ich sehe nicht ganz, wie das Problem mit dem elf-File gelöst wurde. Ich habe momentan das gleiche Problem:
Build -> Compile:Code:#include <avr/io.h> #include "i2cmaster.h" #define POWER_PORTS_I2C 0x72 int main(void) { i2c_init(); // init I2C interface uint8_t ret; ret = i2c_start(POWER_PORTS_I2C + I2C_WRITE); // set device address and write mode if ( ret ) { i2c_stop(); } else { /* issuing start condition ok, device accessible */ char value; value = 1; while(1) { i2c_start_wait(POWER_PORTS_I2C + I2C_WRITE); i2c_write(value); i2c_stop(); value = value * 2; if(value > 16) { value = 1; } } } return 1; }
Build -> Build:Code:avr-gcc.exe -I"E:\mathias\projects\avr.projects\rnbfra_led\." -mmcu=atmega32 -Wall -gdwarf-2 -O0 -fsigned-char -MD -MP -MT rnbfra_led.o -MF dep/rnbfra_led.o.d -c ../rnbfra_led.c Build succeeded with 0 Warnings...
Code:Loaded plugin STK500 Loaded plugin AVR GCC Loaded partfile: C:\Programme\Atmel\AVR Tools\PartDescriptionFiles\ATmega32.xml GCC plug-in: Error: Object file not found on expected location E:\mathias\projects\avr.projects\rnbfra_led\default\rnbfra_led.elf GCC plug-in: Exported makefile to C:\Dokumente und Einstellungen\mathias\Desktop\Makefile GCC plug-in: Error: Object file not found on expected location E:\mathias\projects\avr.projects\rnbfra_led\default\rnbfra_led.elf GCC plug-in: Error: Object file not found on expected location E:\mathias\projects\avr.projects\rnbfra_led\default\rnbfra_led.elf GCC plug-in: Error: Object file not found on expected location E:\mathias\projects\avr.projects\rnbfra_led\default\rnbfra_led.elf GCC plug-in: Error: Object file not found on expected location E:\mathias\projects\avr.projects\rnbfra_led\default\rnbfra_led.elf GCC plug-in: Error: Object file not found on expected location E:\mathias\projects\avr.projects\rnbfra_led\default\rnbfra_led.elf GCC plug-in: Error: Object file not found on expected location E:\mathias\projects\avr.projects\rnbfra_led\default\rnbfra_led.elf GCC plug-in: Error: Object file not found on expected location E:\mathias\projects\avr.projects\rnbfra_led\default\rnbfra_led.elf GCC plug-in: Error: Object file not found on expected location E:\mathias\projects\avr.projects\rnbfra_led\default\rnbfra_led.elf
Unter "Source Files" steht rnbfra.c twimaster.c und i2cmaster.S. Unter "Header Files" nur i2cmaster.h. Ist also alles da was gebraucht wird.
Zitieren
