schau dir mal das Beispielprogramm an das kannst du auch auf 6-8 Servos erweitern
Code:'----------------------------------------------------------------------- ' (c) 2001-2005 MCS Electronics ' servo.bas demonstrates the SERVO option '----------------------------------------------------------------------- 'Servo's need a pulse in order to operate 'with the config statement CONFIG Servos we can specify how many servo's we 'will use and which port pins are used 'A maximum of 16 Servos might be used 'The SERVO statements use one byte for an interrupt counter and the TIMER0 'This means that you can not use TIMER0 anymore 'The reload value specifies the interval of the timer in uS 'Config Servos = 2 , Servo1 = Portb.0 , Servo2 = Portb.1 , Reload = 10 $regfile = "2313def.dat" Config Servos = 1 , Servo1 = Portb.0 , Reload = 10 'as an option you can use TIMER1 'Config Servos = 2 , Servo1 = Portb.0 , Servo2 = Portb.1 , Reload = 10 , Timer = Timer1 'we use 2 Servos with 10 uS resolution(steps) 'we must configure the port pins used to act as output Config Portb = Output 'finally we must turn on the global interrupt Enable Interrupts 'the servo() array is created automatic. You can used it to set the 'time the servo must be on Servo(1) = 10 '10 times 10 = 100 uS on 'Servo(2) = 20 '20 times 10 = 200 uS on Do Loop Dim I As Byte Do For I = 0 To 100 Servo(1) = I Waitms 1000 Next For I = 100 To 0 Step -1 ' Servo(1) = I Waitms 1000 Next Loop End
Zitieren
