Seite 9 von 41 ErsteErste ... 789101119 ... LetzteLetzte
Ergebnis 81 bis 90 von 405
Thema: Alternative zu Flashnnn.exe
  1. #81
    Hallo Osser,
    ich schreibe zum ersten mal und habe mit deinen Programm schwierigkeiten. Bekomme immer diese Fehlermeldung die ich nicht verstehe.
    C:\AsuroFlash\Projekte\Zweite\Project2.hex
    is set as default flash file.
    Use program button to flash it to hardware.
    File saved.
    Default make_all.cmd file created.
    Default makefile created.
    Make
    C:\AsuroFlash\Projekte\Zweite>C:\WinAVR\utils\bin\ make.exe all
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=new.lst -IC:\AsuroFlash\include new.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > new.d; \
    [ -s new.d ] || rm -f new.d
    -------- begin --------
    avr-gcc --version
    avr-gcc (GCC) 3.3.1
    Copyright (C) 2003 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions. There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    Size before:
    Project2.elf :
    section size addr
    .text 102 0
    .data 0 8388704
    .bss 0 8388704
    .noinit 0 8388704
    .eeprom 0 8454144
    .stab 768 0
    .stabstr 1685 0
    Total 2555
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=new.lst -IC:\AsuroFlash\include new.c -o new.o
    new.c:3: warning: return type of `main' is not `int'
    new.c: In function `main':
    new.c:9: warning: `return' with a value, in function returning void
    avr-gcc -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=new.o -IC:\AsuroFlash\include new.o --output Project2.elf -Wl,-Map=Project2.map,--cref -IC:\AsuroFlash\lib -lm
    new.o(.text+0x Bild  : In function `main':
    C:\AsuroFlash\Projekte\Zweite/new.c:4: undefined reference to `Init'
    make.exe: *** [Project2.elf] Error 1
    ExitCode 2
    Ready.
    Wie bekomme ich diesen Error 1 weg
    Juelicher
  2. #82
    Hallo Osser,
    Ich Habe denn Fehler gefunden, Hoffentlich.
    Mußte nur asuro.c und asuro.h mit einbinden.
    Juelicher
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken miteinf_gen.jpg
  3. #83
    Hilfe
    würde dein Programm auch sehr gerne mal benutzen aber leider sind bei mir die Schaltflächen "Make all" und "Make clean" grau hinterlegt.
    Woran kann das liegen?
    Habe den richtigen Pfad angegeben aber leider geht nichts.
    Mfg Tom
  4. #84
    Hallo Minifuzi,
    Habe immer noch Schwierigkeiten mit dem Programm vom Osser,
    aber wie du die Make all und Make clean aktivieren kannst, das weis ich schon.
    Einfach das Projekt und die Dateien abspeichern. Bei mir hat es Funktioniert die Dateien einzelnt abzuschbeichern.
    Wenn ich dann auf Projekt speichern gehe werden Alle Dateien und das Projekt abgespeichert.
    Juelicher
  5. #85
    Dankeschön, das das so einfach hätt ich mir nicht gedacht. Jetzt bin ich schon mal einen Schritt weiter zu meinem egenen Programm. Bild
    Mfg Tom
  6. #86
    So, jetzt hab ich zwar dei Schaltflächen bekomm aber immer wieder folgende Fehlermeldung:
    Asuro Flash (Alias Eierlegendewollmilchsau)	 V1.1.5.30 (c) O.O. Müller 2006
    User has admin rights.
    Processor , OS WINXP
    Hello Tom on PAUL, have fun :)
    Session Environment Variables:
    AF_AVRDIR=C:\Programme\Asuro\WinAVR
    AF_PROJECT=Project1
    AF_SOURCE_FILES=
    AF_ASM_SRC_FILES=
    AF_PRGDIR=C:\Programme\Asuro\AsuroFlash
    >Ready.
    File saved as C:\Programme\Asuro\AsuroFlash\test.c
    AF_PROJECT=test
    AF_SOURCE_FILES=test.c
    AF_ASM_SRC_FILES=
    File test.c saved.
    Make
    C:\Programme\Asuro\AsuroFlash>C:\Programme\Asuro\WinAVR\utils\bin\make.exe all
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst -IC:\Programme\Asuro\AsuroFlash\include test.c \
    	| sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > test.d; \
    	[ -s test.d ] || rm -f test.d
    avr-gcc --version
    avr-gcc (GCC) 4.2.2 (WinAVR 20071221)
    Copyright (C) 2007 Free Software Foundation, Inc.
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst -IC:\Programme\Asuro\AsuroFlash\include test.c -o test.o
    test.c:1:19: error: asuro.h: No such file or directory
    test.c:3: warning: return type of 'main' is not 'int'
    test.c: In function 'main':
    test.c:9: warning: 'return' with a value, in function returning void
    make: *** [test.o] Error 1
    ExitCode 2
    Ready.
    File test.c saved.
    AF_PROJECT=test
    AF_ASM_SRC_FILES=
    File test.c saved.
    Make
    test.c:1:54: error: asuro.h: No such file or directory
    avr-gcc --version
    ExitCode 2
    Ready.
    AF_PROJECT=test
    AF_SOURCE_FILES=..\test.c
    AF_ASM_SRC_FILES=
    File test.c saved.
