Hallo raid_ox,
vermutlich sollte es so gehen...
(dies ist ein ausschnitt aus dem Yeti Init Funktion, der funktioniert gleich wie Asuro)
Gruss,Code://------------------------------------------------------------// // Init USART for RS232 communication // //------------------------------------------------------------// // Init Atmega USART for RS232 communication (connected to Yeti InfraRed transmitter/receiver) // default init UCSRA=0x00; // default init UCSRB=0x00; // select UCSRC, no parity, 1 stop bit, 8 databits per character UCSRC=(1<<URSEL)|(1<<UCSZ1)|(1<<UCSZ0); // select baudrate 2400bps when using 8.0000MHz oscillator (see table 62 in pdf) UBRRL=0xCF; //------------------------------------------------------------// // Init Timer2, used for generating RS232 IR carrier signal // //------------------------------------------------------------// // prepare 36kHz for IR - Communication // WGM21: waveform generation mode 2 => CTC mode => TOP = OCR2 // (Only counting up until value OCR2 (TOP) reached) // COM20: Toggle OC2 on Compare Match // CS20: No prescaling (so Timer2 clock frequency = 8MHz = 125ns) TCCR2=(1<<WGM21)|(1<<COM20)|(1<<CS20); // 0x6E = 110, so frequency is 110 * 125ns = 13.75us = 72.727KHz // as output is toggled, the real frequency is 72.727KHz / 2 = appr. 36KHz OCR2=0x6E; //------------------------------------------------------------// // Set 36KHz carrier pin as output //------------------------------------------------------------// // set carrier signal pin PB3/(MOSI/OC2) as output DDRB|=(1<<PB3);
Henk
Zitieren
