also folgene änderung habe ich gemacht so sah die alte i2cmaster.h aus
und so sieht meine aus änderung ausCode:#ifndef _I2CMASTER_H #define _I2CMASTER_H 1 /************************************************************************* * Title: C include file for the I2C master interface * (i2cmaster.S or twimaster.c) * Author: Peter Fleury <pfleury@gmx.ch> http://jump.to/fleury * File: $Id: i2cmaster.h,v 1.10 2005/03/06 22:39:57 Peter Exp $ * Software: AVR-GCC 3.4.3 / avr-libc 1.2.3 * Target: any AVR device * Usage: see Doxygen manual **************************************************************************/ #ifdef DOXYGEN /** @defgroup pfleury_ic2master I2C Master library @code #include <i2cmaster.h> @endcode @brief I2C (TWI) Master Software Library Basic routines for communicating with I2C slave devices. This single master implementation is limited to one bus master on the I2C bus. This I2C library is implemented as a compact assembler software implementation of the I2C protocol which runs on any AVR (i2cmaster.S) and as a TWI hardware interface for all AVR with built-in TWI hardware (twimaster.c). Since the API for these two implementations is exactly the same, an application can be linked either against the software I2C implementation or the hardware I2C implementation. Use 4.7k pull-up resistor on the SDA and SCL pin. Adapt the SCL and SDA port and pin definitions and eventually the delay routine in the module i2cmaster.S to your target when using the software I2C implementation ! Adjust the CPU clock frequence F_CPU in twimaster.c or in the Makfile when using the TWI hardware implementaion. @note The module i2cmaster.S is based on the Atmel Application Note AVR300, corrected and adapted to GNU assembler and AVR-GCC C call interface. Replaced the incorrect quarter period delays found in AVR300 with half period delays. @author Peter Fleury pfleury@gmx.ch http://jump.to/fleury @par API Usage Example The following code shows typical usage of this library, see example test_i2cmaster.c @code #include <i2cmaster.h> #define Dev24C02 0xA2 // device address of EEPROM 24C02, see datasheet int main(void) { unsigned char ret; i2c_init(); // initialize I2C library // write 0x75 to EEPROM address 5 (Byte Write) i2c_start_wait(Dev24C02+I2C_WRITE); // set device address and write mode i2c_write(0x05); // write address = 5 i2c_write(0x75); // write value 0x75 to EEPROM i2c_stop(); // set stop conditon = release bus // read previously written value back from EEPROM address 5 i2c_start_wait(Dev24C02+I2C_WRITE); // set device address and write mode i2c_write(0x05); // write address = 5 i2c_rep_start(Dev24C02+I2C_READ); // set device address and read mode ret = i2c_readNak(); // read one byte from EEPROM i2c_stop(); for(;;); } @endcode */ #endif /* DOXYGEN */ /**@{*/ #if (__GNUC__ * 100 + __GNUC_MINOR__) < 304 #error "This library requires AVR-GCC 3.4 or later, update to newer AVR-GCC compiler !" #endif #include <avr/io.h> /** defines the data direction (reading from I2C device) in i2c_start(),i2c_rep_start() */ #define I2C_READ 1 /** defines the data direction (writing to I2C device) in i2c_start(),i2c_rep_start() */ #define I2C_WRITE 0 /** @brief initialize the I2C master interace. Need to be called only once @param void @return none */ extern void i2c_init(void); /** @brief Terminates the data transfer and releases the I2C bus @param void @return none */ extern void i2c_stop(void); /** @brief Issues a start condition and sends address and transfer direction @param addr address and transfer direction of I2C device @retval 0 device accessible @retval 1 failed to access device */ extern unsigned char i2c_start(unsigned char addr); /** @brief Issues a repeated start condition and sends address and transfer direction @param addr address and transfer direction of I2C device @retval 0 device accessible @retval 1 failed to access device */ extern unsigned char i2c_rep_start(unsigned char addr); /** @brief Issues a start condition and sends address and transfer direction If device is busy, use ack polling to wait until device ready @param addr address and transfer direction of I2C device @return none */ extern void i2c_start_wait(unsigned char addr); /** @brief Send one byte to I2C device @param data byte to be transfered @retval 0 write successful @retval 1 write failed */ extern unsigned char i2c_write(unsigned char data); /** @brief read one byte from the I2C device, request more data from device @return byte read from I2C device */ extern unsigned char i2c_readAck(void); /** @brief read one byte from the I2C device, read is followed by a stop condition @return byte read from I2C device */ extern unsigned char i2c_readNak(void); /** @brief read one byte from the I2C device Implemented as a macro, which calls either i2c_readAck or i2c_readNak @param ack 1 send ack, request more data from device 0 send nak, read is followed by a stop condition @return byte read from I2C device */ extern unsigned char i2c_read(unsigned char ack); #define i2c_read(ack) (ack) ? i2c_readAck() : i2c_readNak(); /**@}*/ #endif
