Juchhu! *Freu*
funktioniert .. lässt sich 0 - 99,6% duty cycle regeln
lag das nur an dem _WRT_ENABLE_ON
was beim 876A _WRT_OFF heißen muß..hmm ?
schön \/
der funktionierende code wie er im pic steckt:
(oben das komplette *.inc vom 876A bis config bits)
Code:list p=16f876a ERRORLEVEL -302 ;SUPPRESS BANK SELECTION MESSAGES IFNDEF __16F876A MESSG "Processor-header file mismatch. Verify selected processor." ENDIF ;========================================================================== ; ; Register Definitions ; ;========================================================================== W EQU H'0000' F EQU H'0001' ;----- Register Files------------------------------------------------------ INDF EQU H'0000' TMR0 EQU H'0001' PCL EQU H'0002' STATUS EQU H'0003' FSR EQU H'0004' PORTA EQU H'0005' PORTB EQU H'0006' PORTC EQU H'0007' PCLATH EQU H'000A' INTCON EQU H'000B' PIR1 EQU H'000C' PIR2 EQU H'000D' TMR1L EQU H'000E' TMR1H EQU H'000F' T1CON EQU H'0010' TMR2 EQU H'0011' T2CON EQU H'0012' SSPBUF EQU H'0013' SSPCON EQU H'0014' CCPR1L EQU H'0015' CCPR1H EQU H'0016' CCP1CON EQU H'0017' RCSTA EQU H'0018' TXREG EQU H'0019' RCREG EQU H'001A' CCPR2L EQU H'001B' CCPR2H EQU H'001C' CCP2CON EQU H'001D' ADRESH EQU H'001E' ADCON0 EQU H'001F' OPTION_REG EQU H'0081' TRISA EQU H'0085' TRISB EQU H'0086' TRISC EQU H'0087' PIE1 EQU H'008C' PIE2 EQU H'008D' PCON EQU H'008E' SSPCON2 EQU H'0091' PR2 EQU H'0092' SSPADD EQU H'0093' SSPSTAT EQU H'0094' TXSTA EQU H'0098' SPBRG EQU H'0099' CMCON EQU H'009C' CVRCON EQU H'009D' ADRESL EQU H'009E' ADCON1 EQU H'009F' EEDATA EQU H'010C' EEADR EQU H'010D' EEDATH EQU H'010E' EEADRH EQU H'010F' EECON1 EQU H'018C' EECON2 EQU H'018D' ;----- STATUS Bits -------------------------------------------------------- IRP EQU H'0007' RP1 EQU H'0006' RP0 EQU H'0005' NOT_TO EQU H'0004' NOT_PD EQU H'0003' Z EQU H'0002' DC EQU H'0001' C EQU H'0000' ;----- INTCON Bits -------------------------------------------------------- GIE EQU H'0007' PEIE EQU H'0006' T0IE EQU H'0005' INTE EQU H'0004' RBIE EQU H'0003' T0IF EQU H'0002' INTF EQU H'0001' RBIF EQU H'0000' ;----- PIR1 Bits ---------------------------------------------------------- ADIF EQU H'0006' RCIF EQU H'0005' TXIF EQU H'0004' SSPIF EQU H'0003' CCP1IF EQU H'0002' TMR2IF EQU H'0001' TMR1IF EQU H'0000' ;----- PIR2 Bits ---------------------------------------------------------- CMIF EQU H'0006' EEIF EQU H'0004' BCLIF EQU H'0003' CCP2IF EQU H'0000' ;----- T1CON Bits --------------------------------------------------------- T1CKPS1 EQU H'0005' T1CKPS0 EQU H'0004' T1OSCEN EQU H'0003' NOT_T1SYNC EQU H'0002' T1INSYNC EQU H'0002' ; Backward compatibility only T1SYNC EQU H'0002' TMR1CS EQU H'0001' TMR1ON EQU H'0000' ;----- T2CON Bits --------------------------------------------------------- TOUTPS3 EQU H'0006' TOUTPS2 EQU H'0005' TOUTPS1 EQU H'0004' TOUTPS0 EQU H'0003' TMR2ON EQU H'0002' T2CKPS1 EQU H'0001' T2CKPS0 EQU H'0000' ;----- SSPCON Bits -------------------------------------------------------- WCOL EQU H'0007' SSPOV EQU H'0006' SSPEN EQU H'0005' CKP EQU H'0004' SSPM3 EQU H'0003' SSPM2 EQU H'0002' SSPM1 EQU H'0001' SSPM0 EQU H'0000' ;----- CCP1CON Bits ------------------------------------------------------- CCP1X EQU H'0005' CCP1Y EQU H'0004' CCP1M3 EQU