Hi!
Hier noch mein Programmcode:
Code:$regfile = "m32def.dat" 'Die Anweisung bestimmt Ccntrollertyp, hier AVR Mega 32 $crystal = 16000000 $baud = 9600 ' I2C SETUP Config Scl = Portc.0 Config Sda = Portc.1 Config Twi = 100000 'LED AUS Config Portc.2 = Output Config Portc.3 = Output Portc.2 = 0 Portc.3 = 0 ' CONSTANTS 'Anx-S20 Board Slave Adresse Const Anx = &HC2 ' FUNCTIONS Declare Sub Anxwrite(byval Servo As Byte , Byval Pos As Byte) Call Anxwrite(4 , 80) Wait 2 Call Anxwrite(4 , 180) Wait 2 Print "Kopf rechts - links.." I2cinit 'Startet den I2C Bus Sub Anxwrite(servo As Byte , Pos As Byte) I2cstart I2cwbyte Anx Servo = Servo + 62 I2cwbyte Servo ' 8-Bit Register ab Reg. 63 I2cwbyte Pos I2cstop Waitms 10 End Sub
Zitieren
