Juhhu, es Funktioniert![]()
Ich habe die ganze Flankentriggerung weggelassen und die Interrupts nun heiss auf "any logical change" gemacht...
Vielen Dank nochmals für dienen Hilfe!
Hier der funktionierende Code:
Code:#include <inttypes.h> #include <avr/interrupt.h> #define F_CPU 8000000 /* 8Mhz */ #include <util/delay.h> /* definiert _delay_ms() ab avr-libc Version 1.2.0 */ #include "twimaster.c" #include "LCD.h" volatile long t2_y,t2_x; volatile long t1_y,t1_x; volatile int x1,x0; // Temp Variablen für ISR's int count_y, count_x; char ziel[5]; ISR(SIG_INTERRUPT1){ GIFR = 0; if(x1==1){ x1=0; t1_y = count_y; } else{ x1=1; t2_y = count_y; count_y = 0; } } ISR(SIG_INTERRUPT0){ GIFR = 0; if(x0==1){ x0=0; t1_x = count_x; } else{ x0=1; t2_x = count_x; count_x = 0; } } ISR (SIG_OUTPUT_COMPARE1A){ count_y++; count_x++; } void Timer_Inits(void){ TCCR1A = 0; TCCR1B = (1 << WGM12) | (1 << CS10); OCR1A = (uint16_t) ((uint32_t) F_CPU / 50000); //100000 TIMSK |= (1 << OCIE1A); // Interrupt wenn Timer Vergleichswert erreicht //Jede logische änderung von INT0 oder INT1 löst Interrupt aus MCUCR = (0<<ISC11 | 1<<ISC10 | 0<<ISC01 | 1<<ISC00); GIMSK = (1<<INT0 | 1<<INT1); //Int0 u. 1 aktiv } int main (void){ DDRC = 0x00; //alles als Eingan def. PORTC =0x00; //PullUp's aus DDRD =0x00; //alles Eingang PORTD =0x00; //PullUp's aus Timer_Inits(); i2c_init(); _delay_ms(10000); lcd_init(); _delay_ms(10000); sei(); for(;;){ _delay_ms(90000000); clear(); //A(g) = ((T1/T2) / 0.5)/12.5% int resultx,resulty; uint8_t sreg = SREG; cli(); long t1x = t1_x; long t2x = t2_x; long t1y = t1_y; long t2y = t2_y; SREG = sreg; if(t2x!=0) resultx = (((((float)t1x/(float)t2x)*1000)-481)*1000)/125; else resultx=0; if(t2y!=0) resulty = (((((float)t1y/(float)t2y)*1000)-481)*1000)/125; else resulty=0; sei(); sprintf(ziel,"%d",resultx); stringout ("ay="); stringout (ziel); sprintf(ziel,"%d",resulty); stringout (" ax="); stringout (ziel); } }
Zitieren