    Make
    C:\Programme\Asuro\AsuroFlash\FirstTry>C:\Programme\Asuro\WinAVR\utils\bin\make.exe all
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=..\test.lst -IC:\Programme\Asuro\AsuroFlash\include ..\test.c \
    	| sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > ..\test.d; \
    	[ -s ..\test.d ] || rm -f ..\test.d
    avr-gcc.exe: ..test.c: No such file or directory
    avr-gcc.exe: no input files
    avr-gcc --version
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=..\test.lst -IC:\Programme\Asuro\AsuroFlash\include ..\test.c -o ..\test.o
    ..\test.c:1:54: error: asuro.h: No such file or directory
    ..\test.c:3: warning: return type of 'main' is not 'int'
    ..\test.c: In function 'main':
    ..\test.c:9: warning: 'return' with a value, in function returning void
    make: *** [..\test.o] Error 1
    ExitCode 2
    Ready.
    AF_PROJECT=test
    AF_SOURCE_FILES=..\test.c test.c
    AF_ASM_SRC_FILES=
    Make
    avr-gcc --version
    make: *** No rule to make target `test.hex', needed by `all'.  Stop.
    ExitCode 2
    Ready.
    File saved as C:\Programme\Asuro\AsuroFlash\FirstTry\test.c
    AF_PROJECT=test
    AF_ASM_SRC_FILES=
    Make
    avr-gcc --version
    ExitCode 2
    Ready.
  7. #87
    Hallo Minifuzi,
    Kann es sein das du im Projektverzeichnis kein asuro.h eingebunden hast?
    Und das es zwei test.c im Projektverzeichnis gibt?
    Juelicher
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken asuroflash01.jpg
  8. #88
    Hallo allerseits,
    ich bin noch relativ neu hier und möchte dieses Programm auch benutzen, weiß aber nicht was ich da alles einstellen muss (z.B. den Pfad für den AVR, muss man da eine bestimmte Datei auswählen?)
    mfg hai1991
  9. #89
    Wo ist Osser? Oder Jemand der weiß wie es geht??
    Habe immer noch Probleme!!!
    Ein einfaches Programm.
    #include <asuro.h>
    int main(void) {
    Init();
    while (1) {
    while (1) {}
    return 0;
    Macht mir diese Schwierigkeiten.
    Hello Gerhard on KSHK, have fun Bild
    AF_AVRDIR=C:\WinAVR-20071221
    AF_PROJECT=Project1
    AF_SOURCE_FILES=
    AF_ASM_SRC_FILES=
    AF_PRGDIR=C:\Programme\AsuroFlash2
    >Ready.
    File new.c saved.
    File asuro.h saved.
    File myasuro.h saved.
    File asuro.c saved.
    AF_PROJECT=Project1
    AF_SOURCE_FILES=new.c asuro.c
    AF_ASM_SRC_FILES=
    File new.c saved.
    File asuro.h saved.
    File asuro.c saved.
    Make
    C:\AsuroFlash2>C:\WinAVR-20071221\utils\bin\make.exe all
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst -IC:\Programme\AsuroFlash2\include asuro.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > asuro.d; \
    [ -s asuro.d ] || rm -f asuro.d
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=new.lst -IC:\Programme\AsuroFlash2\include new.c \
    avr-gcc --version
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=new.lst -IC:\Programme\AsuroFlash2\include new.c -o new.o
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst -IC:\Programme\AsuroFlash2\include asuro.c -o asuro.o
    avr-gcc -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=new.o -IC:\Programme\AsuroFlash2\include new.o asuro.o --output Project1.elf -Wl,-Map=Project1.map,--cref -IC:\Programme\AsuroFlash2\lib -lm
    asuro.o: In function `__vector_4':
    C:\AsuroFlash2/asuro.c:208: undefined reference to `count36kHz'
    C:\AsuroFlash2/asuro.c:209: undefined reference to `count36kHz'
    C:\AsuroFlash2/asuro.c:210: undefined reference to `timebase'
    asuro.o:C:\AsuroFlash2/asuro.c:210: more undefined references to `timebase' follow
    asuro.o: In function `__vector_2':
    C:\AsuroFlash2/asuro.c:247: undefined reference to `switched'
    asuro.o: In function `__vector_14':
    C:\AsuroFlash2/asuro.c:282: undefined reference to `autoencode'
    C:\AsuroFlash2/asuro.c:300: undefined reference to `encoder'
    C:\AsuroFlash2/asuro.c:305: undefined reference to `encoder'
    asuro.o: In function `Init':
    C:\AsuroFlash2/asuro.c:164: undefined reference to `FrontLED'
    C:\AsuroFlash2/asuro.c:165: undefined reference to `BackLED'
    C:\AsuroFlash2/asuro.c:166: undefined reference to `BackLED'
    C:\AsuroFlash2/asuro.c:167: undefined reference to `StatusLED'
    C:\AsuroFlash2/asuro.c:169: undefined reference to `MotorDir'
    C:\AsuroFlash2/asuro.c:170: undefined reference to `MotorSpeed'
    C:\AsuroFlash2/asuro.c:172: undefined reference to `autoencode'
    make: *** [Project1.elf] Error 1
    ExitCode 2
    Ready.
    Im Projektverzeichnis Proiekt1.apri ist asuro.h , asuro.c , myasuro.h und new.c eingebunden und gespeichert.
    Wer kann mir Helfen?
    Juelicher
  10. #90
    Milda
    lies ein wenig in der hilfe und im thread, dann dürftest du alles finden.
    Read... or die.
    ff.mud.de:7600
