Ergebnis 1 bis 10 von 15
Thema: Mein 81 Fullcolor Colour LED bild
Baum-Darstellung
  1. #13
    HI,
    also hier ist mal der Code:
    $regfile = "8535def.dat"
    $crystal = 1000000
    Declare Sub Allesaus
    Config Timer2 = Timer , Prescale = 64
    Const Aus = 1
    Const An = 0
    Config Porta.0 = Output
    Config Porta.1 = Output
    Config Porta.2 = Output
    Config Porta.3 = Output
    Config Porta.4 = Output
    Config Porta.5 = Output
    Config Porta.6 = Output
    Config Porta.7 = Output
    Config Portb.0 = Output
    Config Portd.4 = Output
    Config Portd.5 = Output
    Config Portb.3 = Output
    Led0 Alias Porta.0
    Led1 Alias Porta.1
    Led2 Alias Porta.2
    Led3 Alias Porta.3
    Led4 Alias Porta.4
    Led5 Alias Porta.5
    Led6 Alias Porta.6
    Led7 Alias Porta.7
    Led8 Alias Portb.0
    Rot Alias Portd.4
    Blau Alias Portd.5
    Gruen Alias Portb.3
    Dim Wertr(10) As Integer
    Dim Wertb(10) As Integer
    Dim Wertg(10) As Integer
    Dim I As Integer
    Dim J As Integer
    Dim Value As Integer
    Wertr(1) = 0
    Wertg(1) = 0
    Wertb(1) = 0
    Wertr(2) = 0
    Wertg(2) = 0
    Wertb(2) = 1
    Wertr(3) = 0
    Wertg(3) = 0
    Wertb(3) = 1
    Wertr(4) = 1
    Wertg(4) = 0
    Wertb(4) = 0
    Wertr(5) = 0
    Wertg(5) = 0
    Wertb(5) = 1
    Wertr(6) = 0
    Wertg(6) = 0
    Wertb(6) = 1
    Wertr(7) = 0
    Wertg(7) = 0
    Wertb(7) = 1
    Wertr(8) = 0
    Wertg(8) = 0
    Wertb(8) = 1
    Wertr(9) = 0
    Wertg(9) = 0
    Wertb(9) = 1
    I = 0
    On Timer2 Zeitroutine
    Const Timervorgabe = 12
    Enable Timer2
    Enable Interrupts
    Do
    Loop
    Zeitroutine:
       Timer2 = Timervorgabe
       I = I + 1
       If I > 9 Then I = 1
       Call Allesaus
       Waitms 1
          If Wertr(i) = 1 Then Rot = An
          If Wertg(i) = 1 Then Gruen = An
          If Wertb(i) = 1 Then Blau = An
          Select Case I
          Case 1
             Led0 = An
          Case 2
             Led1 = An
          Case 3
             Led2 = An
          Case 4
             Led3 = An
          Case 5
             Led4 = An
          Case 6
             Led5 = An
          Case 7
             Led6 = An
          Case 8
             Led7 = An
          Case 9
             Led8 = An
          End Select
       Value = Value + 1
       If Value > 512 Then
          For J = 9 To 1 Step -1
             Wertr(j + 1) = Wertr(j)
             Wertg(j + 1) = Wertg(j)
             Wertb(j + 1) = Wertb(j)
          Next J
          Wertr(1) = Wertr(10)
          Wertg(1) = Wertg(10)
          Wertb(1) = Wertb(10)
          Value = 0
       End If
       Return
    Sub Allesaus:
       Led0 = Aus
       Led1 = Aus
       Led2 = Aus
       Led3 = Aus
       Led4 = Aus
       Led5 = Aus
       Led6 = Aus
       Led7 = Aus
       Led8 = Aus
       Rot = Aus
       Blau = Aus
       Gruen = Aus
       End Sub
    Ich verstehe ihn nicht , weil den mein Vater geschreiben hat.
    ok und hier sind die Schaltpläne
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken led_bild2.gif   led_bild1.gif
