Code:define a 97 define b 98 define c 99 define d 100 define e 101 define f 102 define g 103 define h 104 define i 105 define j 106 define k 107 define l 108 define m 109 define n 110 define o 111 define p 112 define q 113 define r 114 define s 115 define t 116 define u 117 define v 118 define w 119 define x 120 define y 121 define z 122 define lcd byteport[2] define rw port[13] define rs port[14] define enable port[15] define buffer byte define parameter byte define zahl word define ziffer byte gosub initialisierung pause 10 #sync if year<97 then beep 150,50,0 else goto sync beep 150,25,25 #loop gosub lcd_out goto loop #lcd_out parameter=1 gosub whichline parameter=e-32 gosub writeletter parameter=s gosub writeletter parameter=32 gosub writeletter parameter=i gosub writeletter parameter=s gosub writeletter parameter=t gosub writeletter parameter=32 gosub writeletter zahl=hour ziffer=zahl/10 parameter=ziffer+48 gosub writeletter zahl=zahl-ziffer*10 ziffer=zahl parameter=ziffer+48 gosub writeletter parameter=58 gosub writeletter zahl=minute ziffer=zahl/10 parameter=ziffer+48 gosub writeletter zahl=zahl-ziffer*10 ziffer=zahl parameter=ziffer+48 gosub writeletter parameter=58 gosub writeletter zahl=second ziffer=zahl/10 parameter=ziffer+48 gosub writeletter zahl=zahl-ziffer*10 ziffer=zahl parameter=ziffer+48 gosub writeletter return #initialisierung lcd=off parameter=&h38:gosub command lcd=&b00000010 tog enable tog enable parameter=&h28:gosub command parameter=&h0c:gosub command #clear parameter=&h02:gosub command parameter=&h02:gosub command return #whichline if parameter=1 then parameter=&h80 if parameter=2 then parameter=&hc0 goto command #command buffer=off goto write_ #writeletter buffer=&b00100000 #write_ lcd=buffer or (parameter shr 4) tog enable tog enable lcd=buffer or (parameter and &h0f) tog enable tog enable return
Zitieren