H'0003' CCP1M2 EQU H'0002' CCP1M1 EQU H'0001' CCP1M0 EQU H'0000' ;----- RCSTA Bits --------------------------------------------------------- SPEN EQU H'0007' RX9 EQU H'0006' RC9 EQU H'0006' ; Backward compatibility only NOT_RC8 EQU H'0006' ; Backward compatibility only RC8_9 EQU H'0006' ; Backward compatibility only SREN EQU H'0005' CREN EQU H'0004' ADDEN EQU H'0003' FERR EQU H'0002' OERR EQU H'0001' RX9D EQU H'0000' RCD8 EQU H'0000' ; Backward compatibility only ;----- CCP2CON Bits ------------------------------------------------------- CCP2X EQU H'0005' CCP2Y EQU H'0004' CCP2M3 EQU H'0003' CCP2M2 EQU H'0002' CCP2M1 EQU H'0001' CCP2M0 EQU H'0000' ;----- ADCON0 Bits -------------------------------------------------------- ADCS1 EQU H'0007' ADCS0 EQU H'0006' CHS2 EQU H'0005' CHS1 EQU H'0004' CHS0 EQU H'0003' GO EQU H'0002' NOT_DONE EQU H'0002' GO_DONE EQU H'0002' ADON EQU H'0000' ;----- OPTION_REG Bits ----------------------------------------------------- NOT_RBPU EQU H'0007' INTEDG EQU H'0006' T0CS EQU H'0005' T0SE EQU H'0004' PSA EQU H'0003' PS2 EQU H'0002' PS1 EQU H'0001' PS0 EQU H'0000' ;----- PIE1 Bits ---------------------------------------------------------- ADIE EQU H'0006' RCIE EQU H'0005' TXIE EQU H'0004' SSPIE EQU H'0003' CCP1IE EQU H'0002' TMR2IE EQU H'0001' TMR1IE EQU H'0000' ;----- PIE2 Bits ---------------------------------------------------------- CMIE EQU H'0006' EEIE EQU H'0004' BCLIE EQU H'0003' CCP2IE EQU H'0000' ;----- PCON Bits ---------------------------------------------------------- NOT_POR EQU H'0001' NOT_BO EQU H'0000' NOT_BOR EQU H'0000' ;----- SSPCON2 Bits -------------------------------------------------------- GCEN EQU H'0007' ACKSTAT EQU H'0006' ACKDT EQU H'0005' ACKEN EQU H'0004' RCEN EQU H'0003' PEN EQU H'0002' RSEN EQU H'0001' SEN EQU H'0000' ;----- SSPSTAT Bits ------------------------------------------------------- SMP EQU H'0007' CKE EQU H'0006' D EQU H'0005' I2C_DATA EQU H'0005' NOT_A EQU H'0005' NOT_ADDRESS EQU H'0005' D_A EQU H'0005' DATA_ADDRESS EQU H'0005' P EQU H'0004' I2C_STOP EQU H'0004' S EQU H'0003' I2C_START EQU H'0003' R EQU H'0002' I2C_READ EQU H'0002' NOT_W EQU H'0002' NOT_WRITE EQU H'0002' R_W EQU H'0002' READ_WRITE EQU H'0002' UA EQU H'0001' BF EQU H'0000' ;----- TXSTA Bits --------------------------------------------------------- CSRC EQU H'0007' TX9 EQU H'0006' NOT_TX8 EQU H'0006' ; Backward compatibility only TX8_9 EQU H'0006' ; Backward compatibility only TXEN EQU H'0005' SYNC EQU H'0004' BRGH EQU H'0002' TRMT EQU H'0001' TX9D EQU H'0000' TXD8 EQU H'0000' ; Backward compatibility only ;----- CMCON Bits --------------------------------------------------------- C2OUT EQU H'0007' C1OUT EQU H'0006' C2INV EQU H'0005' C1INV EQU H'0004' CIS EQU H'0003' CM2 EQU H'0002' CM1 EQU H'0001' CM0 EQU H'0000' ;----- CVRCON Bits -------------------------------------------------------- CVREN EQU H'0007' CVROE EQU H'0006' CVRR EQU H'0005' CVR3 EQU H'0003' CVR2 EQU H'0002' CVR1 EQU H'0001' CVR0 EQU H'0000' ;----- ADCON1 Bits -------------------------------------------------------- ADFM EQU H'0007' PCFG3 EQU H'0003' PCFG2 EQU H'0002' PCFG1 EQU H'0001' PCFG0 EQU H'0000' ;----- EECON1 Bits -------------------------------------------------------- EEPGD EQU H'0007' WRERR EQU