hmm, es funktioniert immer noch nicht... (-.-).
ich habe DDRB |= (1 << PB3); hinzugefügtCode:void Init(void) { //-------- serial interface programmed in boot routine and already running ------- DDRB |= (1 << PB3); // prepare 36kHz for IR - Communication TCCR2 = (1 << WGM20) | (1 << WGM21) | (1 << COM20) | (1 << COM21) | (1 << CS20); OCR2 = 0x91; // duty cycle for 36kHz TIMSK |= (1 << TOIE2); // 36kHz counter for sleep // prepare RS232 UCSRA = 0x00; UCSRB = 0x00; UCSRC = 0x86; // No Parity | 1 Stop Bit | 8 Data Bit UBRRL = 0xCF; // 2400bps @ 8.00MHz // I/O Ports DDRB = IRTX | LEFT_DIR | PWM | GREEN_LED; DDRD = RIGHT_DIR | FRONT_LED | ODOMETRY_LED | RED_LED; // for PWM (8-Bit PWM) on OC1A & OC1B TCCR1A = (1 << WGM10) | (1 << COM1A1) | (1 << COM1B1); // tmr1 running on MCU clock/8 TCCR1B = (1 << CS11); // A/D Conversion ADCSRA = (1 << ADEN) | (1 << ADPS2) | (1 << ADPS1); // clk/64 ODOMETRY_LED_OFF; FrontLED(OFF); BackLED(ON,ON); BackLED(OFF,OFF); StatusLED(GREEN); MotorState(FWD,FWD); MotorSpeed(0, 0); sei(); }
was heißt eigentlich "serial interface programmed in boot routine and already running" ???
Zitieren
