Thema: ARM 7, Keil und Interrupt
    Ich versuche auf einem ARM7 Intterupts zu benutzen. Der Timer läuft richtig, nur Interrupts bekomme ich noch nicht... Welche Register hab ich vergessen?
    Danke schon einmal!
    #include <LPC21xx.H>
    // olimex LPC-P2129: LEDs on P0.12/P0.13 (active low)
    #define LED1PIN  	12
    #define LED2PIN  	13
    void T0IRQ (void) __irq;
    unsigned short switcher = 0;
    int main(void)
    //INIT
    	// define LED-Pins as outputs
    	IODIR0 |= 1<<LED1PIN;
    	// set Bits = LEDs off (active low)
    	IOSET0 = 1<<LED1PIN;
    	//Sets peripheral clock = system clock
    	VPBDIV=0x01;
    	//initialise timer 0
    	T0TCR = 0x0;
    	T0TC  = 0x0;
    	T0PR  = 0x0;
    	T0PC  = 0x0;
    	T0MR0 = 0xFF;
    	//Reset and interrupt on match
    	T0MCR = 0x3;
    	//TELL VIC WHAT TO DO!
    	VICIntSelect = 0x0; //NO FIQs
    	VICIntEnable = 0x4;  //TIMER 0 on board
    	//Give the VIC the adress
    	VICVectAddr0=(unsigned long) T0IRQ;
    	//start the timer
    	T0TCR=0x1;
    	while(1){}
    	//TOGGLE LED
    	if(switcher) {
    		IOSET0 = 0<<LED1PIN;
    		switcher = 0;
    	} else {
    		switcher = 1;
    	//RESET NECCESSARY TIMER VALUES
    	T0IR=0x1;
    	//END ISR
    	VICVectAddr=0xff;
    Falls einer mal vor dem selben Problem steht:
    Dieser Code funktioniert...
    /* PROJECT NAME: INTERRUPTS	                                */
    /* Project:      LPC2100                                    */
    /* Engineer:     S. Stefanowitsch                           */
    /* Filename:     main.c                                     */
    /* Language:     C                      	                */
    /* Compiler:     Keil ARM	V2.00b		                    */
    /* Assembler:    				                            */
    // olimex LPC-P2129: LED on P0.12 (active low)
    #define LED1PIN  	12
    int main(void)
    //INIT
    	VPBDIV=0x01;
    	T0TCR = 0x0;
    	T0TC  = 0x0;
    	T0PR  = 0x0;
    	T0PC  = 0x0;
    	T0MR0 = 0x1FF;
    	T0MCR = 0x3;
    	//INitialise the VIC
    	VICVectAddr4 = (unsigned long) T0IRQ;
    	VICVectCntl4= 0x24; //Allow This Vector, set is as IRQ Slot 4
    	VICIntEnable = 0x10;//TIMER 0 on board
    	//start the timer
    	T0TCR=0x1;
    	while(1){}
    	//TOGGLE LED
    	if(switcher) {
    		switcher = 0;
    	} else {
    		IOCLR0 = 1<<LED1PIN;
    		switcher = 1;
    	//RESART TIMER
    	T0IR=0x1;
    	//END ISR "Pseudo Write Operation"
    	VICVectAddr=0xff;
