbfra_led.o] Error 1 Build failed with 4 errors and 0 warnings...
kA was da falsch sein soll.Code:TWI_buf[0] = Writepowerport_adr;
Zitieren
