Ich habe das Programm mal etwas bearbeitet.Code:$regfile = "m8def.dat" $crystal = 16000000 Dim Result As Word Dim Channel As Byte Config Pinb.1 = Output Config Pinb.2 = Output Config Pinc.0 = Output Config Pinc.1 = Output Config Pinc.2 = Output Config Pinc.3 = Output Config Pinc.4 = Input Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Compare B Pwm = Clear Up , Prescale = 1 Config Adc = Single , Prescaler = Auto , Reference = Avcc Compare1a = 1 Compare1b = 1 Portc.0 = 1 Portc.1 = 0 Portc.2 = 1 Portc.3 = 0 Start Adc Do Result = Getadc(4) ; Result ; If Result = 1000 Then Portc.0 = 0 Portc.1 = 1 Portc.2 = 0 Portc.3 = 1 Wait 1 Loop End
So mache ich es bei mir immer.
Was ich geändert habe findest du, denke ich, selbst raus, wenn du es die nochmal genauer anschaust.
Zitieren