H'0003' WREN EQU H'0002' WR EQU H'0001' RD EQU H'0000' ;========================================================================== ; ; RAM Definition ; ;========================================================================== __MAXRAM H'1FF' __BADRAM H'8F'-H'90', H'95'-H'97', H'9A'-H'9B' __BADRAM H'105', H'107'-H'109' __BADRAM H'185', H'187'-H'189', H'18E'-H'18F' ;========================================================================== ; ; Configuration Bits ; ;========================================================================== _CP_ALL EQU H'1FFF' _CP_OFF EQU H'3FFF' _DEBUG_OFF EQU H'3FFF' _DEBUG_ON EQU H'37FF' _WRT_OFF EQU H'3FFF' ; No prog memmory write protection _WRT_256 EQU H'3DFF' ; First 256 prog memmory write protected _WRT_1FOURTH EQU H'3BFF' ; First quarter prog memmory write protected _WRT_HALF EQU H'39FF' ; First half memmory write protected _CPD_OFF EQU H'3FFF' _CPD_ON EQU H'3EFF' _LVP_ON EQU H'3FFF' _LVP_OFF EQU H'3F7F' _BODEN_ON EQU H'3FFF' _BODEN_OFF EQU H'3FBF' _PWRTE_OFF EQU H'3FFF' _PWRTE_ON EQU H'3FF7' _WDT_ON EQU H'3FFF' _WDT_OFF EQU H'3FFB' _RC_OSC EQU H'3FFF' _HS_OSC EQU H'3FFE' _XT_OSC EQU H'3FFD' _LP_OSC EQU H'3FFC' LIST ;========================================================================== ; ; Configuration ; ;========================================================================== __CONFIG _CP_OFF & _DEBUG_OFF & _LVP_OFF & _WRT_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_OFF & _HS_OSC ;========================================================================== ; ; Variable Definition ; ;========================================================================== wait EQU 0x20 ; Anfangsinitialisierung init ; PWM vorbereiten ; Vorteiler 16:1 und Timer2 einschalten BSF T2CON,T2CKPS1 ; Vorteiler 16:1 BSF T2CON,TMR2ON ; Timer2 ein ; Frequenz auf 1,22 kHz einstellen BSF STATUS,RP0 ; Bank1 MOVLW D'255' ; MOVWF PR2 ; 1.22 kHz BCF STATUS,RP0 ; Bank1 ; Tastverhältnis auf 50% einstellen MOVLW D'127' ; MOVWF CCPR1L ; 50% ; RC2/CCP1 auf Ausgang stellen BSF STATUS,RP0 ; Bank1 BCF TRISC, 2 ; RC2: output=0 BCF STATUS,RP0 ; Bank 0 ; PWM MODE mit CCP1 initialisieren CLRF CCP1CON ; CCP1-Modus aus BSF CCP1CON,CCP1M3 ; CCP1-Modus PWM-Mode BSF CCP1CON,CCP1M2 ; ; ADC vorbereiten ; PortB vorbereiten bsf STATUS, RP0 ; auf Bank 1 umschalten movlw B'00000000' ; PortB alle output movwf TRISB bcf STATUS, RP0 ; auf Bank 0 zurückschalten clrf PORTB ; alle LEDs ausschalten ; ADC einschalten BSF ADCON0, 0 ; ADON=1 ; ADC-Eingang AN0 auswählen BCF ADCON0, 5 ; ADCHS2=0 BCF ADCON0, 4 ; ADCHS1=0 BCF ADCON0, 3 ; ADCHS0=0 ; ADC speed für 20 MHz einstellen BSF ADCON0, 7 ; ADCS1=1 BCF ADCON0, 6 ; ADCS0=0 ; Daten linksbündig BSF STATUS,RP0 ; Bank1 BCF ADCON1, 7 ; ADFM=0 BCF STATUS,RP0 ; Bank0 ;********************************************************** ; Hauptprogrammschleife Main ;Eingangsspannung wandeln BSF ADCON0, 2 ; ADC starten loop BTFSC ADCON0, 2 ; ist der ADC fertig? GOTO loop ; nein, weiter warten ; Wert nach PortB schreiben movfw ADRESH ; obere 8 Bit auslesen movwf PORTB ; obere 8 Bit nach PortB ; Wert an PWM übergeben MOVWF CCPR1L ; obere 8 Bit sind PWM ; Warten, damit der ADC sich erholen kann clrf wait warten DECFSZ wait, f goto warten goto Main end
Vielen vielen Dank !!![]()
Zitieren
