Naja ich poste jetzt mal einfach meinen Kram, das programm geht vollkommen. Vllt kannst du ja was finden was du vergessen hast (steh grad leider unter Zeitdruck und kann es daher nicht alles raussuchen).
Ist übrigens mein 1. Porgramm *fg*
MfgCode:$regfile = "m16def.dat" $framesize = 32 $swstack = 32 $hwstack = 32 $crystal = 16000000 $baud = 9600 Config Lcd = 16 * 2 Config Lcdpin = Pin , Db4 = Portc.0 , Db5 = Portc.1 , Db6 = Portc.2 , Db7 = Portc.3 , E = Portc.5 , Rs = Portc.4 Cls Cursor Off Dim U As Word Dim I As Integer Dim Teiler As Integer Dim W As Integer Teiler = 20 'Umrechnung A/D Wert W = 1 'Abbruch Bedingung Eingabe Config Adc = Single , Prescaler = Auto Start Adc Config Pina.0 = Input 'AD Config Pinc.6 = Output 'LED Config Pinc.7 = Input 'S1 Portc.7 = 1 'Start Locate 1 , 1 Lcd "<<<<uC Timer>>>>" Locate 2 , 1 Lcd "by Stefan Reible" Wait 2 Cls Locate 1 , 1 Do Lcd "Loading" Lcd " ." Waitms 200 Lcd "." Waitms 200 Lcd "." Waitms 200 Incr I Cls Loop Until I = 3 'Eingabe Timer I = 0 Do Locate 1 , 1 Lcd "Timer setzen: " U = Getadc(0) I = U / Teiler Locate 2 , 1 Lcd "Sek: " ; I ; Locate 2 , 14 Lcd "OK?" Waitms 200 Loop Until Pinc.7 = 0 'Go Cls U = I I = 0 W = 0 Locate 1 , 1 Lcd "Timer = " ; U ; " Sek" ; Locate 2 , 11 Lcd "Start?" Wait 1 Do If Pinc.7 = 0 Then Do Cls Locate 1 , 1 Lcd U ; " Sekunden"; U = U - 1 Wait 1 Loop Until U = 0 W = 1 End If Loop Until W = 1 Cls Locate 1 , 1 Lcd "Fertig!" Locate 2 , 1 Lcd "LED = AN" Portc.6 = 1 'LED an End 'end program
Lenox
Zitieren
