Hallo RamJam,
4 Kanal Hardware PWM Beispiel für M32.
Code:Config Portb = &B00001000 Config Portd = &B10110000 Config Timer0 = Pwm , Pwm = On , Compare = Clear , Prescale = 1 ' 8 Bit PWM Ausgang Portb.3 Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down , Prescale = 1 ' 8 Bit PWM Ausgang Portd.4 und Portd.5 Config Timer2 = Pwm , Pwm = On , Compare = Clear , Prescale = 1 ' 8 Bit PWM Ausgang Portd.7 Enable Timer0 Enable Timer1 Enable Timer2 Enable Interrupts Compare1a = Wert (0 - 255) Compare1b = Wert (0 - 255) Ocr0 = Wert (0 - 255) Ocr2 = Wert (0 - 255)
Zitieren
