Ergebnis 1 bis 4 von 4
Thema: IS IT POSSIBLE? ASURO - FrontLED's navigation-Not line-trace
    HI!
    We would like to do that our ASURO will able to navigate with its FrontLED!
    IS IT POSSIBLE? How long can Asuro see with its FrontLED?
    Danke!
    Milda
    LEDs can only make light, they do not receive anything.
    if you mean the LED-like looking things left and right to the red Front-LED, they can only "see" if it is dark or if there is light; so they wont be able to se shapes or a real picture. so you won't be able to do a real navigation in any way with these parts.
    try to search for "kamera" is the asuro board, there are a few tries to navigate the asuro with a camera.
    Read... or die.
    ff.mud.de:7600
    Bielefeld
    Howdy,
    british manual is available on CD.ROM either. You´ll find the answer to your request pretty well by reading.
    CU, (Michael)
    Südwestdeutschland
    3
    The two parts left and right to the front led's are Fototransistors.
    Using one of this Fototransistor would enable you to develope a kind of 'one pixel kamera'.
    You have to place the Fototransistor at the end of a small black tube. At the other end you have to install a lens. This will give you a kind of telescope.
    stochri