Code:#ifndef _I2CMASTER_H #define _I2CMASTER_H 1 /************************************************************************* * Title: C include file for the I2C master interface * (i2cmaster.S or twimaster.c) * Author: Peter Fleury <pfleury@gmx.ch> http://jump.to/fleury * File: $Id: i2cmaster.h,v 1.10 2005/03/06 22:39:57 Peter Exp $ * Software: AVR-GCC 3.4.3 / avr-libc 1.2.3 * Target: any AVR device * Usage: see Doxygen manual **************************************************************************/ #ifdef DOXYGEN /** @defgroup pfleury_ic2master I2C Master library @code #include <i2cmaster.h> @endcode @brief I2C (TWI) Master Software Library Basic routines for communicating with I2C slave devices. This single master implementation is limited to one bus master on the I2C bus. This I2C library is implemented as a compact assembler software implementation of the I2C protocol which runs on any AVR (i2cmaster.S) and as a TWI hardware interface for all AVR with built-in TWI hardware (twimaster.c). Since the API for these two implementations is exactly the same, an application can be linked either against the software I2C implementation or the hardware I2C implementation. Use 4.7k pull-up resistor on the SDA and SCL pin. Adapt the SCL and SDA port and pin definitions and eventually the delay routine in the module i2cmaster.S to your target when using the software I2C implementation ! Adjust the CPU clock frequence F_CPU in twimaster.c or in the Makfile when using the TWI hardware implementaion. @note The module i2cmaster.S is based on the Atmel Application Note AVR300, corrected and adapted to GNU assembler and AVR-GCC C call interface. Replaced the incorrect quarter period delays found in AVR300 with half period delays. @author Peter Fleury pfleury@gmx.ch http://jump.to/fleury @par API Usage Example The following code shows typical usage of this library, see example test_i2cmaster.c @code #include <i2cmaster.h> #define 0x74 // device address of 0x74, see datasheet int main(void) { unsigned char ret; i2c_init(); // initialize I2C library // write 0x75 to EEPROM address 5 (Byte Write) i2c_start_wait(0x74+I2C_WRITE); // set device address and write mode i2c_write(0x05); // write address = 5 i2c_write(0x75); // write value 0x75 to EEPROM i2c_stop(); // set stop conditon = release bus // read previously written value back from EEPROM address 5 i2c_start_wait(0x74+I2C_WRITE); // set device address and write mode i2c_write(0x05); // write address = 5 i2c_rep_start(0x74+I2C_READ); // set device address and read mode ret = i2c_readNak(); // read one byte from EEPROM i2c_stop(); for(;;); } @endcode */ #endif /* DOXYGEN */ /**@{*/ #if (__GNUC__ * 100 + __GNUC_MINOR__) < 304 #error "This library requires AVR-GCC 3.4 or later, update to newer AVR-GCC compiler !" #endif #include <avr/io.h> /** defines the data direction (reading from I2C device) in i2c_start(),i2c_rep_start() */ #define I2C_READ 1 /** defines the data direction (writing to I2C device) in i2c_start(),i2c_rep_start() */ #define I2C_WRITE 0 /** @brief initialize the I2C master interace. Need to be called only once @param void @return none */ extern void i2c_init(void); /** @brief Terminates the data transfer and releases the I2C bus @param void @return none */ extern void i2c_stop(void); /** @brief Issues a start condition and sends address and transfer direction @param addr address and transfer direction of I2C device @retval 0 device accessible @retval 1 failed to access device */ extern unsigned char i2c_start(unsigned char addr); /** @brief Issues a repeated start condition and sends address and transfer direction @param addr address and transfer direction of I2C device @retval 0 device accessible @retval 1 failed to access device */ extern unsigned char i2c_rep_start(unsigned char addr); /** @brief Issues a start condition and sends address and transfer direction If device is busy, use ack polling to wait until device ready @param addr address and transfer direction of I2C device @return none */ extern void i2c_start_wait(unsigned char addr); /** @brief Send one byte to I2C device @param data byte to be transfered @retval 0 write successful @retval 1 write failed */ extern unsigned char i2c_write(unsigned char data); /** @brief read one byte from the I2C device, request more data from device @return byte read from I2C device */ extern unsigned char i2c_readAck(void); /** @brief read one byte from the I2C device, read is followed by a stop condition @return byte read from I2C device */ extern unsigned char i2c_readNak(void); /** @brief read one byte from the I2C device Implemented as a macro, which calls either i2c_readAck or i2c_readNak @param ack 1 send ack, request more data from device 0 send nak, read is followed by a stop condition @return byte read from I2C device */ extern unsigned char i2c_read(unsigned char ack); #define i2c_read(ack) (ack) ? i2c_readAck() : i2c_readNak(); /**@}*/ #endif
Zitieren
