ok, nun geht es fast![]()
hier nochmal der Code:
main.c
usart.cCode:#define F_CPU 16000000 #include <avr/io.h> #include <util/delay.h> #include <inttypes.h> #include "usart.c" void wait_ms(int i) { int x = 0; while(x <= i) { _delay_ms(1); x++; } } int main(void) { usart_init(); while(1) { usart_print("Test\n"); wait_ms(1000); } return 0; }
Nun kommt im Terminal immer Zeichensalat (wenigstens etwasCode:#define USART_BAUD_RATE 9600 #define USART_BAUD_SELECT (F_CPU/(USART_BAUD_RATE*16l)-1) void usart_init() { /* Set baud rate */ UBRRH = (uint8_t) (USART_BAUD_SELECT>>8); UBRRL = (uint8_t) USART_BAUD_SELECT; /* Enable Receiver and Transmitter */ UCSRB = (1<<RXEN) | (1<<TXEN); /* Set frame format: 8data, 2stop bit */ UCSRC = (1<<URSEL) | (1<<USBS) | (1<<UCSZ0); } void usart_transmit(uint8_t data) { /* Wait for empty transmit buffer */ while ( !( UCSRA & (1<<UDRE)) ) ; /* Put data into buffer, sends the data */ UDR = data; } void usart_print(char *s) { do { usart_transmit(*s); } while (*s++); })
Hast du noch eine Idee an was es liegen könnte?
Viele Grüße,
Johannes[/code]
Zitieren
