Falls es jemanden interessiert, was Bascom bei "PULSEIN" produziert:
Hat ja drei Loops:
1 Warten auf Pinx != state (count 0-65535)
2 Warten auf Pinx == state (count 0-65535)
3 Warten auf Pinx != state (count 0-65535 mit 10µS Loop)
Um die timeoutwerte zu ändern, müßt man den Code-ändern
Code:// DIM result as WORD // Pulsein Result , Pind , 2 , 1 LDI ZL,0x30 // PIND LDI r24,0x02 // PinNr LDI r16,0xFF // State CALL PULSEIN LDI XL,0x60 // addr "result" LDI XH,0x00 ST X+,r24 // store result ST X,r25 ............................................... PULSEIN: CALL Clear_ErrBit CLR ZH CLR XL // clear Timout Lo CLR XH // clear Timout Hi CALL MakeMask // R24 Mask, R25 neg Mask AND r16,r24 LDD r0,Z + 1 // DDRD AND r0,r25 // Make Pin (2) Input STD Z + 1,r0 // DDRD L_0x00D8: // ------------- Loop 1 LDD r0,Z + 0 // PIND AND r0,r24 // PIND & Mask EOR r0,r16 // (PIND & Mask) ^ State BRNE L_0x00E6 // Ok PIN != State ADIW XL,0x0001 // Timeout counter++ BREQ L_0x0118 // elapsed->ERR-Exit RJMP L_0x00D8 // cont'd Loop L_0x00E6: CLR XL // clear Timout Lo CLR XH // clear Timout Hi L_0x00EA: // ------------- Loop 2 LDD r0,Z + 0 // PIND AND r0,r24 // PIND & Mask EOR r0,r16 // (PIND & Mask) ^ State BREQ L_0x00F8 // Ok PIN == State ADIW XL,0x0001 // Timeout counter++ BREQ L_0x0118 // elapsed->ERR-Exit RJMP L_0x00EA // cont'd Loop L_0x00F8: CLR XL // clear Timout Lo CLR XH // clear Timout Hi L_0x00FC: ------------ 10 µS Loop 3 PUSH ZL // Save PUSH ZH LDI ZL,0x20 // calc from $XTAL LDI ZH,0x00 CALL L_0x009C // 10 µS Idle POP ZH // Restore POP ZL LDD r0,Z + 0 // PIND AND r0,r24 // PIND & Mask EOR r0,r16 // (PIND & Mask) ^ State BRNE L_0x011C // OK, Pulsein done ********* ADIW XL,0x0001 // PulseCounter++ BRNE L_0x00FC // cont'd Loop L_0x0118: CALL Set_ErrBit L_0x011C: MOV r24,XL // result --> R24:r25 MOV r25,XH RET // that's it // idle Loop L_0x009C: SBIW ZL,0x0001 BRNE L_0x009C RET Set_ErrBit: SET BLD r6,2 RET Clear_ErrBit: CLT BLD r6,2 RET MakeMask: LDI r25,0x01 AND r24,r24 BREQ L_0x00BC CLC L_0x00B6: ROL r25 DEC r24 BRNE L_0x00B6 L_0x00BC: MOV r24,r25 COM r25 RET
Zitieren
